variable declation
In the following sketch why does the third line not assign to pin A0
int ledPin = 9; // LED connected to digital pin 9
int analogPin = 3; // potentiometer connected to analog pin 3
int val = 0; // variable to store the read value
pinMode(ledPin, OUTPUT); // sets the pin as output
val = analogRead(analogPin); // read the input pin
analogWrite(ledPin, val / 4); // analogRead values go from 0 to 1023, analogWrite values from 0 to 255
The third line seems to be declaring an integer variable "val". Nothing to do with any pins.
Try using "A0" instead of "3".
