Variable initial value not recognized
Hi all,
I'm trying to help my son with a project (he and I are both new to Arduino) and after stripping out all extraneous code there appears to be something fundamentally wrong with our Leonardo board -- essentially, in loop() the initial value of variables is not recognized properly.
Here is the code:
boolean flag;
int idx;
  flag = true;
  idx = 0;
  Serial.print("idx=");
  Serial.println(idx);
  if ( flag )
    Serial.println("resetting flag");
    flag = false;
  idx++;
This is the output from two consecutive runs -- the second began when I uploaded the code again without clearing the monitor:
17:18:49.585 -> idx=2
17:18:50.560 -> idx=3
17:18:51.583 -> idx=4
17:18:52.565 -> idx=5
17:18:53.591 -> idx=6
17:18:54.566 -> idx=7
17:18:55.589 -> idx=8
17:18:56.566 -> idx=9
17:18:57.586 -> idx=10
17:19:05.539 -> idx=2
17:19:06.514 -> idx=3
17:19:07.546 -> idx=4
17:19:08.521 -> idx=5
17:19:09.549 -> idx=6
17:19:10.527 -> idx=7
17:19:11.551 -> idx=8
17:19:12.530 -> idx=9
Any ideas? When I run this code in the Tinkercad simulator I get the expected output.
Thanks!
You might add a little delay after begin to give the Serial port a chance to do its thing.
Or you might put
while (! Serial);
after Serial.begin().
And most defiantly add some digits to the serial speed, try 115200.
What if you print initial idx also in setup()?
Adding while (! Serial); did the trick -- thanks!
