Variable or field 'updateMessage' declared void, why?
the code trying to print out the items in commands one by one and/or some one, got ERROR need help please.
Thanks
Adam
char ButtonA01, ButtonA02, ButtonB01, ButtonB02, ButtonC01, ButtonC02, ButtonD01;
char commands[] = {ButtonA01, ButtonA02, ButtonB01, ButtonB02, ButtonC01, ButtonC02, ButtonD01};
//// TOTAL 8 commands
int i, j;
  i = 5;
  updateMessage(i);
  Serial.print(" updateMessage(i)=");
  Serial.println(updateMessage(i));
void updateMessage(i)
 for ( i = 0; i < 8; i++)
    dataToSend[8] = commands[i];
ERROR:
Arduino: 1.8.16 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_mar22c:22:21: error: variable or field 'updateMessage' declared void
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_mar22c\sketch_mar22c.ino: In function 'void loop()':
sketch_mar22c:15:3: error: 'updateMessage' was not declared in this scope
   updateMessage(i);
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_mar22c\sketch_mar22c.ino: At global scope:
exit status 1
option enabled in File -> Preferences.
Try
int updateMessage( int i)
The updateMessage function does not return anything. It is void.
Where is the dataToSend array declared. Will it have 9 elements (arrays are numbered from 0). So dataToSend[8] is the 9th element.
What is the purpose for writing to element 8 over and over?
See the reference for arrays.
Change:
to:
void updateMessage(int i)
Thanks.
still can't print out say, commands[5] = ButtonC02.
When you make changes to the original code, post the new version, in a new post, so that we can keep up.
Post the new error if there is one.
Thank you.
char *dataToSend;
//int i, j;
  Serial.println(" setup!");
  //  i = 5;
  updateMessage(5);
//  Serial.print(" updateMessage(5)=");
//  Serial.println(updateMessage(5));
//void updateMessage(i)
char updateMessage( int i)
  dataToSend = commands[i];
  Serial.print("dataToSend[9] = ");
  Serial.println(dataToSend);
Thanks.
What I like to do is Serial.print out the items one by one in commands[].
Now you've changed the updateMessage function signature so it is supposed to return a char, yet you do NOT return anything!
It should be:
void updateMessage( int i)
The ONLY code inside your for loop is:
Thanks.
I changed as:
still can't print any thing.
when I say items in commands[], mean: ButtonA01, ButtonA02, ButtonB01, etc.
Where do you believe you are even attempting to print the commands? Your for loop does not print anything at all.
The wokwi shown print some thing:
what I excepted is:
dataToSend[1] = ButtonA01;
dataToSend[2] = ButtonA02;
how can get it?
Consider doing some research, C++ Functions - Return (w3schools.com)?
First, these two lines:
probably do not do anything like what you expect.
The first line creates a bunch of named variables, but does NOT initialize their values, so they are ALL set to 0.
The second line creates the commands array which probably contains only one byte of the two (or more) byte addresses of each of those variables. In other words, it's useless.
So, what is it you are trying to do there, and what values do you expect to be in all those variables and the array?
As I've now pointed out twice, the updateMessage function contains a for loop, which accomplishes absolultely nothing. In fact, the for loop will be optimized away by the compiler, so it will not even exist in the compiled code.
If you are literally expecting to print out the names of the variables ButtonA01, etc., you won't be able to, because those names do not exist in the compiled code. All variable names are replaced with memory addresses in the compiled code, and the names are no longer present.
So, perhaps start by describing what it is you are actually TRYING to achieve.
Did you want something like this?!?
const char *commands[] =
  "ButtonA01", "ButtonA02",
  "ButtonB01", "ButtonB02",
  "ButtonC01", "ButtonC02", "ButtonD01"
//// TOTAL 7 commands
  updateMessage(5);
  for (int i = 0; i < 7; i++)
    Serial.print("updateMessage(i)=");
    updateMessage(i);
  Serial.print("commands[");
  Serial.print(i);
  Serial.print("] = ");
  Serial.println(commands[i]);
It repeatedly prints out:
updateMessage(i)=commands[0] = ButtonA01
updateMessage(i)=commands[1] = ButtonA02
updateMessage(i)=commands[2] = ButtonB01
updateMessage(i)=commands[3] = ButtonB02
updateMessage(i)=commands[4] = ButtonC01
updateMessage(i)=commands[5] = ButtonC02
updateMessage(i)=commands[6] = ButtonD01
Thank you johnwasser.
Tested works.
Thanks.
I was excepted declare a bunch of strings like the first line, not even ButionX, just any strings make them a group like the second line does, and be able to operate them.
