Variable delay in pinging w5500
I had asked this question last week on WizNet forum but couldn't get any answer.
Hope someone has an idea about it here.
I have a custom design using W5500. When I ping it using my PC, generally the ping takes <1ms, but every once in a while it takes more time (~5ms to 15ms) although I am not doing anything else on the W5500 at the moment.
It is connected directly to the PC, there is no switch involved. Most of the time ping time is less than 1ms. But occasionally it is more.
I checked with a w5500 module I bought online, and I did not see this issue on that.
I am pasting a part of a long ping here for sample. I have truncated some part from top and bottom just to show the relevant portion.
Reply from 192.168.1.101: bytes=32 time<1ms TTL=128
**Reply from 192.168.1.101: bytes=32 time=7ms TTL=128**
**Reply from 192.168.1.101: bytes=32 time=11ms TTL=128**
**Reply from 192.168.1.101: bytes=32 time=22ms TTL=128**
**Reply from 192.168.1.101: bytes=32 time=2ms TTL=128**
Reply from 192.168.1.101: bytes=32 time=1ms TTL=128
**Reply from 192.168.1.101: bytes=32 time=4ms TTL=128**
I would install Wireshark on your PC, then see if there is anything happening on your short network when the delayed ping occurs. It could be on the PC end when sending or the 5500 end. What processor are you using along with the 5500? Could anything on your custom design be happening such that there might be a delay in processing a ping request?
Thanks,
I will check that with wirehshark.
I have atmega2560 on my custom board.
When I run the same code on Mega2560 with a w5500 module with the same PC, there is no such delay.
Worth looking to see if the PC is also showing any ethernet errors of any kind, that might suggest anything from a wiring problem (eg. poor connection) to RFI interference.
I checked with Wireshark, there are no retransmissions but I still have occasional long delay times.
I used following filters
tcp.analysis.lost_segment
tcp.analysis.retransmission
Did you check for any errors on the Ethernet?
