Hey guys,
I am still a newb to arduino programming so hopefully someone can help me out.
To give a little background, the code triggers a camera and after so many triggers it activates a windshield wash/wipe system.
Here is the code:
//*User Config Section*//
//Note: All time is set in Milliseconds
const int pictureDelay = 10000; //delay between pictures being taken for test code
const int triggerDelay = 0; //Time between sensor trigger and camera capture
const int washDelay = 250; //How long wash pump is turned on for
const int washToWipe = 4000; //How long before the wiper is activated after the pump stops
const int wiperDelay = 6000; //How long the wipe is activated for. Note: Wiper takes 2-3 seconds to complete 1 full cycle.
const int triggerCount = 3; //How many pictures are taken before the wash wipe system activates
const int sensorPin = 2;
const int camPin = 4;
const int washPin = 7;
const int wipePin = 8;
int currentCount;
void setup(){
Serial.begin(9600); //start serial connection
pinMode(sensorPin, INPUT_PULLUP);
pinMode(camPin, OUTPUT);
pinMode(washPin, OUTPUT);
pinMode(wipePin, OUTPUT);
digitalWrite(camPin, LOW);
digitalWrite(washPin, LOW);
digitalWrite(wipePin, LOW);
currentCount = triggerCount; //Set current count to user configured trigger count
void loop(){
Serial.print("count at beginning of forever loop = ");
Serial.println(currentCount);
delay(triggerDelay); //User set delay time for camera capture
Serial.print("Sensor Activated");
digitalWrite(camPin, HIGH); //Triggers Camera
Serial.print("Camera Triggered");
delay(500); //Keeps camera trigger on for half a second
digitalWrite(camPin, LOW); //Turns camera trigger off
Serial.print("count before subrtraction = ");
currentCount = currentCount - 1; //Subtract 1 from temp count
Serial.print("Count after subtractions = ");
if(currentCount == 0) //Once temp count reaches 0 activate wash wipe system
digitalWrite(washPin, HIGH); //Activates Wash Pump
Serial.print("Wash Triggered");
delay(washDelay); //User set delay for how long wash pump is activated
digitalWrite(washPin, LOW); //Turns wash pump off
delay(washToWipe); //User set delay for time between when the pump stops and when the wiper activates
digitalWrite(wipePin, HIGH); //Activates Wiper
Serial.print("Wiper Trigered");
delay(wiperDelay); //User set delay for how long wiper is activated
digitalWrite(wipePin, LOW); //Turns wiper off
int currentCount = triggerCount;
Serial.print("Count inside of if statement = ");
digitalWrite(camPin, LOW); //Keeps Camera trigger deactivated when the sensor is not triggered
digitalWrite(washPin, LOW); //Keeps Wash trigger deactivated when the sensor is not triggered
digitalWrite(wipePin, LOW); //Keeps Wiper trigger deactivated when the sensor is not triggered
Serial.print("Count After if statement = ");
delay(pictureDelay);
(note: the original code uses a sensor to activate the camera. This program has most of the sensor code removed but that is the reason for references to sensors in the comments)
The problem I am having is with the "currentCount" variable. "currentCount" is set to "triggerCount" at the beginning of the code. Each time a photo is taken, "currentCount" decreases its number by "1". Once current count reaches "0" it enters the IF statement. At the end of the IF statement, "currentCount" is set back to "triggerCount" and process starts over again.
The problem comes after the if statement. In the current case, after "currentCount" is set to "triggerCount" in the if statement, the value for "currentCount" is "3". For some reason though, as soon as the if statement ends, "currentCount" reverts back to the value "0".
Here is the Serial Monitor Output:
count at beginning of forever loop = 3
Sensor Activated
Camera Triggered
count before subrtraction = 3
Count after subtractions = 2
Count After if statement = 2
count at beginning of forever loop = 2
Sensor Activated
Camera Triggered
count before subrtraction = 2
Count after subtractions = 1
Count After if statement = 1
count at beginning of forever loop = 1
Sensor Activated
Camera Triggered
count before subrtraction = 1
Count after subtractions = 0
Wash Triggered
Wiper Trigered
Count inside of if statement = 3
Count After if statement = 0
count at beginning of forever loop = 0
Sensor Activated
Camera Triggered
count before subrtraction = 0
Count after subtractions = -1
Count After if statement = -1
count at beginning of forever loop = -1
Sensor Activated
Camera Triggered
count before subrtraction = -1
Count after subtractions = -2
Count After if statement = -2
these two messages specifically:
What am I doing wrong?
Also I am very open to any suggestions on improving the code.
Thanks so much for any help!
-Scott
