Variable or field "name" declared void.
Who's Next?
//Define pins here
//Define 6 pins
 int F1button = 2;
 int F2button = 3;
 int F3button = 4;
//Define variables to hold outr time in/out
 int F1timeIn = 0;
 int F2timeIn = 1;
 int F3timeIn = 2;
 int counter = 3;
 // variable called not avilable which adds 10,000 to the count assigned to time in variable to bump it down the list
 int NotAvailable = 10000;
 //boolean variable to hold the argument, is F out?
 boolean F1out = false;
 boolean F2out = false;
 boolean F3out = false;
 //Create an array and load it up!
 int sortValues[4] = { NotAvailable, F1timeIn, F2timeIn, F3timeIn };
void setup(){
 //setup here
//sets our button pins as inputs
 pinMode(F1button, INPUT);
 pinMode(F2button, INPUT);
 pinMode(F3button, INPUT);
 //turn on the internal pullup resistors
 digitalWrite(F1button, HIGH);
 digitalWrite(F2button, HIGH);
 digitalWrite(F3button, HIGH);
 //create a string with the value of NotAvailable as the name
 char NotAvailable[ ] = "Not Available";
 Serial.begin(115200);  //open up a serial port for debugging and messages
      Serial.println("Turn order");  //warm up serial port
}//end of setup
void loop(){
//Handle the button pushes
  //F1 Button Handling
  if (digitalRead(F1button) == LOW){                      //if F1 button is pressed
        if(F1out == false){                               //and if F1 is in
          F1timeIn = (counter + NotAvailable);            // then make F1 time in equal to counter plus the not available constant
          counter ++;                                     //add one to the counter ready for when the button is next pushed
          F1out = true;                                   //make a note that F1 is now out
          delay(2000);                                    // wait 2 seconds to prevent accidental button pushes
        }else{                                            //and if F1 was out
          F1timeIn = (counter);                           //give the variable F1time in a number based on count (like picking a number and waiting in a queue
          counter ++;                                     // incriment the counter ready for the next button push
          F1out = false;                                  // F1 is now in so the statement becomes false
          delay(2000);                                    // again wait 2 sec to prevent accidental button pushes
        }                                                 //end of if else
   }                                                      //end of F1 button handling statement
  //F2 Button Handling
   if (digitalRead(F2button) == LOW){                      //if F2 button is pressed
        if(F2out == false){                               //and if F2 is in
          F2timeIn = (counter + NotAvailable);            // then make F2 time in equal to counter plus the not available constant
          F2out = true;                                   //make a note that F2 is now out
        }else{                                            //and if F2 was out
          F2timeIn = (counter);                           //give the variable F1time in a number based on count (like picking a number and waiting in a queue
          F2out = false;                                  // F2 is now in so the statement becomes false
        }                                                 //end of if else
   }                                                      //end of F2 button handling statement
  //F3 Button Handling
   if (digitalRead(F3button) == LOW){                      //if F3 button is pressed
        if(F3out == false){                               //and if F3 is in
          F3timeIn = (counter + NotAvailable);            // then make F3 time in equal to counter plus the not available constant
          F3out = true;                                   //make a note that F3 is now out
        }else{                                            //and if F3 was out
          F3timeIn = (counter);                           //give the variable F1time in a number based on count (like picking a number and waiting in a queue
          F3out = false;                                  // F3 is now in so the statement becomes false
        }                                                 //end of if else
   }                                                      //end of F3 button handling statement
  //Write the latest values into the array
  sortValues[0] = NotAvailable;
  sortValues[1] = F1timeIn;
  sortValues[2] = F2timeIn;
  sortValues[3] = F3timeIn;
  //sort the order using the 'sort' routine
  sort (sortValues,4);
  Serial.println("The order is;");
 //Line 1
 if       (sortValues[0] == F1timeIn){
   Serial.println("F1");
 }else if (sortValues[0] == F2timeIn){
   Serial.println("F2");
 }else if (sortValues[0] == F3timeIn){
   Serial.println("F3");
 }else if (sortValues[0] == NotAvailable){
   Serial.println("NotAvailable");
 //Line 2
 if       (sortValues[1] == F1timeIn){
 }else if (sortValues[1] == F2timeIn){
 }else if (sortValues[1] == F3timeIn){
 }else if (sortValues[1] == NotAvailable){
 //Line 3
 if       (sortValues[2] == F1timeIn){
 }else if (sortValues[2] == F2timeIn){
 }else if (sortValues[2] == F3timeIn){
 }else if (sortValues[2] == NotAvailable){
 //Line 4
 if       (sortValues[3] == F1timeIn){
 }else if (sortValues[3] == F2timeIn){
 }else if (sortValues[3] == F3timeIn){
 }else if (sortValues[3] == NotAvailable){
 delay(2000);
}// end of loop
   //Sorting routine  (http://www.hackshed.co.uk/arduino-sorting-array-integers-with-a-bubble-sort-algorithm/)
   //sorts the array in order of smallest first
void sort(int a[], int size) {
    for(int i=0; i<(size-1); i++) {
        for(int o=0; o<(size-(i+1)); o++) {
                if(a[o] > a[o+1]) {
                    int t = a[o];
                    a[o] = a[o+1];
                    a[o+1] = t;
The program now does what i want it to, but because its in a loop it keeps printing out to the serial over and over.
Its pretty much there, just needs some optimization.
Paul i hope you can see what ive done with "assigning a ticket" so to speak. I probably didnt explain what i meant that well.
I'm now working on how i can write it so that the button code is universal for all buttons but just subs in the values that are relevant. Otherwise once ive loaded the full 6 buttons it'll look pretty clumsy! plus ill learn more in the process.
//Define pins here
//Define 6 pins
 int F1button = 2;
 int F2button = 3;
 int F3button = 4;
?? six?
Comments, [Thanks to @ PaulS] are a pointer to your thinking,
@PaulS (Thank you for the lesson)...
Always change the comments to reflect your thoughts about the line of code you are currently writing...
Comments are cheap... Never appear in the compiled code.
Otherwise you are creating a map to nowhere...
Doc
just 3 for now but will be 6.
i like paul's code, looks real neat, will definitely save me copy and pasting the button handling and the printing 6 times over. Now to understand it.... :cold_sweat:
