Variable result is corrupted after assigning delay
Hi all,
As the title says i am having a bit of an issue.
I am retrieving an ADC value and both printing it via serial and sending trough SPI.
I have no issues doing that at the loop execution rate, but since that is way too fast i added a delay.
The code looks like this:
unsigned long previousMillis = 0;        // will store last time LED was updated
const long interval = 1000;           // interval at which to blink (milliseconds)
int sensorPin = A0;    // select the input pin for the potentiometer
Void setup()
Void loop()
       if(currentMillis - previousMillis >= interval)
          adc = analogRead(sensorPin);
          Serial.println(adc);
          PORTD &= ~_BV(4);                      //Turn Shift register CS PIN LOW); // connects to RCLK
          SPI.transfer (highByte (adc));        // send out upper 8 bits MSB first
          SPI.transfer (lowByte (adc));         // send out lower 8 bits
          PORTD |= _BV(4);                       //Turn Shift register CS PIN high - data output changes on this rising edge
The data returns corrupted. For example a reading of 1023 comes as 1039. If I remove the delay everything works correctly.
Has anyone faced this issue before?
That code cannot compile. Post your code.
You're right!!
I just figured out that the culprit was the Adafruit Nokia5110 LCD library.
I am not sure if it was just a timing issue or what was happening since I wasn't using the LCD (just initialized on the setup).
Do you know of any other good libraries for this LCD that can use HW SPI?
[And yes, I CAN google them, but I am asking a recommendation on a good and light one.]
