Variable "Not declared in this scope" after declaring
Hi everyone, I'm having a strange problem that I can't figure out. I have a veriable declared but when I try to use it in an if() statement in a loop() I get "Compilation error: 'previusMillis' was not declared in this scope"
My code so far is:
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
MAX30105 particleSensor;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
float temperature;
int temperatureCycleCounter = 0;
int bpmXPixel = 5;
int bpmYPixel = 5;
int i;
unsigned long previousMillis = 0;
const long interval = 5000;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET    -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //Declaring the display name (display)
const unsigned char PROGMEM frame0 [] = {0x00, 0x00, 0x00, 0x00, 0x1E, 0x78, 0x21, 0x84, 0x40, 0x02, 0x40, 0x02, 0x40, 0x02, 0x20, 0x04, 0x20, 0x04, 0x10, 0x08, 0x08, 0x10, 0x04, 0x20, 0x02, 0x40, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame1 [] = {0x00, 0x00, 0x00, 0x00, 0x0E, 0x70, 0x11, 0x88, 0x20, 0x04, 0x20, 0x04, 0x21, 0x84, 0x21, 0x84, 0x11, 0x88, 0x08, 0x10, 0x04, 0x20, 0x02, 0x40, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame2 [] = {0x00, 0x00, 0x00, 0x00, 0x0E, 0x70, 0x11, 0x88, 0x20, 0x04, 0x23, 0xC4, 0x27, 0xE4, 0x17, 0xE8, 0x13, 0xC8, 0x09, 0x90, 0x04, 0x20, 0x02, 0x40, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame3 [] = {0x00, 0x00, 0x1E, 0x78, 0x21, 0x84, 0x40, 0x02, 0x46, 0x62, 0x4F, 0xF2, 0x4F, 0xF2, 0x47, 0xE2, 0x47, 0xE2, 0x23, 0xC4, 0x11, 0x88, 0x08, 0x10, 0x04, 0x20, 0x02, 0x40, 0x01, 0x80, 0x00, 0x00};
const unsigned char PROGMEM frame4 [] = {0x00, 0x00, 0x00, 0x00, 0x1E, 0x78, 0x3F, 0xFC, 0x7F, 0xFE, 0x7F, 0xFE, 0x7F, 0xFE, 0x3F, 0xFC, 0x3F, 0xFC, 0x1F, 0xF8, 0x0F, 0xF0, 0x07, 0xE0, 0x03, 0xC0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame5 [] = {0x00, 0x00, 0x1E, 0x78, 0x3F, 0xFC, 0x7F, 0xFE, 0x7F, 0xFE, 0x7F, 0xFE, 0x7F, 0xFE, 0x3F, 0xFC, 0x3F, 0xFC, 0x1F, 0xF8, 0x0F, 0xF0, 0x07, 0xE0, 0x03, 0xC0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame6 [] = {0x00, 0x00, 0x1E, 0x78, 0x3F, 0xFC, 0x7F, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0xFE, 0x7F, 0xFE, 0x3F, 0xFC, 0x1F, 0xF8, 0x0F, 0xF0, 0x07, 0xE0, 0x03, 0xC0, 0x01, 0x80, 0x00, 0x00};
const unsigned char PROGMEM frame7 [] = {0x00, 0x00, 0x00, 0x00, 0x1E, 0x78, 0x21, 0x84, 0x46, 0x62, 0x4F, 0xF2, 0x4F, 0xF2, 0x27, 0xE4, 0x27, 0xE4, 0x13, 0xC8, 0x09, 0x90, 0x04, 0x20, 0x02, 0x40, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame8 [] = {0x00, 0x00, 0x00, 0x00, 0x1E, 0x78, 0x21, 0x84, 0x40, 0x02, 0x43, 0xC2, 0x47, 0xE2, 0x27, 0xE4, 0x23, 0xC4, 0x11, 0x88, 0x08, 0x10, 0x04, 0x20, 0x02, 0x40, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame9 [] = {0x00, 0x00, 0x00, 0x00, 0x1E, 0x78, 0x21, 0x84, 0x40, 0x02, 0x40, 0x02, 0x41, 0x82, 0x21, 0x84, 0x21, 0x84, 0x10, 0x08, 0x08, 0x10, 0x04, 0x20, 0x02, 0x40, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00};
const unsigned char PROGMEM frame10 [] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
static const unsigned char PROGMEM temp[] =
  0b11100011, 0b10000000,
  0b10100100, 0b01000000,
  0b11100100, 0b00000000,
  0b00000100, 0b00000000,
  0b00000100, 0b01000000,
  0b00000011, 0b10000000,
  Serial.println("Initializing...");
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println("MAX30105 was not found. Please check wiring/power. ");
    while (1);
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    while (1); // Don't proceed, loop forever
  particleSensor.setup(); //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
  particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
  temperature = particleSensor.readTemperature();
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.display();
  delay(1500); // Pause for 2 seconds
  // Clear the buffer
  display.clearDisplay();
  long irValue = particleSensor.getIR();
  if (irValue > 50000 && checkForBeat(irValue) == true) {
    heartBeat();
    long delta = millis() - lastBeat;
    lastBeat = millis();
    beatsPerMinute = 60 / (delta / 1000.0);
    if (beatsPerMinute < 255 && beatsPerMinute > 20) {
      rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
      rateSpot %= RATE_SIZE; //Wrap variable
      //Take average of readings
      beatAvg = 0;
      for (byte x = 0 ; x < RATE_SIZE ; x++)
        beatAvg += rates[x];
      beatAvg /= RATE_SIZE;
  if (irValue < 50000)  {
    beatAvg = 0;
  if (currentMillis - previusMillis >= interval) {
    display.drawBitmap(bpmXPixel, bpmYPixel,frame0,16,16, 1);
    display.setCursor(40,10);
    display.print(beatAvg);
    display.drawBitmap(5, 25,temp,16,7, 1);
    display.setCursor(40, 25);
    display.print(temperature, 1);
    display.display();
void heartBeat() {
  for (i = 0;i < 4;i++) {
    display.drawBitmap(bpmXPixel, bpmYPixel,frame10,16,16, 0);
    display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame1,16,16, 1);
  display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame2,16,16, 1);
  display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame3,16,16, 1);
  display.display();
  for (i = 0; i < 11;i++) {
    display.drawBitmap(bpmXPixel, bpmYPixel,frame4,16,16, 1);
    display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame5,16,16, 1);
  display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame6,16,16, 1);
  display.display();
  display.display();
  display.display();
  display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame7,16,16, 1);
  display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame8,16,16, 1);
  display.display();
  display.drawBitmap(bpmXPixel, bpmYPixel,frame9,16,16, 1);
  display.display();
  for (i = 0;i < 3;i++) {
    display.display();
this variable creates the error
what is the underlying problem.
Welcome to the forum
Later
It is a spelling mistake
omg, ha ha
its late where i live so i did not notice it
thanks,
