Variable water pump
Hello everyone,
I'm looking for a way to connect a DC water pump to my Arduino.
I need the speed to be varied. ON/OFF is not enough for what I want to achive.
At the moment I'm using a relay to control it but that allows me to either turn it off or on.
How can I vary the speed of the water pump?
Currently used water pump
Thanks
It's a DC motor right? You need a transistor as the switch and send PWM to vary the speed. Google "Arduino DC motor speed control" and you should get tons of stuff to look at. It's one of the more common topics.
Use a transistor or [u]MOSFET[/u] driver circuit. 5W at 12V is a little less than 1/2 Amp, but the motor will draw more current during start-up, so get a transistor or MOSFET capable of 1A or more (easy to find).
Then use analogWrite() (which is [u]PWM[/u]) to control motor speed.
You might have to hit it with 100% PWM (255 or digitalWrite() ) to get the motor started before slowing it down. And, 50% (127) PWM probably won't be half-speed so you'll have to experiment.
notfreeusername:
Hello everyone,
What are you trying to achieve ?
What type of pump ? Centripedal or displacement ?
Do you need to control the pressure or flow rate ?
Being a brushless motor it may not take kindly to pwm supply.
Link did not work for me.
Generally pumps are designed for a purpose , cheaply available ones especially.
Modifying the for other use may not be easy.
Indeed that are brushless DC motors, with the control hardware built in. Not sure if it's even possible to slow them down that way.
The built in driver may (or may not) alter speed with different input voltages.
For the low cost, you can play with it by seeing what happens when you put it on 9 volts or 5 volts.
you may need to get a pump that is designed for variable speed
dave-in-nj:
They exist but are nowhere as cheap or as readily available fountain pumps.
Maybe the easiest way is to put a throttle in the output hose, and control that. Basically you partly close the hose to slow down the flow.
That will often damage a pump and at the very least, makes it work harder and wastes energy.
The usual approach is to add a valve on the output that, when open, diverts the excess flow back to the water source.
I've had such valves on many pumps that I bought in the shop, so it's apparently not that bad. They can never close completely, though.
Looks like you would have to crack open that case.
Controlling the valving bypass would be easier if you don't have different pressure loads.
Boardburner2:
... pencils are cheaper than printers.....
cost does not have a direct bearing on function.
they make variable speed brushless motor speed controllers. just saying. no use with this pump.
without the actual process, this is all moot.
the fountain pump has a head of 350cm.
this pump is designed for a discharge blocking valve, this one would not benifit with a bypass or run-around valve as the discharge pressure is so low.
the vanes have large gaps to allow for the bypass to occur inside of the impeller housing.
it can push water with little resistance, but is worthless for a pressure application.
at 260 lph, it might push 50 lph in a piped system.
as a note the run-around valving is a good solution for a fixed speed motor/pump.
the valve should be reduced port with an area of no more than half the pump port opening as it will have a much higher pressure drop because it is connected to the high and low pressures of the pump.
dave-in-nj:
Used to be able to get brushed pumps like this which can be speed controlled.
Most seem to have gone over to brushless though now.
Fountain pumps are cheap because of mass market , i can get brushed pumps but have to pay more.
ESC,s used by modellers are cheap for this but you have to break open the pump to connect.
EDIT
It can be done with some by cutting a hole in the side with a dremel.
Downside is you have to sacrifice a pump to find out where to cut the hole.
jremington:
actually the opposite. Throttling a centrifugal pump will cause it to thrash and reduce the load.
