Value fluctuating a lot
All of a sudden the value showing up on my LCD which can be adjusted by a 10k potentiometer is fluctuating alot by itself. On the schematic this is the 10k pot going to to pin A4.
Hello idekman1813
Didn´t the connections aren´t soldered?
grafik
they have been soldered on the other side, i have just put glue to avoid the wires being tugged too much
How much is "a lot"?
so much so that its unreadable on the LCD, it changes really quickly. One thing that i noticed is that when i power through the main supply which is the 15v 4A which is regulated down to 5v this fluctuating is much greater as compared to when i only power the Arduino through its usb cable
Not a useful reply.
How, where, is the 15 volt regulated down to 5 ?
So it worked fine for one or more years, then one day the values started fluctuating?
I’ve added in a buck boost voltage reg which regulates voltage down to 5 v and powers nano through 5v pin
…don’t know the cause of the issue but it was working fine beforehand
Could it be the pot is worned out? Try using another pot.
That,s a good powering. Was afraid You tried to use the little one on board regulator.
According to the schematis it'tsregulated to 8V and supplied to Vin.
Did you try to supply 5V to the 5V pin with the external regulator still connected?
yeah sorry about that one, that voltage reg would heat up way too much so i replaced it with a buck boost one that regulates down to 5v and powers through 5v pin
Maybe, i did buy a new one and tested that but no avail. Ill try another one just in case
I see four sensors connected to the Nano.
Two pots and two pressure sensors.
Put some serialprints in the code, to see which sensor is fluctuating.
Leo..
Im not the best at coding, could you show me how i would implement this?
I can't tell you where to add Serial.print() lines if you don't post your code.
Leo..
//Source code for the BIPAP/CPAP low cost device v1.0
//Arduino Nano
//Details of the hardware, connections and setup can be found in www.ub.edu/biofisica
//For code details contact jorge.otero@ub.edu / m.rodriguez@ub.edu
#include <PID_v1.h>    //PID library
double Setpoint, Input, Output, flow_hp, flow_bp;   //variables
double Kp=0.38, Ki=0.75, Kd=0;    //variables and values for the PID controller KP(proportional),Ki(integral),Kd(derivative)
//Definitions
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
#define analog  10            //define digital 10 as analog.
#define analog_flow  9        //define digital 9 as analog_flow.
#include <LiquidCrystal.h>    //LCD 2x16
LiquidCrystal lcd(12,11,5,4,3,2);    //LCD connections
#define switchPin  6          //define digital 6 as SwitchPin.
#define SwitchMode  13        //define digital 13 as SwitchMode.
#define led  8                //define digital 8 as led.
byte autoipap = 0,lcdmodecpap=1,lcdmodebipap=1,switchState = 0,switchModestate = 0,restard;  //byte variables
unsigned long t0 =micros(),tiempoahora =millis();
int Tm =10000;    //Sampling frequency in microseconds
float tiempo =0;
float fc_hp=0.125;              //cutoff frequency of the high-pass filter
float fc_lp=1.125;              //cutoff frequency of the low-pass filter
float RC_hp =1/(2*PI*fc_hp);
float RC_lp =1/(2*PI*fc_lp);
double data_filt_hp[] = {0, 0};
double data_hp[] = {0, 0};
double data_filt_lp[] = {0, 0};
double data_lp[] = {0, 0};
double maximo=0,vmax=0,flow=0;
int pressure, epap,ipap,consigna=0;
float porcentaje,P_sensor,P_epap,P_ipap,P_sensor_abs,P_sensor2;
int ctroltime =0;
int gain_flow =100;
char P_sensorstring[4];
char P_sensorstring2[4];
char P_EPAPstring[4];
char P_IPAPstring[4];
char porcentajestring[2];
char timestring[2];
int i,z=0;
int samplepressure[25];   //buffer of 25 positions for the pressure sensor 1 readout
int samplepressure2[25];  //buffer of 25 positions for the pressure sensor 2 readout
double totalpress2 = 0.00, promediopress2 = 0.00, totalpress = 0.00, promediopress = 0.00;
double totalzero=0,totalzero2=0,samplezero,samplezero2,pressinzero,pressinzero2,zero,zero2;
#define sensorpress A0             //pressure sensor 1 output is connected to the analog input 0
#define sensorpress2 A1           //pressure sensor 2 output is connected to the analog input 1
#define analog_epap A4           //epap potentiometer adjustment is connected to the analog input 2
#define analog_ipap A3          //ipap potentiometer adjustment is connected to the analog input 3
#define analog_porcentaje A2   //cycling potentiometer adjustment is connected to the analog input 4
//Configuration
myPID.SetMode(AUTOMATIC);     //automatic mode in PID
consigna=ipap;
for(i=0; i< 24; i++)          //array initialization
      samplepressure[i] = 0;
      samplepressure2[i] = 0;
i=0;
lcd.begin(16,2); //LCD 2x16
pinMode(switchPin,INPUT);       //switchPin -> input
pinMode(SwitchMode,INPUT);      //switchMode -> input
pinMode(led,OUTPUT);            //led -> output
lcd.setCursor(0,0);
lcd.print("Calibrating zero");
lcd.setCursor(0,1);
for(i=0; i< 91; i++)          //array initialization
    Serial.println(i);
    if (i==0 || i==6 || i==12 || i==18 || i==24 || i==30 || i==36 || i==42 || i==48 || i==54 || i==60 ||  i==66 || i==72 || i==78 || i==84 || i==90)
        lcd.setCursor(i/6,1);
        lcd.print(".");
    samplezero = 2.5*analogRead(sensorpress);   //zero reading for pressure sensor 1
    totalzero = totalzero + samplezero;
    samplezero2 = 2.5*analogRead(sensorpress2);   //zero reading for pressure sensor 2
    totalzero2 = totalzero2 + samplezero2;
    delay(50);
zero=totalzero/i;
zero2=totalzero2/i;
lcd.setCursor(0,1);
lcd.print("                ");
lcd.setCursor(0,1);
lcd.print("P1:");
lcd.setCursor(8,1);
lcd.print("P2:");
lcd.setCursor(15,1);
lcd.print("  ");
for(i=0; i< 50; i++)
    pressinzero =2.5*analogRead(sensorpress)-zero;         //zero adjustment for pressure sensor 1
    P_sensor=abs((pressinzero/1023)*5.0*4.8);
    dtostrf(P_sensor,1,1, P_sensorstring);
    pressinzero2 =2.5*analogRead(sensorpress2)-zero2;         //zero adjustment for pressure sensor 2
    P_sensor2=abs((pressinzero2/1023)*5.0*4.8);
    dtostrf(P_sensor2,1,1, P_sensorstring2);
    lcd.setCursor(4,1);
    lcd.print(P_sensorstring);
    lcd.setCursor(12,1);
    lcd.print(P_sensorstring2);
    delay(30);
    if (P_sensor >0.3 ||P_sensor2>0.3)
        lcd.setCursor(0,0);
        lcd.print("err calibrating ");
        lcd.setCursor(0,1);
        lcd.print("                ");
        lcd.setCursor(4,1);
        lcd.setCursor(0,1);
        delay(2000);
        lcd.print("Restart sofware.");
        restard =1;
        i=50;
i=0;
// Main program loop
if (restard ==1)
    i=0;
    totalzero=0;
    totalzero2=0;
    restard=0;
    setup();
samplepressure[i] = 2.5*analogRead(sensorpress);   //Pressure sensor 1 sampling
totalpress = totalpress + samplepressure[i];
samplepressure2[i] = 2.5*analogRead(sensorpress2);   //Pressure sensor 2 sampling
totalpress2 = totalpress2 + samplepressure2[i];
ctroltime = 5;
i++;
if (micros()-(t0)>=Tm)
    tiempo=(micros()-t0);
    t0=micros();
    promediopress = (totalpress/i);           //pressure average for sensor 1
    promediopress2 = (totalpress2/i);         //pressure average for sensor 1
    pressinzero = promediopress-zero;         // zero adjustment for pressure sensor 1 -  sensor should be let with no pressure and the zero adjusted with the potentiometer
    pressinzero2 = promediopress2-zero2;      // zero adjustment for pressure sensor 2 -  sensor should be let with no pressure and the zero adjusted with the potentiometer
    P_sensor=(pressinzero2/1023)*5.0*4.8;     //conversion to pressure in cmH2O units.
    P_sensor_abs = abs(P_sensor);
    Serial.println(P_sensor_abs);
    epap=0.833*analogRead(analog_epap)+170;     //epap range from 4 cmH2O to 24 cmH2O (170-1023)
    ipap= 0.833*analogRead(analog_ipap)+170;    //ipap range from 4 cmH2O to 24 cmH2O (170-1023)
    if (epap>ipap)
        epap=ipap;        //epap value never can be higher than ipap value
    P_epap =(epap/1023.00)*5.0*4.8;       //conversion of epap pressure to cmH2O units
    P_ipap =(ipap/1023.00)*5.0*4.8;       //conversion of ipap pressure to cmH2O units
    porcentaje=100*(analogRead(analog_porcentaje)/1023.00);     //conversion of the cycling value to percentage (0% - 100%)
    flow=gain_flow*(pressinzero2-pressinzero);       // flow calculation from the pressure difference in the sensors
    if (flow>0)
        flow=100*sqrt(flow);        //flow+ linearization
        flow=-100*sqrt(-flow);      //flow- linearization
    int flow_out = map(flow,-20000,40000,0,255);    // rescaling flow values (0-255) for PWM control in pin 9
    analogWrite(analog_flow,flow_out);
    Input =pressinzero2;       //pressure of the transducer is the input for the PID controller
    Setpoint= consigna;       //setpoint for the PID controller
    myPID.Compute();          //myPID function call
    if (pressinzero2 < 250)
        Output=85;  //if pressure is very low it is because there is no patient, so output is settled very low
    analogWrite(analog,Output);                         //analog output 10 actuates the blower
    switchState = digitalRead(switchPin);             //adjust values switch readout
    switchModestate = digitalRead(SwitchMode);      //CPAP/BIPAP modes switch readout
    if (switchModestate == LOW && switchState == LOW) //CPAP mode is active when both switches are off
        if (lcdmodecpap ==1)
            myPID.SetTunings(Kp=0.12, Ki=0.75, Kd=0);       //PID values for CPAP mode
            lcd.setCursor(0,0);
            lcd.print("    CPAPmode    ");
            lcd.setCursor(0,1);
            lcd.print("Press      ");
            lcd.setCursor(11,1);
            lcd.print("CmH20");
            lcdmodecpap = 0;                       // no rewritting of the display until mode is switched again
        digitalWrite(led , LOW);
        lcd.setCursor(7,1);
        dtostrf(P_sensor_abs,2,0, P_sensorstring);
        lcd.print(String(P_sensorstring));
        consigna=ipap;                                //setpoint is adjusted by the ipap potentiometer
        lcdmodebipap=1;                              //allows switching to BIPAP mode
    if (switchModestate == LOW && switchState == HIGH)  //CPAP mode, adjustment of the parameters
        lcd.setCursor(0,0);
        lcd.print("    Set CPAP    ");
        lcd.setCursor(0,1);
        dtostrf(P_ipap,2,1, P_IPAPstring);
        lcd.print(String("IPAP " )+String(P_IPAPstring)+String("  CmH2O "));                //display the IPAP value
        lcdmodebipap=1;        //allows mode switching
        lcdmodecpap=1;        //allows mode switching
    if ( switchModestate == HIGH && switchState == LOW) //BIPAP mode is active, no parameters setup
        if (lcdmodebipap ==1)
            lcd.setCursor(0,0);
            lcd.print("BiPAPmode ");
            lcd.setCursor(12,0);
            lcd.print("%");
            lcd.setCursor(0,1);
            lcd.print("CmH20");
            lcdmodebipap=0;                    // LCD is just written once
        dtostrf(porcentaje,2,0,porcentajestring);                          //conversion of % to string
        lcd.setCursor(10,0);
        lcd.print(String(porcentajestring));
        lcd.setCursor(7,1);
        dtostrf(P_sensor_abs,2,0, P_sensorstring);                     //conversion of pressure to string
        Serial.println(P_sensorstring);
        if (autoipap==0)
            lcd.setCursor(13,0);
            dtostrf(ctroltime,1,0,timestring);                //conversion of time to string
            lcd.print(String(" -")+String(timestring));
    if (switchModestate == HIGH && switchState == HIGH)   //BIPAP mode, parameter adjustment
        lcd.setCursor(0,0);
        lcd.print(String("IPAP ")+String(P_IPAPstring)+String(" CmH2O    "));
        lcd.setCursor(0,1);
        dtostrf(P_epap,2,1, P_EPAPstring);
        lcd.print(String("EPAP ")+String(P_EPAPstring)+String(" CmH2O     "));
        lcdmodebipap=1;
        lcdmodecpap=1;
        flow_hp = mifiltroHP(flow,tiempo/1000000,RC_hp);                        //high-pass filtering flow signal
        flow_bp = mifiltroLP(flow_hp,tiempo/1000000,RC_lp);                    //low-pass filtering flow signal
        if (flow_bp>350 && switchModestate == HIGH && switchState == LOW) //detection of inspiratory flow > 350 when BIPAP mode is active
            myPID.SetTunings(Kp=0.1, Ki=0.45, Kd=0);                       //new PID parameters
            digitalWrite(led , HIGH);                                     //inspiration detection LED is active
            tiempoahora=millis();
            maximo = max(maximo, flow_bp);                                //maximum flow calculated
            if (maximo>1.05*flow_bp)
            {                                                           //detects a 5% flow reduction respect to the peak flow
                vmax =porcentaje/100*maximo;                           //calculation of the change point to EPAP (Vmax)
                if (flow_bp<vmax)
                    consigna = epap;                                //if the flow is lower than the change point, switches to EPAP mode
                myPID.SetTunings(Kp=0.65, Ki=0.2, Kd=0);     //new PID parameters
                consigna=ipap;      //if the flow is inspiratory but not 5% reduced, it maintains IPAP mode
    if (flow_bp<350 && switchModestate == HIGH && switchState == LOW)   //detect flow  < 350 in BIPAP mode
        digitalWrite(led , LOW);   //switch off inspiration led (flow<350 = expiration)
        if (millis()>(tiempoahora+(1000*ctroltime))&& millis() <= (tiempoahora+(1000*ctroltime)+1010)) //detects if the flow<350 time is greater than control time
            autoipap=1;                                 //autoIPAP mode activated
            consigna=ipap;                             //IPAP mode activated
            lcd.setCursor(14,0);
            lcd.print(String(F("ON")));
            if (millis()> tiempoahora+(1000*ctroltime)+1000)
                consigna=epap;
                lcd.print(String(timestring));
        {                                                 //no autoIPAP mode needed
            consigna=epap;
            autoipap=0;
        if (millis()> tiempoahora+(1000*ctroltime)+3000)
            tiempoahora=millis();   //time variable reset
        maximo=0;                        //maximum varibles reset
        vmax=0;
    if (switchModestate == LOW && switchState == LOW)   //CPAP mode active, maintains IPAP
        consigna=ipap;
    if (switchModestate == LOW && switchState == HIGH)  //CPAP mode active, setting parameters, maintains IPAP
        consigna=ipap;
    //variables reset
    promediopress=0;
    totalpress=0;
    promediopress2=0;
    totalpress2=0;
    i=0;
} //end of main program loop
double mifiltroHP(double dato,double dt,double RC)  //high-pass filtering of flow function
    double alpha = RC/(RC+dt);
    data_hp[1] = dato;
    // High Pass Filter
    data_filt_hp[1] = alpha * (data_filt_hp[0] + data_hp[1] - data_hp[0]);
    // Store the previous data in correct index
    data_hp[0] = data_hp[1];
    data_filt_hp[0] = data_filt_hp[1];
    return (data_filt_hp[1]);
double mifiltroLP(double dato,double dt,double RC) //low-pass filtering of flow function
    double alpha = dt/(RC+dt);
    data_lp[1] = dato;
    // low Pass Filter
    data_filt_lp[1] = alpha *data_lp[1]+(data_filt_lp[0]*(1-alpha));
    data_lp[0] = data_lp[1];
    data_filt_lp[0] = data_filt_lp[1];
    return (data_filt_lp[1]);
just tested with a different pot. Still no change. It fluctuates constantly between +-10 values
Load this program.
It prints A0 to A4 to the serial monitor.
See which input fluctuates, try with and without external supply.
Leo..
  Serial.print(analogRead(A0));
  Serial.print("\t");
  Serial.print(analogRead(A1));
  Serial.print("\t");
  Serial.print(analogRead(A2));
  Serial.print("\t");
  Serial.print(analogRead(A3));
  Serial.print("\t");
  Serial.println(analogRead(A4));
