aimmet
February 11, 2020, 2:40am
1
Hello all, I noticed when im trying to incrememnt j every 100 milliseconds using the Millis(); function, I realized j is not going up by 1. it just stays at 0. Whats the proper way to get the j to increment by 1 every 100 milliseconds? (Ill only post the part of the code where its happening to make reading more simple)
int i;
static int j = 0;
unsigned long interval = 100;
unsigned long previousMillis;
if (currentMillis - previousMillis >= interval)
j + 1;
if (j == 256)
j = 0;
for(i=0; i< 2; i++) {
strip.setPixelColor(i, j, j, j);
strip.show();
Serial.println(j);
vaj4088
February 11, 2020, 4:18am
3
Code snippets are not very helpful.
j+1 does not store its result anywhere. j++ does.
aimmet
February 13, 2020, 3:03am
4
I replaced it with both j+=1 and j== yet the value still remains zero. is it an issue with the millis counter?
gfvalvo
February 13, 2020, 3:06am
5
aimmet:
No, it's an issue with your code that we can't see. Show us this latest attempt.
vaj4088
February 13, 2020, 3:08am
6
No one said to try j==.
Please post good code that does not increment j. The whole thing please, not just a snippet. There is a good chance that the problem is in the part that we cannot see.
If this is in loop( ) you could likely be setting currentMillis( ) faster than 100mS.
You also have a block for maybe no good reason.
Why do you have so many spaces in your code?
aimmet
February 17, 2020, 3:47am
8
Sorry, heres the entire code, the j incrementing happens in rainbowcycle function
#define NUM_LEDS 3
#define BRIGHTNESS 75
#define PIN A0
//const int LED = A0;
const int Xs = 9;// pins the buttons are attached too
const int A = 4;//
const int B = 5;//
const int X = 8;//
const int Y = 7;//
const int DL = 6;//
int lastButtonState;
int buttonState;
double long aPressed; // values to insert millis value
double long bPressed;
double long xPressed;
double long yPressed;
double long dlPressed;
double long xsPressed;
byte R; // byte variables
byte G;
byte V;
int zero = 0;
unsigned long previousMillis = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
int a = digitalRead(A); //read digital inputs into integers
int b = digitalRead(B);
int x = digitalRead(X);
int y = digitalRead(Y);
int dl = digitalRead(DL);
int xs = analogRead(Xs); // 0-360-728
pinMode(A, INPUT);
pinMode(B, INPUT);
pinMode(X, INPUT);
pinMode(Y, INPUT);
pinMode(DL, INPUT);
pinMode(Xs, INPUT);
strip.setBrightness(BRIGHTNESS);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
byte Wheel = 0;
static int pattern = 0, lastReading;
double long Millis = millis();
//------------------------CONDITIONS BEGIN HERE------------------------------------------//
if (b == 0) //when pressed, turn on LEDs to RED
strip.clear();
bPressed = Millis;
strip.setPixelColor(2, 255, 0, 0);
strip.show();
strip.setPixelColor(1, 255, 0, 0);
strip.show();
strip.setPixelColor(0, 255, 0, 0);
strip.show();
strip.clear();
else if (30 + bPressed > Millis) // bPressed will be higher than Millis momentarily, execute color fade
uint16_t ib, jb;
for (jb = 255; jb > 0; jb--) {
for (ib = 0; ib < 2; ib++) {
strip.setPixelColor(ib, jb, 0, 0);
strip.show();
//Serial.println(j);
strip.clear();
if (x == 0)
xPressed = Millis;
for (int ixx=0; ixx<3; ixx++)
strip.setPixelColor(ixx, 0, 255, 255);
strip.show();
else if (30 + xPressed > Millis)
uint16_t ix, jx;
for (jx = 255; jx > 0; jx--) {
for (ix = 0; ix < 2; ix++) {
strip.setPixelColor(ix, 0, jx, jx);
strip.show();
strip.clear();
else if (x == 1)
for (int I = 0; I < 2; I++)
strip.setPixelColor(I, 0, 0, 0);
strip.show();
strip.clear();
if ((a && b && x && y && dl && (xs == 360 || xs == 361)) == 1)
rainbowCycle();
// functions for future use
void rainbowCycle() {
byte *c;
int i;
static int j = 0;
j++;
if (j == 256)
j = 0;
strip.show();
Serial.println(j);
byte * Wheel(byte WheelPos) {
static byte c[3];
if(WheelPos < 85) {
c[0]=WheelPos * 3;
c[1]=255 - WheelPos * 3;
c[2]=0;
} else if(WheelPos < 170) {
WheelPos -= 85;
c[0]=255 - WheelPos * 3;
c[1]=0;
c[2]=WheelPos * 3;
WheelPos -= 170;
c[0]=0;
c[1]=WheelPos * 3;
c[2]=255 - WheelPos * 3;
return c;
When do you ever update currentMillis?
aimmet
February 18, 2020, 4:52am
10
evanmars:
its at the top when defining the terms.
vaj4088
February 18, 2020, 4:59am
11
currentMillis is declared at the top and given an initial value but it never changes after that. Does it need to get a fresh value at the top of the loop() function?
