Problem solved (missing brackets), Thanks for the input and help
I have a program which the variable is changing when it should not change. I am guessing that I am overwriting it in memory. Any help or ideas will be appreciated.
The complete code is listed at the bottom of this post.
Here is the piece which is causing problems:else
Serial.print("Distance before = ");
Serial.println(distance);
if (distance >= startdistance) {
for (int i = 0; i <= NUM_LEDS; i++) {
leds = CRGB(0, 0, 0);
- Serial.print("Distance After= ");*
- Serial.println(distance);*
// Serial.println(" Out Of Range"); - FastLED.show();*
- delay(50);*
distance is an int variable that currently is assigned a value.
Here is the output from the Serial.print
Distance before = 548 (before entering the if and for loop)
Distance After= 0 (after the if and for loop)
Changing the values of the leds *= CRGB(0, 0, 0); line changes the value of distance. *
Complete Code listing:
* Garage Parking Sensor - Published By Bob Torrence edited by Me
#include <NewPing.h>
#include <FastLED.h>
// defining the pins
//#define FASTLED_ESP8266_NODEMCU_PIN_ORDER
#define LED_PIN 3
#define NUM_LEDS 22
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
const int trigPin = 12;
const int echoPin = 13;
NewPing sonar(trigPin, echoPin, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
// defining variables
CRGB leds[NUM_LEDS];
int distance;
int stopdistance=48; //parking position from sensor (CENTIMETERS)
int startdistance=150; //distance from sensor to begin scan as car pulls in(CENTIMETERS)
//int increment=((startdistance-stopdistance)/15);
int increment=10;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
Serial.begin(9600); // Starts the serial communication
distance = stopdistance + increment *50;
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
// Serial.print("Ping: ");
// Serial.print(sonar.ping_in()); // Send ping, get distance in cm and print result (0 = outside set distance range)
// Serial.println(" Inches");
delay(2000);
//distance = sonar.ping_in();
if (distance <= stopdistance){ //Red
* for (int i = 0; i <= NUM_LEDS; i++) {
_ leds = CRGB ( 255, 0, 0);
FastLED.show();
delay(50);
Serial.print("stopdistance = ");
Serial.println(stopdistance);
Serial.print(distance);
Serial.println(" Stop");*_
if ((distance >= stopdistance+increment2) && (distance < stopdistance+increment3)) {
* for (int i = NUM_LEDS/2-1 ;i <= NUM_LEDS/2+1; i++) {
_ leds = CRGB ( 255, 255, 0);
FastLED.show();
delay(50);
Serial.println("2nd Stop");
else_
_if ((distance >= stopdistance+increment3) && (distance < stopdistance+increment4)){_
for (int i = NUM_LEDS/2-2 ;i <= NUM_LEDS/2+2; i++) {
FastLED.show();
delay(50);
Serial.println("3rd Stop");
else_
_if (distance >= (stopdistance+increment4) && (distance < stopdistance+increment5)){_
for (int i = NUM_LEDS/2-3 ;i <= NUM_LEDS/2+3; i++) {
FastLED.show();
delay(50);
Serial.println("4th Stop");
else_
_if (distance >= (stopdistance+increment5)&& (distance < stopdistance+increment6)){_
for (int i = NUM_LEDS/2-4 ;i <= NUM_LEDS/2+4; i++) {
FastLED.show();
delay(50);
Serial.println("5th Stop");
else_
_if (distance <= (stopdistance+increment6)&& (distance < stopdistance+increment7)){_
for (int i = NUM_LEDS/2-5 ;i <= NUM_LEDS/2+5; i++) {*
leds = CRGB ( 255, 255, 0); }
* FastLED.show();*
* delay(50);*
* Serial.println("6th Stop");*
if (distance <= (stopdistance+increment7)&& (distance < stopdistance+increment8)){
* for (int i = NUM_LEDS/2-6 ;i <= NUM_LEDS/2+6; i++) {
}*_
* FastLED.show();*
* delay(50);*
* Serial.println("7th Stop");*
if (distance <= (stopdistance+increment8)&& (distance < stopdistance+increment9)){
* for (int i = NUM_LEDS/2-7 ;i <= NUM_LEDS/2+7; i++) {
_ }*_
* FastLED.show();*
* delay(50);*
* Serial.println("8th Stop");*
if (distance <= (stopdistance+increment9)&& (distance < stopdistance+increment10)){
* for (int i = NUM_LEDS/2-8 ;i <= NUM_LEDS/2+8; i++) {
FastLED.show();
delay(50);
Serial.println("9th Stop");
else_
_if (distance <= (stopdistance+increment10)&& (distance < stopdistance+increment11)){_
for (int i = NUM_LEDS/2-9 ;i <= NUM_LEDS/2+9; i++) {
FastLED.show();
delay(50);
Serial.println("10th Stop");
else _
_if (distance <= (stopdistance+increment11)&& (distance < stopdistance+increment12)){_
for (int i = NUM_LEDS/2-10 ;i <= NUM_LEDS/2+10; i++) {
_ leds = CRGB ( 255, 255,0);
FastLED.show();
delay(50);
Serial.println("11th Stop");
else_
_if (distance >= (stopdistance) && (distance <= stopdistance + increment13)){ // all green
* for (int i = NUM_LEDS/2-11 ;i <= NUM_LEDS/2+11; i++) {*
leds = CRGB(255, 255, 0);
Serial.println("12th Stop");
FastLED.show();
delay(50);
if (distance >= startdistance) { _
_ leds = CRGB(0, 0, 0);
FastLED.show();
delay(50);
}*_
