Variable message size on AES encryption/decryption
This code here: https://github.com/spaniakos/AES/blob/master/examples_Rpi/aes.cpp encrypts and decrypts messages of certain size. I need to make it able to encrypt/decrypt variable message sizes. For this reason I changed this:
byte plain[] = "TESTTESTTESTTESTTESTTESTTESTTESTTESTTESTTESTTESTTESTTESTTEST";
to this:
byte *plain;
But it does not work! Any idea?
Just to inform you that I input the messages from the Serial (Keyboard).
"It does not work" contains no information.
What comes out of the try?
Nothing comes out. However If I put the follwoing command:
byte plain[] = "Hello World!";
on the output I get the sentence: Hello World! plus carbage (irrelevant characters)...
That's a different kind of access. End the string with an ascii null character to end the string to cut the garbage!
@Railroader Railroader: You are Amazing! The garbage disappeared! How do I make the text I send to the Serial of variable length? I am reading malloc documentation, but I am not sure it is the right approach...
That's charbage.
a7
Send a string, ending with the null character to serial.
This link you pointed to has an example:
" https://github.com/spaniakos/AES/blob/master/examples/test_vectors/test_vectors.pde
Have you already tested it?
I have a lot of errors! I cannot run it...
