while the experts were discussing how to get the POINT to solve how to POINT to POINTERS I was sleeping and now in 5 minutes I fixed my error in the exercise from @GolamMostafa and now I get the desired output:
long int *srcPtr;
long int *destPtr;
byte byteCounter = 2;
long int srcData[] = {12345678, 87654321};
long int destData[2];
srcPtr = (long int*)&srcData;
destPtr = (long int*)&destData;
do
*destPtr = *srcPtr;
destPtr ++ ;
srcPtr ++;
byteCounter --;
while (byteCounter != 0);
for (int i = 0; i < 2; i++)
Serial.print(destData[i], DEC);
Serial.print(' ');
I learned that I do not need to increment the address by 4 bytes because the declaration of long int already tells the compiler to increment 4 bytes to point to the next element.
Now my simple low level programmers version would be:
int byteCounter = 1;
do
destData[byteCounter] = srcData[byteCounter];
byteCounter --;
while (byteCounter >= 0);
Serial.print(' ');
now balance: pointer solution 25 relevant lines vs. array solution 17 relevant lines
now my “stone in my shoe” question is not answered yet:
I think I got it now but for my low level programmers purposes I really prefer my solution because my preference is making something like a mechanical device move or a TFT-display showing nice graphic before wasting time by struggling with Pointer syntax.
Anyway it was a great pleasure to get this excellent programming classes predominantly from @GolamMostafa thanks a lot
I do remember as I played a lot with that arguments --
argc = argument count
argv = argument vector
If I could discover my old exercise books, I could nicely explain the need of **argv pointer to pointer. Probably, those arguments greatly facilitated the parsing of DOS command line.
In C++, a declaration introduces a name and its type to the compiler without necessarily allocating storage. A definition allocates storage for a variable or provides the implementation for a function or class, and thus is also by nature a declaration. Initialization gives an object its first value at the point of definition, while assignment changes the value of an already existing object later.
It is important to note that from the language semantics point of view, initialization and assignment are still different: initialization happens at object creation, while assignment happens afterward. The optimizer can sometimes make the generated code equivalent or even identical for simple types when the assignment follows the definition, but it does not change the semantic distinction.
I think that this is hair splitting. Everyone knows what those terms mean, but let's give them a definition anyway:
Declaring a variable = reserve a piece of memory for it and give tihs memory a name.
Defining a variable = telling the compiler that a variable of a certain type (amount of memory) is going to be used but the memory itself is not allocated yet.
Assigning the variable = copying some value into variable's memory space.
Initializing the variable = assigning it a value for the first time.
I don't think that clarifies anything. Back to your question, what would the following code do?
`byte *ptr;
*ptr = 0x35;`
Most likely crash the controller, since ptr's value is undefined (haven't been allocated yet) and point to, well, whatever was in the memory that ptr occupies before this memory was assigned to ptr. So ptr may point to any location of the memory until it gets properly assigned with some address. So it is a bad idea to do something like this.
The "position" is the same: as you said, "between" the type and variable. The position of some operators matter, like ++ and --. The difference with those three is with the spaces, which are optional
byte*ptr; // fourth variant -- do not use
as with
x=a+b+c+d; // spaces would help readability
and even
x=a++ +b;
x=a+ ++b;
x=a+++b; // no really, don't do this -- auto-format does the right thing
For complex entities (objects) the difference can also be practical and significant. Objects are initialized by the class's constructor and the code executed there is completely different than the code that's executed during an assignment ... which happens in the function operator=().
int y; //it is a declaration; no memory space is allocated
int y;
y = 0x35; //variable y is defined; memory space is allocated
int y = 0x35; //variable y is initialized; given a value to y for the first time
y = 0x76; //variable y is assigned a new value
