'val' does not name a type
keep getting error code and can not work it out, I am trying to use 2 Arduino Compatible PIR Motion Detector Module's to light up LED's and the eventually swap the LED's for a scoring board with an LCD screen, if you know which library also would be appreciated
here is my code
int led1 = 13; // the pin that the LED is atteched to
int led2 = 14; // the pin LED2 is attatched to
int sensor = 2; // the pin that the sensor is atteched to
int sensor2 = 4; // the pin sensor 2 is attatched to
int state = LOW; // by default, no motion detected
int val = 0; // variable to store the sensor status (value)
int val2 = 2; // variable to store the sensor status (value) for sensor2
pinMode(led1, OUTPUT); // initalize LED as an output
pinMode(led2, OUTPUT); // initalize LED2 as an output
pinMode(sensor, INPUT); // initialize sensor as an input
pinMode(sensor2, INPUT); // initialize sensor2 as an input
Serial.begin(9600); // initialize serial
void loop(){
val = digitalRead(sensor); // read sensor value
if (val == HIGH) { // check if the sensor is HIGH
digitalWrite(led1, HIGH); // turn LED ON
delay(100); // delay 100 milliseconds
if (state == LOW) {
Serial.println("Motion detected!");
state = HIGH; // update variable state to HIGH
else {
digitalWrite(led1, LOW); // turn LED OFF
delay(200); // delay 200 milliseconds
if (state == HIGH){
Serial.println("Motion stopped!");
state = LOW; // update variable state to LOW
val2 = digitalRead(sensor2); // read sensor2 value
if (val2 == HIGH) { // check if the sensor is HIGH
digitalWrite(led2, HIGH); // turn LED2 ON
if (state == LOW) {
else {
digitalWrite(led2, LOW); // turn LED2 OFF
if (state == HIGH){
here is my error message:
Arduino: 1.8.12 (Mac OS X), Board: "Arduino Uno"
sketch_jun03a:40:1: error: 'val2' does not name a type
sketch_jun03a:41:3: error: expected unqualified-id before 'if'
sketch_jun03a:50:3: error: expected unqualified-id before 'else'
else {
sketch_jun03a:59:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
Any help appreciated
Sure. Press ctrl-T to auto format the code and you will see the misplaced bracket. The statement that triggered the error is not inside any code block.
Please use code tags next time you post code.
Removed a " } " at line 37, compiles now:
void loop(){
   if (state == LOW) {
 else {
     if (state == HIGH){
//} removed <<<<<<<<<<<<<<<<<
   if (state == LOW) {
 else {
     if (state == HIGH){
thank you very much
Karma bumped for providing the solution.
