Hi , trying to achieve a varying speed using a pot connected to A0.
The sketch uploaded OK , but the array seems to have decided on its own constant rate ---X milliseconds.
Any help appreciated
int potPin = A0;
int potValue;
// LED patterns here
unsigned char led_pattern[] = {
0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,
0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f
// set pin 2 to 5 as outputs
for (int i = 2; i <= 5; i++) {
pinMode(i, OUTPUT);
potValue = analogRead(potPin);
potPin = map(A0, 0, 1023, 100, 1000);
DisplayPattern(led_pattern, sizeof(led_pattern));
delay(potValue);
void DisplayPattern(unsigned char *pattern, int num_patterns)
static int pattern_num = 0; // keeps count of patterns
unsigned char mask = 1; // for testing each bit in pattern
// LEDs on pin 2 to pin 5
// check if bit in pattern is set or not and switch LED accordingly
if (pattern[pattern_num] & mask) {
digitalWrite(i, HIGH);
else {
digitalWrite(i, LOW);
mask <<= 1; // adjust mask for checking next bit in pattern
pattern_num++; // move to next pattern for next function call
// keep pattern within limits of pattern array
if (pattern_num >= num_patterns) {
pattern_num = 0;
