I’m having the weirdest problem with this program, and it’s extremely intermittent. So, I wrote a program to time how long it takes between the Arduino setting a super pin 13 LED and the human smashing down on a large pulled-down microswitch. Sort of a response timer, if you will, actually for a small-scale study I’m doing. The communication protocol is that, in the setup()
section, it spits out a “124”. When you press the pin 2 switch, the LED blinks 3 times and spits out “246” a second later. It then waits a pseudo-random amount from 2,000 to 10,000 milliseconds. After it’s up, interrupt 0 (pin 2, the switch) is set to trigger stopTimer
on RISING
. stopTimer
does one thing: sets killLoop
to true
. The while loop that has, in the meantime, been incrementing cyclesGlobal
once per millisecond, on the condition that cyclesGlobal < 1000 && killLoop != true
, meaning that pressing the switch kills the loop. After the loop either times out or is killed, it does a phoneHome()
sending a “135” to serial then reading out cyclesGlobal
. It runs a cleanup()
function which resets all the variables and detaches the interrupt. You can then press the switch again and restart the test. This is where things get weird. It spits a zero for a response time and completely skips the while loop. A debug if
checking on the same things as the loop runs, and it starts to tell me that an int
at 0 is not < 1000
. I’ve used both the Arduino IDE and HyperTerminal to listen to the serial (tempted to say cereal). Interestingly enough, it seems to reset upon connecting either monitor, proven by seeing a 124. I’ve even tried to force a reset through the program by jumpering pin 4 and RESET then trying different HIGH/LOW combinations. It would either constantly reset, stay in a reset, or not reset when I wanted. Lovely. Any ideas? Thanks so much for listening to my noobdom. I’ll post the code here (sorry, no nice colored formatting):
int lightPin = 13;
int buttonPin = 2;
int resetPin = 4;
static int cyclesGlobal = 0;
boolean isTesting = false;
boolean killLoop = false;
pinMode(lightPin, OUTPUT);
pinMode(buttonPin, INPUT);
pinMode(resetPin, OUTPUT);
digitalWrite(resetPin, HIGH);
Serial.println(124, DEC);
void reset()
digitalWrite(resetPin, LOW);
void erraticSignal()
digitalWrite(lightPin, HIGH);
delay(200);
digitalWrite(lightPin, LOW);
delay(100);
delay(200);
delay(100);
delay(200);
void alertStart()
Serial.println(246, DEC);
void lightOn()
void lightOff()
void startTiming()
delay(200);
while(cyclesGlobal < 10000 && killLoop != true)
delay(1);
cyclesGlobal++;
phoneHome();
lightOff();
cleanup();
void phoneHome()
Serial.print(135, DEC);
delay(100);
Serial.println(cyclesGlobal);
void stopTimer()
killLoop = true;
void cleanup()
lightOff();
detachInterrupt(0);
cyclesGlobal = 0;
isTesting = false;
killLoop = false;
reset();
void spill()
//debug
/* Serial.println("Now spilling the beans...");
delay(200);
Serial.print("lightPin: ");
delay(200);
Serial.println(lightPin);
delay(200);
Serial.print("buttonPin: ");
delay(200);
Serial.println(buttonPin);
delay(200);
Serial.print("cyclesGlobal: ");
delay(200);
delay(200);
Serial.print("isTesting: ");
delay(200);
Serial.println(int(isTesting));
delay(200); */
Serial.print("killLoop: ");
delay(200);
Serial.println(long(killLoop));
delay(200);
void startTesting()
isTesting = true;
startWaiting();
attachInterrupt(0, stopTimer, RISING);
lightOn();
startTiming();
void startWaiting()
delay(random(2000, 10000));
if (digitalRead(buttonPin) == HIGH)
if (isTesting != true)
erraticSignal();
alertStart();
startTesting();
/me
