I have a linear arrangement of 16 LEDs that I want to display a single-hued sequence from light to dark, with perceptually even increments from each light to the next. I have an excellent HSV to RGB routine for the Arduino, but when I linearly interpolate Value from 0 to 1, with constant hue and full saturation, most of the LEDs are bright, then there's a rapid fall-off to black at the very end of the sequence. I've found a C library that implements a perceptually uniform color space, called HSLuv, but it requires double-precision, so doesn't work properly on the Arduino. Can someone suggest either 1) How to do the value interpolation in HSV to get perceptual uniformity, or 2) A C library for a perceptually uniform color space that runs on Arduino? Thanks very much.
Look up gamma matching.
What kind of LEDs? How are they driven?
You may find that if using ws2811/12 etc or most other "NeoPixels" or using Arduino PWM pins, most of which are 8-bit resolution, that you may struggle to get the LEDs at the dimmer end to look like they have even increments.
I'm driving them using a pair of TLC5947 breakout boards. The HSV to RGB library I'm using
takes 8-bit saturation, 8-bit value, and 6*256 hues, output 8-bit R, G, and B values.
Elby:
The HSV to RGB library I'm using... output 8-bit R, G, and B values.
That's a shame, the chip is 12 bit.
Thanks, Mike, that was exactly what I needed! In case someone else needs this, the magic transformation is: pow(value, 2.2);
