variable inside the name of a variable
Is it possible to have a variable inside the name of another variable ?
For example we have 12 variables (a1,a2,a3,...,a12) and we want to make if statements with these variables like:
If (a1>....){something}
if (a12>....){something}
Could we do something like:
for (i=1; i<13; i++){
    If (a_i>....){something}
I can well understand that a2, ai and a_i are three completely different variables but I am asking whether there is a way of doing this in order to avoid repeatitive programming.
Thank you in advance,
Alex
Use an array instead.
Remember arrays index from zero, not one.
AWOL thank you for your reply !
I know about arrays and I am aware how the work so that is what I am going to do, but apart from an array this cannot be done the way I said, can it ?
Thanx again.
No, tampering with the name after compilation is not possible and the macro pre processor doesn't have a loop construct, so an array and loop is the right way to go.
No. Names are for your use. The compiler discards them all, replacing them with addresses. If you store a name that goes away, the stored name will not be useful.
So then does the name of the variable add to the size of the sketch since it is replaced?
chrisnet:
No.
Names just become addresses, so no, the size of the name has no effect on sketch size.
