variable declaration using SD using config.ini
Hi I am wanting to use a SD card and set variable pins from it. I have this working or thought I did
as an example I would
in the setup read values into variables and then want to use the Lcd library I would
LiquidCrystal lcd(rs.toInt(), en.toInt(), d4.toInt(), d5.toInt(), d6.toInt(), d7.toInt());
but when I try to use in the loop section I get a
'LCD' not declared in this scope.
Is this possible or do I have to declare in the top and have the pins hard coded?
thanks
Jasemilly
(deleted)
You will need to declare a pointer to the LiquidCrystal instance, initialized to null.
LiquidCrystal *pLCD = NULL;
In setup(), after you get the values, you will add:
  pLCD = new LiquidCrystal(rs.toInt(), en.toInt(), d4.toInt(), d5.toInt(), d6.toInt(), d7.toInt());
Then, everywhere where you currently have “LCD.”, you will have to use “pLCD->”
Thank you PaulS that worked
