Variable PWM Output
Hello everyone! I'm new here and I'm looking for some help regarding my project. In a nutshell, I am building an bluetooth controlled quad copter (Ariel drone) and need some help with a pwm signal I need to output from the arduino. I am driving a flight control board that first takes in a pwm signal (from originally an RC transmitter) than converts these 4 channels into the logic needed to control each electronic speed control to power the motors. I have an RC transmitter that I was able to hook up to an oscilloscope to analyze the outputs. Basically, there is a neutral, full right, and full left position. Here is what I found the output was.
Left
Neutral
Right
So basically, you can see that at rest, the "on" time is ~ 1.5ms and the left and right "on" time is +- ~.5ms. From what I found, this is close to the industry RC standard.
I need some guidance on how I should go about programming this. My PS3 controller outputs a value from 0-255, 0 being full left, and 255 being full right. Basically, this 0-255 value needs to be interpreted into these desired waveforms. I have tried multiple different arduino library functions such as write microsecond, but I cant get reverse (left) with this! I need to be able to mimic these waveforms exactly in order to give my flight control board the proper signal.
Any help will be greatly appreciated!
Have you looked at the servo library ? Either for inspiration as to how to generate the required waveforms yourself or simply using it ?
