Hello.
I am currently in an internship and I am working on a project for an opening and closing system for a henhouse. I have to program a guillotine type door, which opens and closes according to the direction of rotation of the motor driven by relays, in automatic mode.
HIGH and LOW sensors are integrated to designate the door open and close limits, which have normally open contacts. These contacts close when they detect a magnet hanging on the door, allowing the motor to be stopped 1 second after the contacts close and to stop the door.
I managed to program the manual mode of the door with the help of a RIGHT button included in the LCD display which also shows data on the screen. In this manual mode, by pressing the button:
-the door closes until the DOWN sensor (+1 second)
- she pauses for 3 seconds
-the door opens up to the UP sensor (+1 second)
-end of the manual door test.
Now I'm looking to have the door open and close automatically depending on the time of day. I am using a solar cell to sense ambient light and convert it to voltage.
Here I would like to program a threshold of 1V to determine if it is day or night.
I also added Boolean variables to denote the state of the door (closed, not closed, open, not open), and I use the millis () function for timers, and state machines for my programs.
This is what I did:
//moteur + relais + LCD + cellule + capteurs
// LCD Keypad Shield
// Modif 15
#include <LiquidCrystal.h>
// Création de l'objet lcd (avec les différents ports numériques qu'il utilise)
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
//variables
int lcd_key = 0;
int adc_key_in = 0;
int TensionBAS = 0;
int TensionHAUT = 0;
float TensionCelluleSolaire = 0;
float TensionMoteur = 0;
//constantes
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
#define RelayPin1 2 //le port numérique D2 est connecté au relais 1
#define RelayPin2 3 //le port numérique D3 est connecté au relais 2
#define CapteurBAS 11 //le port numérique D11 est connecté au capteur BAS
#define CapteurHAUT 12 //le port numérique D12 est connecté au capteur HAUT
#define debugTxtVar(myParameterText, variableName) \
Serial.print(#myParameterText " = "); \
Serial.println(variableName);
#define debugTxtVar2(myParameterText1, variableName1, myParameterText2, variableName2) \
Serial.print(#myParameterText1 " = "); \
Serial.print(variableName1); \
Serial.print(" " #myParameterText2 " = "); \
Serial.println(variableName2);
int Etat_fonctionnement_manuel = 0;
int Etat_fermeture_auto = 0;
int Etat_ouverture_auto = 0;
unsigned long temps_fonctionnement_manuel = 0;
unsigned long temps_fermeture_auto = 0;
unsigned long temps_ouverture_auto = 0;
unsigned long temps_mesures = 0;
unsigned long temps_serie = 0;
unsigned long temps_actuel;
boolean JourVrai; // indique si c'est le jour ou la nuit
boolean PorteOuverte = false; // indique si la porte est en position ouverte ou non
boolean PorteFermee = false; // indique si la porte est en position fermee ou non
boolean Test_manuel_demarrage = false; //indique si le test manuel de la porte est en cours ou non
boolean AUTO_Fermeture = false; //indique si la fermeture automatique de la porte est en cours ou non
boolean AUTO_Ouverture = false; //indique si l'ouverture automatique test manuel de la porte est en cours ou non
// On met les pin de chaque relais en sortie
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
// On met les pin de chaque capteur en entrée
pinMode(CapteurBAS, INPUT);
pinMode(CapteurHAUT, INPUT);
Serial.begin(9600);// ouvre le port série et fixe le debit de communication à 9600 bauds
lcd.begin(16, 2); // Démarrage de l'écran
lcd.setCursor(0, 0); // Positionnement du curseur au début
lcd.print("Test porte"); // Message
// Sous traite les différentes tâches
lcd_key = read_LCD_buttons(); // Lecture des touches
task_mesure_tensions();
task_fonctionnement_manuel();
task_fermeture_auto();
switch (lcd_key) // Action en cas de touche pressée
case btnRIGHT: //en appuyant sur le bouton RIGHT
if (Etat_fonctionnement_manuel == 0 && PorteOuverte) {
Etat_fonctionnement_manuel = 1; //on affecte la variable à 1
Test_manuel_demarrage = true;
if ( digitalRead(CapteurBAS) == LOW )//lorsque le contact du capteur BAS est fermé...
PorteFermee = true; //la porte est en position fermée
PorteFermee = false; //la porte n'est pas en position fermée
if ( digitalRead(CapteurHAUT) == LOW )//lorsque le contact du capteur HAUT est fermé...
PorteOuverte = true; //la porte est en position ouverte
PorteOuverte = false; //la porte n'est pas en position ouverte
if (TensionCelluleSolaire < 1.0 )
{ // une tension basse signifie qu'il commence à faire sombre
JourVrai = false; //la variable passe à false lorsqu'il fait nuit
//{ // une tension haute signifie que le soleil se lève
JourVrai = true; //la variable passe à true lorsqu'il fait jour
if (!JourVrai && !PorteFermee) // s'il fait nuit mais la porte n'est pas en position fermée...
Etat_fermeture_auto = 1; //on affecte la variable à 1
Etat_ouverture_auto = 0; //on affecte la variable à 0
if (!JourVrai && PorteFermee) // s'il fait nuit et la porte est en position fermée...
Etat_fermeture_auto = 0; //on affecte la variable à 0
if (JourVrai && !PorteOuverte) // s'il fait jour mais la porte n'est pas en position ouverte...
Etat_ouverture_auto = 1; //on affecte la variable à 1
if (JourVrai && PorteOuverte) // s'il fait jour et la porte est en position ouverte...
temps_actuel = millis(); //fonction non bloquante qui indique le temps passé en millisecondes
if ( (temps_actuel - temps_serie) >= 1000ul )//la boucle se réinitialise à chaque seconde
temps_serie = temps_actuel;
//affiche les différentes données sur le moniteur série
debugTxtVar2(TensionCelluleSolaire , TensionCelluleSolaire, TensionMoteur , TensionMoteur);
debugTxtVar(JourVrai , JourVrai);
debugTxtVar2(Etat_fonctionnement_manuel , Etat_fonctionnement_manuel, Test_manuel_demarrage , Test_manuel_demarrage);
debugTxtVar2(AUTO_Fermeture , AUTO_Fermeture, Etat_fermeture_auto , Etat_fermeture_auto);
debugTxtVar2(AUTO_Ouverture , AUTO_Ouverture, Etat_ouverture_auto , Etat_ouverture_auto);
debugTxtVar2(PorteOuverte , PorteOuverte, PorteFermee , PorteFermee);
debugTxtVar(temps_actuel , temps_actuel);
}//loop
void task_mesure_tensions()//permet de prendre des mesures de tensions et d'afficher des données sur l'écran LCD
temps_actuel = millis();//fonction non bloquante qui indique le temps passé en millisecondes
if ( (temps_actuel - temps_mesures) >= 250ul ) //la boucle se réinitialise toutes les 250 ms
temps_mesures = temps_actuel;
// Transforme la mesure (nombre entier) en tension via un produit en croix
int CelluleSolaireCAN = analogRead(A1); // Mesure la tension aux bornes de la cellule solaire
int MoteurCAN = analogRead(A2); // Mesure la tension consommée par le moteur
float TensionV1 = (float)CelluleSolaireCAN * (5.0 / 1023.0);
float TensionV2 = (float)MoteurCAN * (5.0 / 1023.0);
lcd.setCursor(0, 1); // Positionnement du curseur début de ligne
//affiche les différentes données sur l'écran LCD
if (JourVrai)
lcd.print("jour"); //affiche "jour"
else if (!JourVrai)
lcd.print("nuit"); //affiche "nuit"
lcd.print(" M");
lcd.print(Etat_fonctionnement_manuel); //affiche la valeur de la variable
lcd.print(" F");
lcd.print(Etat_fermeture_auto); //affiche la valeur de la variable
lcd.print(" O");
lcd.print(Etat_ouverture_auto); //affiche la valeur de la variable
TensionCelluleSolaire = TensionV1;
TensionMoteur = TensionV2;
}//if
}//task_mesure_tensions
void FermerMoteur() {//fait tourner le moteur dans un sens pour fermer la porte
digitalWrite(RelayPin1, LOW); //le relais 1 est actif
digitalWrite(RelayPin2, HIGH); //le relais 2 est inactif
void ArretMoteur() {//met le moteur en pause et stoppe la porte
digitalWrite(RelayPin1, HIGH); //le relais 1 est inactif
void OuvrirMoteur() {//fait tourner le moteur dans l'autre sens pour ouvrir la porte
digitalWrite(RelayPin2, LOW); //le relais 2 est actif
void task_fonctionnement_manuel()//permet d'activer le test de fonctionnement manuel de la porte
switch ( Etat_fonctionnement_manuel )
case 1:
// Après l'appui du bouton, le moteur tourne dans un sens et la porte commence à se fermer...
FermerMoteur();
temps_fonctionnement_manuel = temps_actuel;//on réinitialise le temps passé à 0 ms
Etat_fonctionnement_manuel++;// on incrémente la variable de 1
case 2:
if (PorteFermee) //lorsqu'on détecte la porte en position fermée...
//on lance une temporisation d'une seconde pour être sûr qu'elle soit bien fermée
}//if
case 3:
if ((temps_actuel - temps_fonctionnement_manuel) >= 1000ul) //une fois la temporisation achevée...
//...le moteur se met en pause et la porte s'arrête
ArretMoteur();
}//if
case 4:
if ( (temps_actuel - temps_fonctionnement_manuel) >= 3000ul )
// une fois les 3 secondes de pause passées, on ouvre la porte
OuvrirMoteur();
}//if
case 5:
if (PorteOuverte) //lorsqu'on détecte la porte en position ouverte...
//on lance une temporisation d'une seconde pour être sûr qu'elle soit bien ouverte
}//if
case 6:
if ( (temps_actuel - temps_fonctionnement_manuel) >= 1000ul )//une fois la temporisation achevée...
ArretMoteur();
Etat_fonctionnement_manuel = 0;//on affecte la variable à 0
Test_manuel_demarrage = false; //le test manuel de la porte est terminé
}//if
}//switch
}//task_fonctionnement_manuel
void task_fermeture_auto//permet de fermer la porte automatiquement
switch ( Etat_fermeture_auto)
case 1:
if ( (temps_actuel - temps_fermeture_auto) >= 10000ul )
// Au bout de 10 secondes...
temps_fermeture_auto = temps_actuel;//on réinitialise le temps passé à 0 ms
Etat_fermeture_auto++;// on incrémente la variable de 1
case 2:
//on ferme la porte indéfiniment
FermerMoteur();
}//switch
}//task_fermeture_auto
// Fonction de lecture des touches
int read_LCD_buttons()
adc_key_in = analogRead(0); // Lecture du port analogique
// Les valeurs qui suivent doivent être adaptées au shield
if (adc_key_in > 1000) return btnNONE; // En principe 1023 quand aucune touche n'est pressée
if (adc_key_in < 50) return btnRIGHT; // 0
if (adc_key_in < 195) return btnUP; // 99
if (adc_key_in < 380) return btnDOWN; // 255
if (adc_key_in < 555) return btnLEFT; // 409
if (adc_key_in < 790) return btnSELECT; // 640
return btnNONE;
For now, I am trying to perform an automatic closing test, where if it is dark but the door is not completely closed, it starts a 10 second time delay where, once elapsed, allows you to do close the door.
I also use the serial monitor to display my data:
As expected, the Etat_fermeture_auto variable changes to 1 when it is dark but the door is not yet closed.
However, after 10 seconds the variable remains at 1 instead of being assigned to 2 to close the door.
I use a switch case for this function of my program, but also for the task_fonctonnement_manuel function for the manual test of the door, where Etat_fonctionnement_manuel goes to 1 when the button is pressed, which closes the door.
How come ?
Did I make a mistake somewhere? Is it related to the 10 second timeout?
I need help please
