Value not defined
Can anyone help me it says that "VALUE" was not declared
declared is "results"
Welcome to the forum
Please post the full error message copied from the IDE using the button provided for the purpose
Put the error message and your code in separate sets of code tags rather than posting pictures of them
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
And it is true.
If you don’t think so, show where you declare it
The internet could. You found a bad example, or failed to follow slavishly any good example you worked with.
Here's what less than a minute of googling found
if(irrecv.decode(&results)) //this checks to see if a code has been received
    if(results.value == 0xC284) //if the button press equals the hex value 0xC284
        //do something useful here
    irrecv.resume(); //receive the next value
which is the basic pattern for looking for , and receiving (maybe) a result from the library.
HTH and be careful out there.
a7
