I'm using an Arduino to control a stepper motor. The stepper motor needs to oscillate in a sine wave motion. My code attached has an array i made in matlab and copied into the arduino ide which sets the number of steps and pulse timing. The overall motion works but the timing of the step pulses are off and results in an oscillating frequency other than what was desired. The method im using is to digitalwrite high and low a pin which sends a step pulse to move the motor. After testing i found out this isnt the best method as i need to pulse at relatively high frequencies. I looked into timing on an arduino but couldnt understand how to use the different timers to get a reliable pulsing signal at the frequencies i need.
Would appreciate any help.
Thanks
// Define stepper motor connections and steps per revolution:
#define dirPin 10
#define stepPin 9
const long int frame[] = {1273,1273,1273,1274,1274,1274,1275,1276,1276,1277,1278,1279,1280,1281,1282,1283,1284,1286,1287,1289,1291,1293,1294,1296,1298,1301,1303,1305,1308,1310,1313,1316,1319,1322,1325,1328,1331,1335,1338,1342,1346,1350,1354,1358,1363,1367,1372,1377,1381,1387,1392,1397,1403,1409,1415,1421,1427,1434,1441,1448,1455,1463,1470,1478,1486,1495,1504,1513,1522,1532,1542,1552,1563,1574,1586,1598,1610,1623,1636,1650,1664,1679,1695,1711,1728,1745,1764,1783,1803,1824,1846,1869,1893,1918,1945,1973,2003,2035,2068,2104,2141,2182,2225,2271,2321,2374,2432,2495,2564,2640,2724,2817,2922,3040,3175,3331,3514,3734,4003,4345,4796,5432,6431,8363,20145,-20145,-8363,-6431,-5432,-4796,-4345,-4003,-3734,-3514,-3331,-3175,-3040,-2922,-2817,-2724,-2640,-2564,-2495,-2432,-2374,-2321,-2271,-2225,-2182,-2141,-2104,-2068,-2035,-2003,-1973,-1945,-1918,-1893,-1869,-1846,-1824,-1803,-1783,-1764,-1745,-1728,-1711,-1695,-1679,-1664,-1650,-1636,-1623,-1610,-1598,-1586,-1574,-1563,-1552,-1542,-1532,-1522,-1513,-1504,-1495,-1486,-1478,-1470,-1463,-1455,-1448,-1441,-1434,-1427,-1421,-1415,-1409,-1403,-1397,-1392,-1387,-1381,-1377,-1372,-1367,-1363,-1358,-1354,-1350,-1346,-1342,-1338,-1335,-1331,-1328,-1325,-1322,-1319,-1316,-1313,-1310,-1308,-1305,-1303,-1301,-1298,-1296,-1294,-1293,-1291,-1289,-1287,-1286,-1284,-1283,-1282,-1281,-1280,-1279,-1278,-1277,-1276,-1276,-1275,-1274,-1274,-1274,-1273,-1273,-1273,-1273,-1273,-1273,-1274,-1274,-1274,-1275,-1276,-1276,-1277,-1278,-1279,-1280,-1281,-1282,-1283,-1284,-1286,-1287,-1289,-1291,-1293,-1294,-1296,-1298,-1301,-1303,-1305,-1308,-1310,-1313,-1316,-1319,-1322,-1325,-1328,-1331,-1335,-1338,-1342,-1346,-1350,-1354,-1358,-1363,-1367,-1372,-1377,-1381,-1387,-1392,-1397,-1403,-1409,-1415,-1421,-1427,-1434,-1441,-1448,-1455,-1463,-1470,-1478,-1486,-1495,-1504,-1513,-1522,-1532,-1542,-1552,-1563,-1574,-1586,-1598,-1610,-1623,-1636,-1650,-1664,-1679,-1695,-1711,-1728,-1745,-1764,-1783,-1803,-1824,-1846,-1869,-1893,-1918,-1945,-1973,-2003,-2035,-2068,-2104,-2141,-2182,-2225,-2271,-2321,-2374,-2432,-2495,-2564,-2640,-2724,-2817,-2922,-3040,-3175,-3331,-3514,-3734,-4003,-4345,-4796,-5432,-6431,-8363,-20145,20145,8363,6431,5432,4796,4345,4003,3734,3514,3331,3175,3040,2922,2817,2724,2640,2564,2495,2432,2374,2321,2271,2225,2182,2141,2104,2068,2035,2003,1973,1945,1918,1893,1869,1846,1824,1803,1783,1764,1745,1728,1711,1695,1679,1664,1650,1636,1623,1610,1598,1586,1574,1563,1552,1542,1532,1522,1513,1504,1495,1486,1478,1470,1463,1455,1448,1441,1434,1427,1421,1415,1409,1403,1397,1392,1387,1381,1377,1372,1367,1363,1358,1354,1350,1346,1342,1338,1335,1331,1328,1325,1322,1319,1316,1313,1310,1308,1305,1303,1301,1298,1296,1294,1293,1291,1289,1287,1286,1284,1283,1282,1281,1280,1279,1278,1277,1276,1276,1275,1274,1274,1274,1273,1273,1273};
int steps;
// Declare pins as output:
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
interrupts();
for(int i = 0; i < 500 ; i++) {
if (frame[i] > 0) {
steps = frame[i];
digitalWrite(dirPin, HIGH);
else {
steps = abs(frame[i]);
digitalWrite(dirPin, LOW);
digitalWrite(stepPin, HIGH);
delayMicroseconds(0.5*steps);
digitalWrite(stepPin, LOW);
