Variable speed continuous rotation servo code
Hello everyone,
I've been searching on the web a lot but I didn't find anything that match what I need, I'm really new to all these and trying to make my own code for these project is quite difficult. I "just" need variable speed with a joystick on a modify continuous rotation servo. I already have the modify servo working, but when I push the joystick the servo reach its max. speed with a little impute (or pushing all degrees), I need it to be exponential (from 0 to 100, lets say), like the wheels of a car toy.
I was trying with the VarSpeedServo.h Arduino library, but not results so far (mostly I spouse because of my poor knowledge).
Please, someone can give me a hand. Thx!
Perhaps if you showed your code it would be a minor change.
My first guess at a solution would look something like this:
const int INPUT_PIN = A0;
const int ZERO_POINT = 33;  // An adjustment to get the servo to stop when stick is centered.
  int speed = analogRead(INPUT_PIN) - 512;  // -512 to +511
  long expo = speed * abs(speed);  // -262144L to +261121L
  servo.writeMicroseconds(map(expo, -262144L, 261121L, 1000, 2000) - ZERO_POINT);
Some simple test code you can try. Most DIY continuous rotation servos speed control range is between 1400us to 1600us.
//continuous rotation servo joystick
#include <Servo.h>
Servo myservo;  //declare servo
int potPin = 0;  //analog input pin A0
int potVal=1500; //~neutral value for continous rotation servo
  myservo.attach(9); // use pin 9 for servo control
void loop ()
  potVal = analogRead(potPin); // read pan joystick position
  potVal = map(potVal, 0, 1023, 1300, 1700); // scale reading to servo
  myservo.writeMicroseconds(potVal); //move servo to required position
You need to realise that you now have a speed rather than position control.
1400uS is say full CW
1600uS is full CCW
1500uS is STOP
The STOP 1500 may have to be adjusted in software to finetune it.
Tom.... :slight_smile:
Hi, johnwasser, at int speed = analogRead(INPUT_PIN)-512 with tiny input the servo moves slow, then faster (slow tough, not reach its max peed), and then ultra slow. I played with that numbers from -512 to +511, but not results :confused:
zoomkat, it's almost there. I get an exponential servo moving (with a potVal=150) but with in a 1/3 of the joystick range, the rest is full speed. what do you mean when you say "put your main code here, to run repeatedly".
sorry to be such a noob, please bare with me :-[
Daniel
What is the servo model that you modified?
hi Tom, its a futaba s3004, I didn't remove the potentiometer, I drilled a biger hole in the main gear so that the potentiometer would not move. I did these so I could adjust the potenciometer to "0", I mean, so it stops spinning.
(sorry for my english)
While you had the servo apart, did you send the servo a 90 deg. (1500us) command and then carefully adjust the pot such that the motor stopped moving?
This doesn't appear to be the code I posted.
hi zoomkat, I did't send the 90 deg. comand (I only adjust the pot). May I ask you how it's write?
Sorry the text "put your main..." was there by mistake coping something from the examples.
if it's myservo.write(90); in void setup... it's done. But I'm having the same problems
sin2numeros:
You need to clearly explain what your current problems are. You can change the mapping like below. Bottom is servo test code to see how the command values change the servo rotation speed.
potVal = map(potVal, 0, 1023, 1400, 1600); // scale reading to servo
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// (two hands required, one for letter entry and one for enter key)
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continous rotation servo
//int pos=90;
  myservo.attach(7, 400, 2600); //servo control pin, and range if desired
  Serial.println("serial servo incremental test code");
  Serial.println("type a character (s to increase or a to decrease)");
  Serial.println("and enter to change servo position");
  Serial.println("use strings like 90x or 1500x for new servo position");
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    if(readString.indexOf('x') >0) {
      pos = readString.toInt();
    if(readString =="a"){
      (pos=pos-1); //use larger numbers for larger increments
      if(pos<0) (pos=0); //prevent negative number
    if (readString =="s"){
      (pos=pos+1);
    if(pos >= 400) //determine servo write method
      Serial.println(pos);
      myservo.writeMicroseconds(pos);
      myservo.write(pos);
  readString=""; //empty for next input
Can you please post a copy of your sketch, using code tags?
Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom..... :slight_smile:
I made a video showing the problem I have (Hope would be more clear). I've been playing with the mapping numbers, but no succeed. It slowly gain speed but with in the halph of the joystick range, then it's all constant speed.
it's like:
(backward) 999999999987654321-0-123456789999999999(forward)
and should be:
(backward) 987654321-0-123456789 (forward)
I had problems with the code, I enter the values for the servo position but nothing happens. here is the code, there might be something I did wrong. (I used this code in the video. thanks Tom for the tip!):
#include <Servo.h>
String readString;
Servo myservo;
int pos=1500;
int potPin=0;
int potVal=150;
 myservo.attach(9,400,2600);  // put your setup code here, to run once:
      (pos=pos+1);
      myservo.write(pos);
  myservo.writeMicroseconds(potVal); //move servo to required position// put your main code here, to run repeatedly:
Use this sketch to control the servo and note the microsecond values for maximum speed forward, stop, and maximum speed reverse. Report back with those values. That data will be handy for designing your final sketch.
#include <Servo.h>
Servo myservo;
const int potPin = A0;
  myservo.attach(9); // put your setup code here, to run once:
   int potVal = analogRead(potPin);
   int microseconds = map(potVal, 0, 1023, 1000, 2000);
   myservo.writeMicroseconds(microseconds);
   Serial.println(microseconds);
it's like: (backward) 999999999987654321-0-123456789999999999(forward)
and should be: (backward) 987654321-0-123456789 (forward)
Did you try reducing the mapped servo control range like I suggested to 1400-1600? The code below has the reduced range which should give wider stick speed control.
#include <Servo.h>
void loop ()
Max. speed forward = 1000
Stop = 498
Max. speed reverse = 2000
I just upload the code and read it in the serial monitor, is that right? my doubt is because of the obvious numbers.
Yes I did, but 1300-1700 was the best range. Now I have check it again and notice the potVal was 150 instead of 1500. With this correction and the 1400-1600 range, the servo works better. It's a softer curve but not quite yet where I need it to be. It allows me more control because it's slower now...
I found a video that shows the exact same problem (although the solution it's not for me...)
Please jump to the minute 5:45 (you only need to watch 2 minutes from there)
Hello, could this be the solution?
http://www.seattlerobotics.org/encoder/200009/S3003C.html
tahnks
sin2numeros:
Stop = 498
Are you sure you don't mean 1498 instead of 498?!?
If you search there may be commercially available servos with similar broad range properties made for powering wheels on small bots.
:o upss... yes, 1498
I've search but with no luck, but I'll keep trying, there must be I spouse...
So... should I assume it's not possible then to program a normal servo to have that range?
Thanks
