Vanch VM-5GA Uhf Rfid Reader
I pick up one of these at https://www.alibaba.com/product-detail/UHF-RFID-reader-module-for-arduino_60655915507.html?spm=a2700.7724838.2017115.96.3acb596e0SZTWV
I am using Arduino Mega the reader is on serial2 I can read EPC memory but I am having no luck in reading user memory! Here is the code:
//byte readOnce[] = {0xBB, 0x00, 0x22, 0x00, 0x00, 0x22, 0x7E};
byte readOnce[] = {0xBB, 0x00, 0x39, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x4D, 0x7E};
byte container[1024]; //A buff container to cnotain received bytes
bool isDoorOpen = false;
int switchPin = 8;//The pin used for door state input.
//byte tt[] ={0xBB,0x02,0x22,0x00,0x02,0x12,0x34,0x99,0x88,0x56,0x41,0xEF,0x7E};
//byte tad[] = {0xBB, 0x02,0x22,0x00,0x11,0xC9,0x34,0x00,0x30,0x75,0x1F,0xEB,0x70,0x5C,0x59,0x04,0xE3,0xD5,0x0D,0x70,0x3A,0x76,0xEF,0x7E};
  Serial2.begin(115200);
  pinMode(switchPin, INPUT);
  Serial2.setTimeout(2000);
  onDoorOpen();
  int doorState = digitalRead(switchPin);
  if (doorState == HIGH) {
    onDoorOpen();
void onDoorOpen() {
  Serial2.write(readOnce, sizeof(readOnce));
  delay(100);
  int len = Serial2.available();
  if (len > 0) {
    Serial2.readBytes(container, len);
    frameParse(container, len);
void extractEPC(byte frm[], int le) {
  if (frm[1] == 0x02 && frm[2] == 0x22) {
    int frmLen = le;
    int epcLen = frmLen - 8 - 4;
    byte epc[epcLen];
    int ind = 0;
    Serial.write(42);    Serial.write(42);    Serial.write(42);
    for (int i = 8; i < epcLen + 8; i++) {
      epc[ind++] = frm[i];
      //  Serial.write(frm[i]);
      Serial.print(frm[i]);    //GET NUMBER HERE!!!!!!!!!!!!!!
      Serial.write(32);
    Serial.write(10);
void frameParse(byte dataCom[], int lent) {
  //Serial.write(98);
  bool frameBeginFlag = false;
  bool frameEndFlag = true;
  long frameLength;   //实际接收到的数据长度
  long strNum;      //实际接收到的帧个数
  byte strBuff[4096];
  int n = lent;
  for (int j = 0; j < n; j++)
    if (frameBeginFlag)
      strBuff[strNum] = dataCom[j];
      if (strNum == 4)
        frameLength = 256 * strBuff[3] + strBuff[4];
        if (frameLength > 3072)
          continue;
      else if (strNum == frameLength + 6 && strBuff[strNum] == 0x7E)
        int checksum = 0;
        for (int i = 1; i < strNum - 1; i++)
          checksum += strBuff[i];
        checksum = checksum % 256;
        if (checksum != strBuff[strNum - 1])
          // Console.WriteLine("ERROR FRAME, checksum is not right!");
          continue;
        //Send out
        byte packet[strNum + 1];
        for (int i = 0; i <= strNum; i++)
          packet[i] = strBuff[i];
        extractEPC(packet, strNum + 1);
      else if (strNum == frameLength + 6 && strBuff[strNum] != 0x7E)
        // Console.WriteLine("ERROR FRAME, cannot get FRAME_END when extends frameLength");
        continue;
      strNum++;
    else if (dataCom[j] == 0xBB && frameBeginFlag != true)
      strNum = 0;
      frameBeginFlag = true;
      frameEndFlag = false;
      strNum = 1;
The data sheet is attached.
I am trying to read from the User memory so I tried to change:
to: byte readOnce[] = {0xBB, 0x00, 0x39, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x4D, 0x7E};
it does read from the user data but not all of it. I would be grateful for any help as to why.
Thanks, Chris
VM-5GA development handbook-VANCH.doc (912 KB)
If you read the description of command 0x39, it mentions you need to send the set select parameter command (0x0C) before you send this command.
Didn't read any further...
