If you use find/replace to switch between isLongDetected and isLongButtonPressDetected in the following code, the variation in compiled program size occurs when compiling for Arduino Nano or LGT8F328P.
// Pin numbers and long/short press duration settings
const int BUTTON_PIN_SET = 3;
const int BUTTON_PIN_PLUS = 8;
const int BUTTON_PIN_MINUS = 12; // the number of the pushbutton pin
const int SHORT_PRESS_TIME = 1000; // 1000 milliseconds
const int LONG_PRESS_TIME = 1000; // 1000 milliseconds
// Variables for long/short press detection
int lastStateSet = LOW; // the previous state from the input pin
int currentStateSet; // the current reading from the input pin
unsigned long pressedTimeSet = 0;
unsigned long releasedTimeSet = 0;
bool isPressingSet = false;
bool isShortDetectedSet = false;
bool isLongButtonPressDetectedSet = false;
int lastStateMinus = LOW; // the previous state from the input pin
int currentStateMinus; // the current reading from the input pin
unsigned long pressedTimeMinus = 0;
unsigned long releasedTimeMinus = 0;
bool isPressingMinus = false;
bool isShortDetectedMinus = false;
bool isLongButtonPressDetectedMinus = false;
int lastStatePlus = LOW; // the previous state from the input pin
int currentStatePlus; // the current reading from the input pin
unsigned long pressedTimePlus = 0;
unsigned long releasedTimePlus = 0;
bool isPressingPlus = false;
bool isShortDetectedPlus = false;
bool isLongButtonPressDetected = false;
// Variables for the counters
unsigned char counters[4]; // 0: front, 1: back, 2: arms, 3: legs
bool counterAdjustEnable = false;
unsigned char counterArrayIndexPosition;
pinMode(BUTTON_PIN_SET, INPUT_PULLUP);
pinMode(BUTTON_PIN_MINUS, INPUT_PULLUP);
pinMode(BUTTON_PIN_PLUS, INPUT_PULLUP);
pinMode(BUTTON_PIN_MINUS - 2, OUTPUT); // these four lines are just to give convenient ground pins
digitalWrite(BUTTON_PIN_MINUS - 2, LOW); // these four lines are just to give convenient ground pins
pinMode(BUTTON_PIN_PLUS - 2, OUTPUT); // these four lines are just to give convenient ground pins
digitalWrite(BUTTON_PIN_PLUS - 2, LOW); // these four lines are just to give convenient ground pins
buttonPressDetection(BUTTON_PIN_SET, lastStateSet, currentStateSet, pressedTimeSet, releasedTimeSet, isPressingSet, isShortDetectedSet, isLongButtonPressDetectedSet);
buttonPressDetection(BUTTON_PIN_MINUS, lastStateMinus, currentStateMinus, pressedTimeMinus, releasedTimeMinus, isPressingMinus, isShortDetectedMinus, isLongButtonPressDetectedMinus);
buttonPressDetection(BUTTON_PIN_PLUS, lastStatePlus, currentStatePlus, pressedTimePlus, releasedTimePlus, isPressingPlus, isShortDetectedPlus, isLongButtonPressDetected);
counterTask();
// This bit is for debugging - something is messed up and these serial prints show it - a year later, I can't see anything messed up - maybe this was fixed
static unsigned long currentMillis;
static unsigned long previousMillis = 0;
currentMillis = millis();
if (currentMillis - previousMillis > 1000) {
Serial.print("debug:");
Serial.print(counters[0]);
Serial.print(",");
Serial.print(counters[1]);
Serial.print(",");
Serial.print(counters[2]);
Serial.print(",");
Serial.print(counters[3]);
Serial.print(",");
Serial.print("counterArrayIndexPosition:");
Serial.print(counterArrayIndexPosition);
Serial.print(",");
Serial.print("counterAdjustEnable:");
Serial.print(counterAdjustEnable);
Serial.print(",");
Serial.print("isShortDetectedMinus:");
Serial.print(isShortDetectedMinus);
Serial.print(",");
Serial.print("isLongButtonPressDetectedMinus:");
Serial.println(isLongButtonPressDetectedMinus);
Serial.print(",");
Serial.print("isShortDetectedPlus:");
Serial.print(isShortDetectedPlus);
Serial.print(",");
Serial.print("isLongButtonPressDetected:");
Serial.println(isLongButtonPressDetected);
void counterTask() {
static unsigned char counterCheck = counters[counterArrayIndexPosition]; // this will check for changes
// if counters are allowed to be adjusted and Plus button is short-pressed, increment counter at selected array position
if (isShortDetectedPlus == true && counterAdjustEnable == true) {
counters[counterArrayIndexPosition]++;
// if counters are allowed to be adjusted and Minus button is short-pressed, decrement counter at selected array position
if (isShortDetectedMinus == true && counterAdjustEnable == true) {
counters[counterArrayIndexPosition]--;
// if Set button is short-pressed, change position of index in array of counters and disable counterAdjustEnable flag
if (isShortDetectedSet == true && counterAdjustEnable == true) {
else if (isShortDetectedSet == true) {
counterArrayIndexPosition = (counterArrayIndexPosition + 1) % 4; // Cycle through the array positions
// if counters are allowed to be adjusted and Plus button is long-pressed, increment counter at selected array position every 150 ms
if (isLongButtonPressDetected == true && counterAdjustEnable == true) {
if (currentMillis - previousMillis < 150) return;
// if counters are allowed to be adjusted and Minus button is long-pressed, decrement counter at selected array position every 150 ms
if (isLongButtonPressDetectedMinus == true && counterAdjustEnable == true) {
// if Set button is long-pressed, enable counter adjustment
if (isLongButtonPressDetectedSet == true) {
counterAdjustEnable = true;
// check whether counter has changed since last function call and print to serial if it has
if (counterCheck != counters[counterArrayIndexPosition]) {
Serial.println(counters[counterArrayIndexPosition]);
void buttonPressDetection(const int BUTTON_PIN, int &lastState, int ¤tState, unsigned long &pressedTime, unsigned long &releasedTime, bool &isPressing, bool &isShortDetected, bool &isLongButtonPressDetected) {
// read the state of the switch/button:
currentState = digitalRead(BUTTON_PIN);
if (lastState == HIGH && currentState == LOW) { // button is pressed
pressedTime = millis();
isPressing = true;
} else if (lastState == LOW && currentState == HIGH) { // button is released
isPressing = false;
releasedTime = millis();
long pressDuration = releasedTime - pressedTime;
if ( 10 < pressDuration && pressDuration < SHORT_PRESS_TIME ) {
Serial.println("A short press is detected");
isShortDetected = true;
if (isPressing == true && isLongButtonPressDetected == false) {
long pressDuration = millis() - pressedTime;
if ( pressDuration > LONG_PRESS_TIME ) {
Serial.println("A long press is detected");
isLongButtonPressDetected = true;
// save the last state
lastState = currentState;
