Variable switch with push button
I want to change the value of a variable “Komma” with a push button.
Each time you click the button the value is to change.
  1. Click Komma = 5,
    2nd click Komma = 1,
  2. click Komma again 5 and so on. A simple Swap-Function.
In VB I use the Int - Function on every Button Click:
a=a+1
if a/2=int(a/2) then
 Komma=5
 Komma=1
end if
How to do it on the Arduino? Was looking for swap function but found nothing that helped me.
if button becomes pressed
  increment counter
  if counter % 2  //modulo operator
    Komma = 5
  end if
    Komma = 1
  end else
end if
Many Thanks. problem solved :)
Skino: Many Thanks. problem solved :)
For future issues, you might look at the examples. This particular issue is addressed in the State Change Detection example.
I think a problem is the title of some examples and tutorials.
"State Change Detection " probably means jibberish to a noob, hence members and the forum to assist.
Tom..... :)
