Hello, i have built a temperature controller using controllino, ds18b20 and nextion HMI and am having problems when i set temeprature it resets other variables. Any suggestions are welcome.
#define Output_J2 CONTROLLINO_R1
#define Output_J3 CONTROLLINO_R2
#define Output_P CONTROLLINO_R3
#define Error CONTROLLINO_IN0
#include "EasyNextionLibrary.h"
EasyNex myNex(Serial2);
//temp sonde
#include <SPI.h>
#include <Controllino.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS1 42
OneWire oneWire1(ONE_WIRE_BUS1);
DallasTemperature sensor1(&oneWire1);
#define ONE_WIRE_BUS2 43
OneWire oneWire2(ONE_WIRE_BUS2);
DallasTemperature sensor2(&oneWire2);
#define ONE_WIRE_BUS3 44
OneWire oneWire3(ONE_WIRE_BUS3);
DallasTemperature sensor3(&oneWire3);
#define ONE_WIRE_BUSP 45
OneWire oneWireP(ONE_WIRE_BUSP);
DallasTemperature sensorP(&oneWireP);
const long interval = 2000;
unsigned long previousMillis = 0;
bool napaka=0;
//reg pisarna
int poz=0;
bool aut=0;
double SetpointP, tempP;
//reg J1
long time1_start;
long time1_stop;
uint32_t time1_set;
uint32_t temp1_1;
uint32_t temp1_2;
bool state1 = 0;
double Setpoint1,temp1, temp1_old, temp1_new;
//reg J2
long time2_start;
long time2_stop;
uint32_t time2_set;
uint32_t temp2_1;
uint32_t temp2_2;
bool state2 = 0;
double Setpoint2, temp2, temp2_old, temp2_new;
//ref J3
long time3_start;
long time3_stop;
uint32_t time3_set;
uint32_t temp3_1;
uint32_t temp3_2;
bool state3 = 0;
double Setpoint3,temp3, temp3_old, temp3_new;
bool on1=0;
bool on2=0;
bool on3=0;
//time conversion to s
long (time_to_s()){
long seconds;
seconds=(Controllino_GetWeekDay()+1)*86400 + Controllino_GetHour()*3600 + Controllino_GetMinute()*60 + Controllino_GetSecond();
return seconds;
void setup(void)
Controllino_RTC_init(0);
sensor1.begin();
sensor1.setResolution(9);
sensor2.begin();
sensor2.setResolution(9);
sensor3.begin();
sensor3.setResolution(9);
sensorP.begin();
sensorP.setResolution(9);
myNex.begin(9600);
pinMode(Error, INPUT_PULLUP);
pinMode(Output_J1, OUTPUT);
pinMode(Output_J2, OUTPUT);
pinMode(Output_J3, OUTPUT);;
pinMode(Output_P, OUTPUT);
attachInterrupt(digitalPinToInterrupt(Error), error_, FALLING);
void loop(void)
while(Serial2.available()){
myNex.NextionListen();
meritve();
if(on1 == 1){
reg_J1();
if(on2 == 1){
reg_J2();
if(on3 == 1){
reg_J3();
if(aut == 1){
reg_P();
if(napaka==1){
myNex.writeNum("error.val",1);
void meritve()
if (currentMillis - previousMillis >= interval) {
sensor1.requestTemperatures();
temp1_new=sensor1.getTempCByIndex(0);
if(temp1_new == -127){
temp1=temp1_old;
}else{
temp1=temp1_new;
temp1_old=temp1_new;
sensor2.requestTemperatures();
temp2_new=sensor2.getTempCByIndex(0);
if(temp2_new == -127){
temp2=temp2_old;
}else{
temp2=temp2_new;
temp2_old=temp2_new;
sensor3.requestTemperatures();
temp3_new=sensor3.getTempCByIndex(0);
if(temp3_new == -127){
temp3=temp3_old;
}else{
temp3=temp3_new;
temp3_old=temp3_new;
sensorP.requestTemperatures();
tempP=sensorP.getTempCByIndex(0);
if(tempP==-127.0){
tempP=35;
myNex.writeNum("x1.val",temp1*10);
myNex.writeNum("x3.val",temp2*10);
myNex.writeNum("x5.val",temp3*10);
myNex.writeNum("x7.val",tempP*10);
Serial.print(Setpoint1);
Serial.print(" , ");
Serial.print(temp1);
Serial.print("...");
Serial.print(Setpoint2);
Serial.print(temp2);
Serial.print(Setpoint3);
Serial.print(temp3);
void reg_J1(){
if(state1==1){
if(temp1 >= Setpoint1){
time1_stop=long(time_to_s())+long(time1_set)*3600;
state1=0;
if(time_to_s()==time1_stop){
Setpoint1=temp1_2;
myNex.writeNum("Tset1.val",Setpoint1*10);
if(Setpoint1 <= temp1){
digitalWrite(Output_J1, LOW);
}else{
digitalWrite(Output_J1, HIGH);
void reg_J2(){
if(state2==1){
if(temp2 >= Setpoint2){
time2_stop=long(time_to_s())+long(time2_set)*3600;
state2=0;
if(time_to_s()==time2_stop){
Setpoint2=temp2_2;
myNex.writeNum("x2.val",Setpoint2*10);
if(Setpoint2 <= temp2){
digitalWrite(Output_J2, LOW);
}else{
digitalWrite(Output_J2, HIGH);
void reg_J3(){
if(state3==1){
if(temp3 >= Setpoint3){
time3_stop=long(time_to_s())+long(time3_set)*3600;
state3=0;
if(time_to_s()==time3_stop){
Setpoint3=temp3_2;
myNex.writeNum("x4.val",Setpoint3*10);
if(Setpoint3 <= temp3){
digitalWrite(Output_J3, LOW);
}else{
digitalWrite(Output_J3, HIGH);
void reg_P(){
if(SetpointP <= tempP){
digitalWrite(Output_P, LOW);
}else{
digitalWrite(Output_P, HIGH);
Serial.print(SetpointP);
Serial.print(tempP);
void trigger1(){
temp1_1=myNex.readNumber("Temp1_1.val")/10;
temp1_2=myNex.readNumber("Temp1_2.val")/10;
time1_set=myNex.readNumber("Time1.val");
Setpoint1=temp1_1;
state1=1;
on1=1;
void trigger2(){
Setpoint1=0;
on1=0;
void trigger3(){
temp2_1=myNex.readNumber("Temp2_1.val")/10;
temp2_2=myNex.readNumber("Temp2_2.val")/10;
time2_set=myNex.readNumber("Time2.val");
Setpoint2=temp2_1;
state2=1;
on2=1;
void trigger4(){
Setpoint2=0;
on2=0;
void trigger5(){
temp3_1=myNex.readNumber("Temp3_1.val")/10;
temp3_2=myNex.readNumber("Temp3_2.val")/10;
time3_set=myNex.readNumber("Time3.val");
Setpoint3=temp3_1;
state3=1;
on3=1;
void trigger6(){
Setpoint3=0;
on3=0;
void trigger7(){
poz=myNex.readNumber("p0.pic");
Serial.println(myNex.readNumber("p0.pic"));
//Serial.println(poz);
switch(myNex.readNumber("p0.pic")){
case 5: digitalWrite(Output_P, HIGH);aut=0;
case 6: digitalWrite(Output_P, LOW);aut=0;
case 7: aut=1;
SetpointP=myNex.readNumber("x6.val")/10;
void error_(){
napaka=1;
Serial.println("error");
void trigger8(){
napaka=0;
