Variable HTTPPARA URL
At the moment, I am able to send data to my database by using constant values with:
Serial1.println("AT+HTTPPARA=\"URL\",\"http://xx.xx.xx.xx:xx/aard/InsertCrash.php?ID=8&MID=2&TIME=1&locationX=1&locationY=1&locationZ=1\"");
However, I need to have the values be variables. I have tried the following, and cannot figure out why it isn't working even though it returns OK:
Serial1.print("AT+HTTPPARA=\"URL\",\"http://27.32.93.185:90/aard/InsertCrash.php?");
  Serial1.print("ID=");  // This is the value name
  Serial1.print(ID); // value of...
  Serial1.print("MID=");  // This is the value name
  Serial1.print(MID); // value of...
  Serial1.print("TIME=");  // This is the value name
  Serial1.print(TIME); // value of...
  Serial1.print("locationX=");  // This is the value name
  Serial1.print(locationX); // value of...
  Serial1.print("locationY=");  // This is the value name
  Serial1.print(locationY); // value of...
  Serial1.print("locationZ=");  // This is the value name
  Serial1.print(locationZ); // value of...
  Serial1.println("\"");
Help on this would be awesome ASAP
I have tried the following, and cannot figure out why it isn’t working
Change Serial1 to Serial, and see if it is REALLY sending what you think it is.
Keep in mind that the original had &s between the name=value pairs and the new method does not.
AT
OK
AT+CSQ
AT+CGATT?
AT+SAPBR=3,1,"CONTYPE","GPRS"
+CSQ: 9,0
OK
AT+SAPBR=3,1,"APN","live.vodafone.com"
OK
AT+SAPBR=1,1
OK
AT+HTTPINIT
OK
AT+HTTPPARA="URL","http://xx.xx.xx.xx:xx/aard/InsertCrash.php?ID=5MID=1TIME=1locationX=1locationY=1locationZ=1"
AT+HTTPACTION=1
ERROR
AT+HTTPREAD
OK
AT+HTTPTERM
OK
That is the response I got for:
Serial.print("AT+HTTPPARA=\"URL\",\"http://xx.xx.xx.xx:xx/aard/InsertCrash.php?");  //ID=8&MID=2&TIME=1&locationX=1&locationY=1&locationZ=1\""
  Serial.print("ID=");  // This is the value name
  Serial.print(ID); // value of...
  Serial.print("MID=");  // This is the value name
  Serial.print(MID); // value of...
  Serial.print("TIME=");  // This is the value name
  Serial.print(TIME); // value of...
  Serial.print("locationX=");  // This is the value name
  Serial.print(locationX); // value of...
  Serial.print("locationY=");  // This is the value name
  Serial.print(locationY); // value of...
  Serial.print("locationZ=");  // This is the value name
  Serial.print(locationZ); // value of...
  Serial.println("\"");
You need the & symbols.
It's always the little things haha, it working now with:
Serial1.print("AT+HTTPPARA=\"URL\",\"http://xx.xx.xx.xx:xx/aard/InsertCrash.php?");  //ID=8&MID=2&TIME=1&locationX=1&locationY=1&locationZ=1\""
  Serial1.print("&ID=");  // This is the value name
  Serial1.print("&MID=");  // This is the value name
  Serial1.print("&TIME=");  // This is the value name
  Serial1.print("&locationX=");  // This is the value name
  Serial1.print("&locationY=");  // This is the value name
  Serial1.print("&locationZ=");  // This is the value name
thank you guys so much!!!
