'value' does not name a type - error
Hi, thanks for this tuto,
i use the library EEPROM.h for my Sketch and get this error for the compiler : 'value' does not name a type.
Please, can have your help. Thanks again.
lamboni75:
Hi, the word 'value' does not appear in the EEPROM library.
Are you creating a variable of a class/struct named 'value' or using a function parameter of a class/struct named 'value'?
Post your sketch
pYro_65:
Post your sketch
Thanks,
the sketch is :
#include <EEPROM.h>
#include <LiquidCrystal.h>
LiquidCrystal Ecran(12, 11, 5, 4, 3, 2);
int Address = 0;
byte value;
int Heures=23;
int Minutes=03;
int Secondes=59;
int Jours=29;
const int Relais = 8;
pinMode(Relais, OUTPUT);
Ecran.begin(16,2);}
value = EEPROM.read(Address);
Minutes = value;
while ( Minutes == 0) {
digitalWrite(Relais, LOW);
Ecran.setCursor(0,0);
Ecran.print(" TEMPS ");
Ecran.setCursor(0,1);
Ecran.print(" COMPTE EXPIRE ");
digitalWrite(Relais, HIGH);
Secondes --;
if (Secondes < 00) {Minutes --; Secondes = 59;};
if (Minutes < 00) {Heures --; Minutes = 59;};
if (Heures < 00) {Jours --; Heures = 23;};
if (Jours < 00) {Jours = 0;};
if (Jours < 10) {Ecran.print("0");};
Ecran.print(Jours); Ecran.print("J");
Ecran.setCursor(4,1);
if (Heures < 10) {Ecran.print("0");};
Ecran.print(Heures); Ecran.print("H");
Ecran.setCursor(8,1);
if (Minutes < 10) {Ecran.print("0");};
Ecran.print(Minutes); Ecran.print("Mn");
Ecran.setCursor(13,1);
if (Secondes < 10) {Ecran.print("0");};
Ecran.print(Secondes); Ecran.print("S");
EEPROM.write(Address,Minutes);
Hi, please use Ctrl+T or select the auto-text-format tool in the menu.
The compiler tells in which line number the problem is. You can turn on the line numbers in the settings. The first error of the compiler is the most important. The compiler says that it has problems with "value = EEPROM.read(Address) ;". That is code outside the setup() function and outside the loop() function.
An if-statement does not need a semicolon after the closing bracket.
I think the "while ( Minutes == 0) {" will run forever and never get out of that loop.
Please don't use a space in front of the decrement operator.
  Secondes --;    // not good
  Secondes--;    // good
This is the code:
#include <EEPROM.h>
int Address = 0;
byte value;
int Heures=23;
int Minutes=03;
int Secondes=59;
int Jours=29;
Ecran.begin(16,2);}
Minutes = value;
Secondes --;
That's the same code you posted a couple of days ago. The problem has already been explained to you by Koepel. The error is caused by your code, not by the EEPROM library. Before posting code please Auto Format and use code tags.
moderator: Split off this topic as it has nothing to do with the EEPROM library
tip use CTRL-T to auto indent your code
AND
check the amount of { }
