Variable assignment does not “stick.”
Dear Arduino community,
[Arduino Uno Rev 3, Arduino IDE 1.0.5]
I have a sketch (below) that is intended to be a countdown timer. The timer takes advantage of the millis() function to count down a period of time which is assigned to a variable called “interval.” The interval is set using input from a 4-key keypad. The serial monitor shows what the variable is assigned to.
When the sketch is uploaded and I press a key on the keypad, the serial monitor correctly shows the assigned variable, but only temporarily. On the next pass through the sketch, it is re-assigned to a different value, and I can’t figure out why. I need the assigned variable (interval) to keep its value until the timer is up.
For example, the serial monitor will show:
The timer interval is set to 20 seconds. //I don’t know where this value is coming from, but it persists even after powerdown
The timer interval is set to 60 seconds. //I hit button 3 on the keypad
The timer interval is set to 20 seconds. //but now it goes back to its previous value
The timer interval is set to 40 seconds. //I hit button 2 on the keypad
The timer interval is set to 20 seconds. //but it goes back to 20 again!
etc.
If someone can see why the variable “interval” is not keeping its value, please elaborate. Thanks for reading!
 This sketch is a countdown timer that takes advantage of the millis() function.
 The timer interval is set using a keypad. When the current millis exceeds the
 set interval, then an alarm goes off.
Circuit utilizes a 4-key keypad (5 wires--one for each key plus GND) in a breadboard.
Arduino GND is connected to ground wire on keypad and the pins 2, 3, 4, and 5
on the Arduino are connected to the wires on the keypad.
      //start serial connection
      //configure pins 2,3,4 and 5 as an inputs and enable the internal pull-up resistor
      pinMode(2, INPUT_PULLUP);
      pinMode(3, INPUT_PULLUP);
      pinMode(4, INPUT_PULLUP);
      pinMode(5, INPUT_PULLUP);
      int ledPin=13;
      pinMode(ledPin, OUTPUT);
      long interval;  //long is used here because it will be compared to millis, another long.
      int i=0;  //counter variable in for loop
      int ledPin=13;
      //read the pushbutton value and assign it to a variable
      int sensorVal2 = digitalRead(2);  //sensorValX is which button (1-4) on the keypad is pressed
      int sensorVal3 = digitalRead(3);
      int sensorVal4 = digitalRead(4);
      int sensorVal1 = digitalRead(5);
      long currentMillis = millis();
            //Assign the keypad inputs to an interval time for the timer.
            if (sensorVal1==LOW)  //input pullup inverts the logic.  Closed circuit is low and open is high.
            {interval=20000;  //20 seconds
            if (sensorVal2==LOW)
            {interval=40000;  //40 seconds
            if (sensorVal3==LOW)
            {interval=60000;  //60 seconds
            if (sensorVal4==LOW)
            {interval=80000;  //80 seconds
      Serial.print("The timer interval is set to "); //serial monitor shows what the timer is set to
      Serial.print(interval/1000);
      Serial.println(" seconds.");
      //Serial.println(currentMillis);
      //Check to see if time is up!
      if(currentMillis > interval) //If true, trigger the alarm
            for(i=0; i<4; i++)
                digitalWrite(ledPin, HIGH);
                delay (1000);
                digitalWrite(ledPin, LOW);
                delay (1000);
       delay(1000);  //The delay slows down the serial monitor updates but does not affect the millis() timer
Try qualifying it with "static"
Yes, it works.
STATIC is the answer.
Thanks, AWOL!
