values problem
Hi
I am programming a certain board. My values come approximately 3 times high than the actual ones .need help in programming. I give an example.
  1. My values should come 14 but they come 40
  2. My values should come 18 but they come 56.
so how to include this factor in arduino programming so that it reads approx.14 instead of 40 and approx 18 instead of 56.
thanks
What board are you using?
and upload your code please.
The value of the ASCII character ‘8’ is 5610, or 0x38.
Coincidence?
If your values are consistently higher than what you expect by ~3, to me that says:
  • Your expectations are wrong
  • Your sensor is stuffed
  • Your calculations converting the raw data into values are wrong
In any case, scaling the value back to what you want it to be, is not the right solution imo.
That said, you could use map maybe?
Which board ?
What program ?
Where do these values come from ?
How do you know what the values should be ?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
