Hello,
I'd like to use my arduino to control my water well. We have low producing well with a holding tank. There is a float in the tank. I am currently using an arduino to send signal power to a relay that is spliced into my float wire (110V). It sends signal to the relay for 35 seconds while powering a green LED, my well runs dry, it shuts off for 10 minutes to allow my well to fill back up while powering a red LED. Downside of this system, is the arduino loop is running constantly, even if the float is not sending signal because the tank is full.
I'd like to expand on this later, but for right now, this is what im trying to achieve:
Using a potmeter, vary the time that the water well pump (and green LED) is on, once the timer runs out, the water well pump (and red LED) shut off for a set time determined by the second potmeter.
Id like to have both the adjustable countdown on a display. Will this require 2 displays?
I understand the theory of a potmeter used an analog signal, but no idea how to set different times for different values.
Ideally what id like to see in the end, is figure out how to read the power from the 110V float, and have that signal start a the loop of the variable duty cycle controller.
Im new to all of this. This is my first arduino project, happy with what ive been able to achieve and learn so far, but I'd like to make it a bit more fancy to see how in depth my arduino learning will be. This will help my water well pump($2,300) last longer (not pumping when theres no water), and really make a difference in my electricity bill.
