Variable scope and tabs
I’m having a bit of trouble with declaring global variables.
I am trying to achieve a tab that contains a variable list.
Tab 1-
Variables();
  Serial.print ("Initial humidity variable = ");
  Serial.print (humidity);
  ReadHumidity();
  Serial.print ("Final humidity variable = ");
  delay(20000);
Tab 2-
void Variables()
float humidity = 0;
float temperature = 0;
Tab 3-
void ReadHumidity()
    float hum=0;
    int i=0;
    float humread=0;
    for (int i=0; i <= 5; i++)
  humread = sht1x.readHumidity();
  hum = hum + humread;
  //Debugging print section.
  Serial.print ("hum ");
  Serial.print (i);
  Serial.print (" = ");
  Serial.print (hum);
  humidity = hum / 5;
Compiling gives error:
In function ‘void loop()’:
error: ‘humidity’ was not declared in this scope In function ‘void ReadHumidity()’:
And highlights serial.print (humidity); in tab #1 / void loop().
I have also tried just listing variables in a tab by themselves, foregoing the subroutine call in void setup().
Any suggestions?
Each tab is a separate pde file. Global scope is limited to the file that a variable is defined in. If you want to share variables between pde files, that has to be done as arguments to functions or return values from functions.
Exactly what I was trying to avoid.
Thanks for the clarity of your answer!
You could try declaring your variables as extern.
//pde1
extern int test;
//pde2
extern int test;
Now both files should ‘see’ the test integer
Is the extern keyword required in both files? I thought it was needed only in the files that are trying to use a global variable defined in another file.
I think PaulS might be right.
I've coded php for a while now and the clock says 0117, maybe it's time to do something useful for a change... :wink:
Thanks all, that got me exactly where I wanted to be.
Just a side note on another hard learned lesson.
If the Arduino ide is spitting out weird compile errors,
Save and restart!
