(Sorry for my language I am french )
It’s been some days since my project doesn’t compile well.
The code is made for a teensy 3.5. I have declared a bunch of variable at the beginning of the program, (a lot of pin address essentially), but when I use one of the variables to make a digitaWrite or something I get the error :
main:252:49: error: ‘delay_bip_alarm’ was not declared in this scope
I don’t think my issue is related to the code so I have deled some useless functions to make the debugging easier
I have tested to put my variable declaration with the “const” prefix and without “#define” but it changes nothing …
Thanks by advance !
#include <Arduino.h>;
#include <Adafruit_MMA8451.h>;
#include <Adafruit_Sensor.h>;
#include <L3G.h>;
L3G gyro;
Adafruit_MMA8451 mma = Adafruit_MMA8451();
#define int ADDRESS_EEPROM[8] = {0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57};
#define int ADDRESS_ACC = 0x50;
#define int pin_capteurs[5] = {A1, A2, A3, A4, A5};
#define int freq_echant = 1000; //Hz
#define int record_time = 6000; //6s
#define float tension_nominale_battery = 12.0; // V
#define float seuil_limit_bat = 10.0; // V
#define float rapport_pont_diviseur_batterie = 0.5;
int off_set_jauges[5] = {0, 0, 0, 0, 0};
#define int pin_battery = A21;
//Définition des tableaux de données
int data_strain[5][freq_echant * record_time] = 0; //5 cases pour les capteurs
int data_acc[3][freq_echant * record_time] = 0; // données accélération x, y, z repère fusée
int data_gyro[3][freq_echant * record_time] = 0; // données accélération x, y, z, repère fusée
float data_time[freq_echant * record_time] = 0.0; // prise précise du temps.
#define int pin_buzzer = 23;
#define int date_buzzer = 0;
#define int pin_wheatstone = 24;
#define int pin_led_erreur = 13;
#define int pin_button = A22;
#define int pin_WP = 39;
#define int pin_SDA_EEPROM = 38;
#define int pin_SCL_EEPRIM = 37;
#define int pin_TX_seq = 32;
#define int pin_RX_seq = 31;
#define int pin_led_save = 28;
#define int pin_led_on = 27;
#define int pin_SCL_ACC = 3;
#define int pin_SDA_ACC = 4;
#define int pin_dem_exp = A7;
byte highAddress;
byte lowAddress;
byte data;
bool etat_buzzer = false;
bool alarm_buzzer = false;
int delay_bip_alarm = 100;
bool on_record = false;
bool ready_ = false;
bool etat_led_ready = false;
int date_led_ready = 0;
int delay_ready_flash = 500;
ready_ = true;
if (millis() % 10000 <= 50) { // toute les 10s
alarm_buzzer = check_battery(); //on vérifie le niveau de batterie
if (alarm_buzzer and millis() - date_buzzer > delay_bip_alarm ) { // bip en alternance si l'alarme est déclanchée
etat_buzzer = not etat_buzzer;
if (etat_buzzer) {
digitalWrite(pin_buzzer, HIGH);
digitalWrite(pin_buzzer, LOW);
if (digitalRead(pin_dem_exp) == HIGH) { //demarage exp
on_record = true;
ready_ = false;
record();
if (digitalRead(pin_button) == HIGH and not on_record) { // remise à zero offset jauges appui court // save EEPROM appui long, on interdit le offset pendant le vol
if (analogRead(pin_button) > 500) { // appuis long -> save
digitalWrite(pin_led_save, HIGH);
save_eeprom();
digitalWrite(pin_led_save, LOW);
else { //appui court -> offset zero
digitalWrite(pin_led_on, LOW);
set_offset();
delay(100);
digitalWrite(pin_led_on, HIGH);
if (ready_ and millis() - date_led_ready > delay_ready_flash) { //clignotement ready
etat_led_ready = not etat_led_ready;
if (etat_led_ready) {
else {
else {
