Connect Gnd to Gnd, and the other three pins to PWM capable pins. So if you connect R/G/B to pins 9/10/11, you could get that with
analogWrite(9,20);
analogWrite(10,50);
analogWrite(11,221);
Note that:
RGB LEDs give miserable color rendition even if you do everything right. There are some kinds of colors they're great at, while other colors just never look right.
The response curves are not linear, so if you actually want to match RGB values, you'll have to do some sort of correction. (This is an issue on all RGB leds).
The RGB LED's actually are not bad at all for colors, you need to use a diffuser(plastic from a milk container). I even dipped one in a short tube of hot glue to use for a project, when the glue completely cooled, the colors were more accurate, even orange!. And yellow was actually yellow!
Use Windows Paint and edit the colors, it'll show you the RGB values.
I've seen a RGB library around somewhere that uses that command structure like RGB(r,g,b).
