Variable temperature set
Is there anyone who can help with my project consist of keypad and a master and slave. My goal is to input minimum temperature and maximum temperature via keypad on my master and then sends it to my slave , my slave will be saving it on EEPROM.
The problem i encountered is that i cannot send minimum and max value only value at a time.Im using SPI protocol to send data.
Master Code
#include<SPI.h>
#include<Wire.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 3;
byte value = 0;
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
void setup (void){
  lcd.begin(20,4);
  lcd.backlight();
  SPI.begin();                            //Begins the SPI commnuication
  SPI.setClockDivider(SPI_CLOCK_DIV8);    //Sets clock for SPI communication at 8 (16/8=2Mhz)
  digitalWrite(SS,HIGH);                  // Setting SlaveSelect as HIGH (So master doesnt connnect with slave)
void loop(void)
  lcd.setCursor(0,0);
  lcd.print("Enter Ref Temp:");
  char key = customKeypad.getKey();
   if (key != NO_KEY)
      if ( (key >= '0') && (key<= '9') )
         value = value *10;
         value = value + key -'0';
         lcd.setCursor(0,1);
         lcd.print(value);
      if ( key == '#' )
        digitalWrite(SS, LOW);
        SPI.transfer(value); //Send the mastersend value to slave also receives value from slave
        lcd.clear();
        value = 0;
Slave code
#include<Wire.h>
#include <EEPROM.h>
#include "DFRobot_SHT20.h"
#include<SPI.h>
//i2c pins
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); //
//temp&humid
DFRobot_SHT20    sht20;
// declaration of variable for relay
const int window1 = 2;
const int window2 = 3;
const int exhaustfan = 4;
const int orbitfan = 5;
const int fanheater = 6;
const int mistpump = 7;
const int heater =8;
volatile boolean received;
volatile byte Slavereceived;
void(* resetFunc) (void) = 0; //declare reset function @ address 0
  pinMode(MISO,OUTPUT);                   //Sets MISO as OUTPUT (Have to Send data to Master IN
  SPCR |= _BV(SPE);                       //Turn on SPI in Slave Mode
  received = false;
  SPI.attachInterrupt();                  //Interuupt ON is set for SPI commnucation
  lcd.begin(20,4);
  lcd.backlight();//Power on the back light
  sht20.initSHT20();     // Init SHT20 Sensor
  delay(100);
  sht20.checkSHT20();    // Check SHT20 Sensor
  // Relay modules
    pinMode(window1,OUTPUT);
    pinMode(window2,OUTPUT);
    pinMode(exhaustfan,OUTPUT);
    pinMode(orbitfan,OUTPUT);
    pinMode(fanheater,OUTPUT);
    pinMode(mistpump,OUTPUT);
    pinMode(heater,OUTPUT);
  pinMode(resetPin, OUTPUT);
  //Temperature And Humidity
    float humd = sht20.readHumidity();        // Read Humidity
    float temp = sht20.readTemperature();   // Read Temperature
    lcd.setCursor(0,0);
    lcd.print("Temperature:");
    lcd.print(temp);
    lcd.print("C");
    delay(100);
    lcd.setCursor(0,1);
    lcd.print("Humidity:");
    lcd.print(humd);
    lcd.print("%");
    delay(100);
ISR (SPI_STC_vect){                        //Inerrrput routine function
  Slavereceived = SPDR;         // Value received from master if store in variable slavereceived
  received = true;
  EEPROM.update(0,Slavereceived);//Sets received as True
  resetFunc();
//void receiveEvent(int howMany) {
//  byte byteVal = Wire.read();//Receive value from master board
//  lcd.setCursor(0,3);
//  lcd.print("Ref Temp:");
//  lcd.print(byteVal);
//  EEPROM.update(0,byteVal);
  byte eepromval = EEPROM.read(0);
  byte eepromles = eepromval - 2;
  Serial.println("Data");
  Serial.print(eepromval);
  Serial.print(eepromles);
  lcd.setCursor(0,0);
  lcd.print(temp);
  lcd.print("C");
  delay(100);
  lcd.setCursor(0,1);
  lcd.print(humd);
  lcd.print("%");
  lcd.setCursor(0,3);
  lcd.print(eepromval);
  delay(100);
  v1(eepromval,eepromles);
void v1(byte eepromval,byte eepromles){
    lcd.setCursor(0,0);
    lcd.print(temp);
    lcd.print("C");
    delay(100);
    lcd.setCursor(0,1);
    lcd.print(humd);
    lcd.print("%");
    lcd.setCursor(0,3);
    if(temp >= eepromval){//process #1
      lcd.setCursor(0,2);
      lcd.print("Process 1");
      digitalWrite(window1,LOW); // relay #1
      digitalWrite(window2,HIGH);  //relay #2
      digitalWrite(exhaustfan,LOW); //relay #3
      digitalWrite(orbitfan,LOW); //relay #4
      digitalWrite(fanheater,HIGH); //relay #5
      digitalWrite(mistpump,LOW); //relay #6
      digitalWrite(heater,HIGH); //relay #8
    }else{
      v2(eepromval,eepromles);
void v2(byte eepromval,byte eepromles){
  lcd.setCursor(0,0);
  lcd.print(temp);
  lcd.print("C");
  delay(100);
  lcd.setCursor(0,1);
  lcd.print(humd);
  lcd.print("%");
  lcd.setCursor(0,3);
  if(temp < eepromval){
    lcd.setCursor(0,2);
    lcd.print("Process 2");
    digitalWrite(mistpump,HIGH);
  }else{
    v3(eepromval,eepromles);
void v3(byte eepromval,byte eepromles){
  lcd.setCursor(0,0);
  lcd.print(temp);
  lcd.print("C");
  delay(100);
  lcd.setCursor(0,1);
  lcd.print(humd);
  lcd.print("%");
  lcd.setCursor(0,3);
  if(temp < 26){
    lcd.setCursor(0,2);
    digitalWrite(window1,HIGH);
    digitalWrite(window2,LOW);
    digitalWrite(exhaustfan,HIGH);
    digitalWrite(fanheater,LOW);
    digitalWrite(heater,LOW);
  }else{
    v4(eepromval,eepromles);
void v4(byte eepromval,byte eepromles){
  lcd.setCursor(0,0);
  lcd.print(temp);
  lcd.print("C");
  delay(100);
  lcd.setCursor(0,1);
  lcd.print(humd);
  lcd.print("%");
  lcd.setCursor(0,3);
  if(temp < eepromles || temp >= 26){
    lcd.setCursor(0,2);
    lcd.print("Process 3");
    digitalWrite(orbitfan,HIGH);
  }else{
In addition to your post of about 15 minutes ago on the same subject, there is this duplicate post:
All three about the same thing really, sending two byte values over SPI.
Duplication like that is not allowed in this forum.
Sorry for that i badly need some help for my project and still cannot find some answers myself so i ask for help. Will not do it again.
