Variable assignment inside if( here ) while comparing
When I do this:
if (i_a=3)
I usually want to do
if (i_a==3)
Common mistake, I suppose.
But sometimes it makes sense something like this:
if(i_a=test()==3)
Where test() is just
int test(){
  return 5;
looks like i_a becomes 0 ou 1 (false ou true?) according to the == result.
But :slight_smile: if I do
if((i_a=test())==3)
It seems to do both things: assigns test() return to i_a and compares test() return (or i_a) to 3.
I have done several tests and it seems to work smoothly.
Do this make sense?
Thanks
Martins
if(i_a=test()==3)
The result of the assignment “i_a = test ()” will evaluate to either true (non-zero) or false (zero).
Neither true nor false will be equal to 3
Yes, I'll use parenthesis rather than remember the more arcane Rules of Precedence. It makes it at least appear that you've thought about it.
You can also look at Assignment operators | Microsoft Docs under “Result of Assignment Operators” for another point of view.
This:
if(i_a=test()==3)
Is equivalent to:
if(i_a=( test()==3) )
So this statement is correct:
“looks like i_a becomes 0 ou 1 (false ou true?) according to the == result.”
THX @6V6gt. While I was over getting my first vaccine shot I kept struggling with all these cases. I wrote this on an online C/C++ compiler. Handy for no Arduino attached.
# include <stdio.h>
int i_a;
int test()
    return 3;
int main()
    printf("Hello World\n");
    if ( i_a = test()  == 3 )    printf("\n (  =   ==  )   is true, i_a is %d\n", i_a);
    if ( i_a = (test() == 3))    printf("\n (  = ( == ))   is true, i_a is %d\n", i_a);
    if ((i_a = test()) == 3 )    printf("\n (( = ) ==  )   is true, i_a is %d\n", i_a);
    return 0;
All three expressions are true if test returns 3. All are false otherwise. The appearance at the bottom of the precedence chart of the assignment operators spun me around a bit but explains it of course. If you add the fact that the assignment statement returns the assigned value. Then add right-to-left and you can figure how things like
a = b = c;
are working.
I also use ( ) as mentioned earlier either to make sure I get what I want or as a courtesy to those who might read my code or even myself one day later. Although it would be nice to have a brain with sufficient number of cooperating cells that could just confidently omit any unnecessary parentheses.
Output
Hello World
 (  =   ==  )   is true, i_a is 1
 (  = ( == ))   is true, i_a is 1
 (( = ) ==  )   is true, i_a is 3
...Program finished with exit code
Press ENTER to exit console.
a7
I tend also to use parentheses to add clarity to a compound expression and usually try to steer clear of relying on mysterious side effects of action. An “if” condition statement is not really the best place to pack in a load of assignments.
I will sometimes do this, though, to manage the wrap around and increment of a loop counter variable, say when handling the multiplexing of a display:
if ( ++i >= arraySize ) i = 0 ;
