I have a project where I'm moving water between a measurement tank and a storage reservoir based on the user's level request, levels 1 through 10, and there are ten water level sensors in the tank that determine what action is taken when a request happens (fill, drain, or nothing).
Btw, I'm very new to this Arduino stuff, I've only been doing this a few weeks. My code is primitive, but it all works. I'm hoping here to tighten up the code and make future refinements and updates easier. I'm using an Arduino Mega (Elegoo).
The code below is the method that's ran when water level 1 is requested. There are ten water levels in my project, and so far I've been using ten separate methods, one for each water level. Any time I refine the code for level 1, I then have to propagate those changes to the other nine. I'd like to have one method for all ten and use a variable instead.
Here's a demonstration of what I'd like to do:
Instead of
if(digitalRead(levelsensor1) == HIGH && digitalRead(levelsensor2) == LOW){
I'd like to do something like
if(digitalRead(levelsensor variable) == HIGH && digitalRead(levelsensor variable +1) == LOW){
I would then set the variable prior to running the method, instead of setting it within the method as I'm doing now so I would only need one method for any requested water level.
Is this even possible?
Thanks for any suggestions!
void goto_level1(){
#include <LCD_I2C.h>
LCD_I2C lcd(0x27, 16, 2);
lcd.backlight();
digitalWrite(gobuttonled, LOW);
lvl = 1; //sets variable to current level request
//check for defective level sensor
//the requested water level sensor is dry, but somehow a higher level sensor is wet
sensor_defect(); //stops pump, closes valves, displays error message on lcd
return; }
//water level less than requested
if(digitalRead(levelsensor1) == HIGH && digitalRead(levelsensor2) == HIGH){
display_filling(); //display message that tank is filling
while(digitalRead(levelsensor1) == HIGH){
active_fill(); //open valves to allow filling
sensor_defect();
return; }
delay(50);}
//water level at requested, higher water level not detected
if(digitalRead(levelsensor1) == LOW && digitalRead(levelsensor2) == HIGH){
display_achieved();
//water level already above requested
if(digitalRead(levelsensor2) == LOW){
display_draining();
active_drain(); //open valves to allow draining
while(digitalRead(levelsensor2) == LOW){
if(digitalRead(levelsensor1) == HIGH){
sensor_defect();
return; }
}//defective sensor not found, moving on
//when requested level sensor becomes dry, stop draining
digitalRead(levelsensor1);
while(digitalRead(levelsensor1) == LOW){
active_drain();
delay(50);}
display_achieved();
lvl = 0; //reset level request variable
turnoff_leds();
active_stop(); //stops pump, closes valves
buzzer_achieved(); //audible tone when action is complete
delay(3000);
