Hi everyone, I am attempting to use a button to cycle through neo pixel effects (from the Adafruit Neo-Pixel library example "simple") I copy and pasted the void functions for the effects as global variables but when I try to call them in case 1 it gives me the error "rainbow was not declared in this scope" (rainbow being a name of one of the effects)
Board: Arduino Uno
Any help is greatly appreciated!
#define Button 3
#define Led_Data 4
#define LED_COUNT 120
int State = 0;
int Old = 0;
int Bstate = 0;
Adafruit_NeoPixel strip(LED_COUNT, Led_Data, NEO_GRB + NEO_KHZ800);
strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
strip.show(); // Turn OFF all pixels ASAP
strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
pinMode(Button, INPUT);
pinMode(Led_Data, OUTPUT);
Bstate = digitalRead(Button);
if (Bstate == 1) {
delay(100);
if (Bstate == 0) {
State = Old + 1;
else {
delay(100);
switch (State) {
case 1:
rainbow(10);
Old = State;
void rainbow(int wait) {
// Hue of first pixel runs 5 complete loops through the color wheel.
// Color wheel has a range of 65536 but it's OK if we roll over, so
// just count from 0 to 5*65536. Adding 256 to firstPixelHue each time
// means we'll make 5*65536/256 = 1280 passes through this outer loop:
for (long firstPixelHue = 0; firstPixelHue < 5 * 65536; firstPixelHue += 256) {
for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
// Offset pixel hue by an amount to make one full revolution of the
// color wheel (range of 65536) along the length of the strip
// (strip.numPixels() steps):
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
// strip.ColorHSV() can take 1 or 3 arguments: a hue (0 to 65535) or
// optionally add saturation and value (brightness) (each 0 to 255).
// Here we're using just the single-argument hue variant. The result
// is passed through strip.gamma32() to provide 'truer' colors
// before assigning to each pixel:
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
strip.show(); // Update strip with new contents
delay(wait); // Pause for a moment
