variable declaration just unsigned and no data type
In native c, if a variable is declared as just static unsigned value without a type, can it contain both numbers and letters i.e. for hex values?
Thanks
It's an 'unsigned int'.
ultrasonicbananna: Hi,
Thanks
It can store whatever you like, just as long as what you like occupies no more than sixteen bits.
Thanks
There are no untyped variables in C. You get a default type as OldSteve said.
I'm just wondering about this:-
Maybe I'm misunderstanding you, but.... When storing a hex value, a combination of letters and numbers isn't stored. ie When you set a variable to 0x05 (hex), exactly the same thing is stored as if you set it to 5 (decimal). The "x" in the hex value isn't placed into the variable. It's just a way of representing it for humans. Assuming an 8-bit variable, in both cases, the variable will hold 0b00000101.
OldSteve is right. It all comes down to how YOU interpret the value. Although the Arduino IDE (/underneath code) has some preferences on how to interpret a variable (for example, a char as a variable with a ASCII representation of a character) it's not fixed.
For example, this will work just fine
unsigned int myInt = 'm';
Serial.print( (char)myInt );
I casted the unsigned int to a char because the default action of calling Serial.print() when using a int is to print the numeric value. The default action of calling Serial.print() with a char is to print the ASCII representation of that variable.
