Variable output on tft
Hello, i want to show a variable on my ILI9341 TFT screen but i need help.
My code:
 Interfacing ESP8266 NodeMCU with ILI9341 TFT display (240x320 pixel).
 This is a free software with NO WARRANTY.
 https://simple-circuit.com/
  This is our GFX example for the Adafruit ILI9341 Breakout and Shield
  ----> http://www.adafruit.com/products/1651
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <Adafruit_GFX.h>       // include Adafruit graphics library
#include <Adafruit_ILI9341.h>   // include Adafruit ILI9341 TFT library
#define TFT_CS    D2     // TFT CS  pin is connected to NodeMCU pin D2
#define TFT_RST   D3     // TFT RST pin is connected to NodeMCU pin D3
#define TFT_DC    D4     // TFT DC  pin is connected to NodeMCU pin D4
// initialize ILI9341 TFT library with hardware SPI module
// SCK (CLK) ---> NodeMCU pin D5 (GPIO14)
// MOSI(DIN) ---> NodeMCU pin D7 (GPIO13)
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
  Serial.println("ILI9341 Test!");
  tft.begin();
  tft.setRotation(1);
  // read diagnostics (optional but can help debug problems)
  uint8_t x = tft.readcommand8(ILI9341_RDMODE);
  Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDMADCTL);
  Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDPIXFMT);
  Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDIMGFMT);
  Serial.print("Image Format: 0x"); Serial.println(x, HEX);
  x = tft.readcommand8(ILI9341_RDSELFDIAG);
  Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
  Serial.println(F("Benchmark                Time (microseconds)"));
  Serial.print(F("Text                     "));
  Serial.println(testText());
  Serial.println(F("Done!"));
byte runXTimes = 0;
if (runXTimes)
 testText();
    runXTimes--;
String myvariable = test;
unsigned long testText() {
  tft.fillScreen(ILI9341_BLACK);
  tft.setCursor(40, 55);
  tft.setTextColor(ILI9341_GREEN);
  tft.setTextSize(2);
  tft.println("myvariable");
And the error i become is:
1time_tft:74:21: error: 'test' was not declared in this scope
exit status 1
can someone help me please, i'm new with Arduino.
Thanks!
Regards
Alex
Did you mean "testText"?
testText works but i want to output the text of myvariable
grumpy_oleg:
What do you expect that to be?
The variable named test is not declared in the sketch so no wonder you get an error
What exactly do you want to print ?
Your codeline
assigns the variable myvariable the content of the variable named test.
One quick and easy way to get your code running is use a string-constant like this
String myvariable = "Hello World";
hardcoded strings always needs double-hyphens at most left and most right "
single characters stored in variables of type char need single-hyphens 'A'
You shouldn't use variable-type String for real code.
variables of type String eat up all memory over time when you re-assign values to it.
This leads to very hard to debug errors.
You should use the library PString or SafeString.
For learning programming in general Take a look into this tutorial:
Arduino Programming Course
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
best regards Stefan
Stefan - there maybe a language problem here. What do you mean by a hyphen ?
