Variable On For a Few Seconds With Pause and Loop
Guys,
I have a e cigarette, hooked up to a fish pump and a 3.7v lipo battery.
Think small portable Smoke Machine.
I want to hook it up to an Audrino and it trigger (turn on) for variable 3-5 seconds, pause for 10-15 seconds and then turn on again for 3-5 seconds. Loop forever.
Which code would you recommend?
Thank you,
GR
None - smoking is bad for everyone :)
can you show code & diagram on how you would turn on and off your fish pump?
then once you get there, have a look at the "blink" or "blink without delay" example to understand how to repeat something forever
It doesn't make a lot of sense to talk about turning a variable on or off. Variables are like Mr. Spock - completely immune to sweet talk.
Turning pins on or off is a different story.
PaulS: It doesn't make a lot of sense to talk about turning a variable on or off. Variables are like Mr. Spock - completely immune to sweet talk.
I think what OP meant with for variable 3-5 seconds the basic english language meaning (i.e. want to be able to set the duration between 3 and 5 seconds) not a programing code variable ;)
Guys,
By variable I mean duration.
So duration of 3-5 seconds, wait 10-15 seconds duration and loop.
I have no code besides simple LED blink code.
Not sure how to code 3-5 second duration or 10-15 second wait duration.
Here is the link to the Fog Machine.
http://valkyriestudios.net/making-a-mini-fog-machine/
Thanks,
Here is what I have found. Or is there a better code??
  • Random On/Off for (Smoke Machine)
    *Connect to ground & digital pin 4 (smokePin)
int smokePin = 4; // digital pin 4
long randOn = 0; // Initialize a variable for the ON time
long randOff = 0; // Initialize a variable for the OFF time
void setup() // run once, when the sketch starts
randomSeed (analogRead (0)); // randomize
pinMode(smokePin, OUTPUT); // sets the digital pin as output
void loop() // run over and over again
randOn = random (3000, 5000); // generate ON time between 3 and 5 seconds
randOff = random (10000, 15000); // generate OFF time between 10 and 15 seconds
digitalWrite(smokePin, HIGH); // sets the SMOKE on
delay(randOn); // waits for a random time while ON
digitalWrite(smokePin, LOW); // sets the SMOKE off
delay(randOff); // waits for a random time while OFF
That will work if you don't want the Arduino to do anything else because using delay() will prevent that.
What else might you want it to do ? Well, perhaps you want to add a software on/off pushbutton or pushbuttons to make the periods longer or shorter whilst running or a pushbutton to turn continuous smoke on and off, etc, etc
If you need such functions then there are alternative timing techniques using millis() that will let you implement them and operate immediately without waiting for a delay() to complete.
Why don't time variables have Time in the name? Wouldn't onTime and offTIme make more sense? That the values are randomly generated is irrelevant, don't you think?
You don't need longs to hold values up to 15000.
Well, actually, between 3.0000 and 4.9999 seconds...
a duration is always positive, instead of long, go for unsigned long (or unsigned int if short enough)
Guys,
Took suggestions. The Audrino is just going to be running the pump, no buttons. Will add a power switch for the battery. Then mount in my Halloween costume.
I took out long, and changed text.
@J-M-L , I have no idea about long vs unsigned????
Am I missing anything else??
* Random On/Off for  (Smoke Machine)
*Contributions by @J-M-L, PaulS, UKHeliBob
const byte smokePin = 4; // Digital Pin 4 of the Arduino needs to connect to power of fish pump
unsigned long onTime = 0;                  // variable for the ON time
unsigned long offTime = 0;                 // variable for the OFF time
onTime = random (3000, 5000);    // generate ON time between 3 and 5 seconds
offTime = random (10000, 15000);    // generate OFF time between 10 and 15 seconds
  delay(onTime);                // waits for a random time while ON
  delay(offTime);               // waits for a random time while OFF
it's all documented :)
--> long
--> unsigned long
with 5 posts now you are a veteran, Please correct your post above and add code tags around your code: [code][color=blue]// your code is here[/color][/code].
It should look like this:// your code is here (Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
I would change the type of your pin variableint smokePin = 4; // digital pin 4intoconst byte smokePin = 4; // Digital Pin 4 of the Arduino needs to connect to ....and if you add comments, make them meaningful...
J-M-L,
Thanks.
I corrected the code in Post #9.
Now to buy another Audrino...
Great
Guys,
My Audrino arrived.
The code that we helped created is below:
But then I realized that I could hook up the mini air pump and the clearomizer to the Audrino.
So I updated the code below
*digital pin 4 (smokePin) is the Kanger T2 clearomizer
*digital pin 5 (airpump) is mini air pump
const byte smokePin = 4; // Digital Pin 4 of the Arduino needs to connect to the clearomizer
const byte airpumpPin = 5; // Digital Pin 5 of the Arduino needs to connect to the airpump
pinMode(airpumpPin, OUTPUT);        // sets the digital pin as output
I added airpumpPin 5. But I am stuck on how to random airpumpPin & smokePin together.
Power has to be sent to the Airpump and Smoke (clearomizer) at the same time. Then both Pin 4 & Pin 5 have the same random time.
Need some help.
Thank you
So, what IS the problem? You choose a time to turn both pins off, and then turn both pins on. Periodically, you see if it is time to turn both pins off. It's really no different from dealing with a single pin.
if you want different random times for each then you hit the limit of this simplistic design - it is time you go Read again #6
@PaulS
I am not sure how to add airpumpPin to the section below:
Guys,
I have another Noobie question.
I am using a 3.3v Arduino.
I checked the digital Pin output with a volt meter and I am getting 3.2v.
But when I connect a 3V mini fish pump, it is not turning on.
But when i directly connect a 3.7v lipo battery to the mini pump it works.
Then when I connect the mini pump to VCC, the pump works.
The mini pump specs:
Rated voltage: DC3V
Operating voltage range: DC2V-3.2V
Rated current: <150mA
Cartomizer:
2ohms
What am I doing wrong?
This section of code turns the smoke on and off. So what is so hard about writing to a second pin at the same time as the smoke pin, or at least immediately after it ?
As to your other question
Rated voltage: DC3V
Rated current: <150mA. How much less than 150mA ? An Arduino pin can supply only 20mA if I remember correctly. You may have blown up at least one pin output when you tried to power the pump from it.
@UKHeliBob
I have very little experience with Audrino code.
With the code below, will the two pins receive the same value?
digitalWrite(airpumpPin, HIGH);   // sets the SMOKE on
  digitalWrite(airpumpPin, LOW);    // sets the SMOKE off
Also I read about the 20mA of a pin.
Then I hooked up a N Mosfet to get it to work.
