variables at the beginning of my programs for setting information
I am trying to use variables at the beginning of my programs for setting information that can be viewed from the Serial Monitor. i would like to be able to enter information and have it show up when the sketch first runs. i am having problems doing this. the program name does not show up. Also is float the correct way to enter a program version number. i would like to be able to enter a version number like 1.0.1 but i am getting a to many decimals points in number fault. Does anyone have any suggestions.
SKETCH:
char ProgramName = "Blinker"; float versionNumber = 1.0;
int TimeOn(500); // milliseconds int TimeOff(1500); // milliseconds
void setup() { Serial.begin(9600); // turn on Serial Port
Serial.print("Program: "); Serial.println(ProgramName); Serial.print("Version: "); Serial.println(versionNumber);
pinMode(13, OUTPUT);
} void loop() {
// Blink code digitalWrite(13, HIGH); delay(TimeOn); digitalWrite(13, LOW); delay(TimeOff); }
A char uses up 1 byte. I don't think you can put "Blinker" in a char. Maybe you could put it in a character array and print it by iterating over the index?
 char ProgramName [] = "Blinker";
Jimmy
Think about it. Is 1.0.1 a floating point number ? Try
char * ProgramName = "Blinker";
char * versionNumber = "1.0.1";
mixographer: A char uses up 1 byte. I don't think you can put "Blinker" in a char. Maybe you could put it in a character array and print it by iterating over the index?
Jimmy
No need to use an index and iterate over the array. This is fine:-
char ProgramName[] = "Blinker";
In the posted code, the only thing missing is [] when declaring 'ProgramName'. Edit: Oh, and the lack of [code]code tags[/code]. :(
I don't think this does what you intended:
Use
int TimeOn = 500;    // milliseconds
int TimeOff = 1500;  // milliseconds
Better yet
const int TimeOn = 500;    // milliseconds
const int TimeOff = 1500;  // milliseconds
olf2012:
I don’t think this does what you intended:
Ha, I missed that. I did run his code earlier, however, and it does do what he intended - 500ms ‘on’ and 1500ms ‘off’.
Did you test it?
This is why it works:-
N.B. It’s known as “constructor initialisation”, and is perfectly valid.
See here:- Variables and types
(About 3/4 of the way down the page.)
Never too old to learn. :smiley:
cplusplus.com:
All three ways of initializing variables are valid and equivalent in C++.
#include <iostream>
using namespace std;
int main ()
 int a=5;               // initial value: 5
 int b(3);              // initial value: 3
 int c{2};              // initial value: 2
 int result;            // initial value undetermined
a = a + b;
 result = a - c;
 cout << result;
return 0;
A sketch which does not compile cannot run, so it isn’t surprising that the program name doesn’t show.
Remember to use code tags when posting code - here, I’ve got a spare pair you can have [code][/code]
Thank you everyone. i am still new to coding and i am not sure how to use the code tags. is this correct?
char versionNumber[] = 1.0;
Thank You David
Your use of tags is correct, but the compiler has already told you that part of the code you posted is incorrect.
dsmith9583: i am still new to coding and i am not sure how to use the code tags. is this correct?
That one will probably not do what you want. Use this:
char versionNumber[] = "1.0";
For 'variables' you don't intend to change it helps the compiler if you tell it not to let you accidentally change the value:
const char ProgramName[] = "Blinker";
const char versionNumber[] = "1.0";
It won’t do anything at all, because it doesn’t compile.
I worked. You guys are great. i appreciate all the help
David
dsmith9583: I worked. You guys are great. i appreciate all the help
David
Learn from getting it to work. Do you understand why it did not work originally but does now ?
dsmith9583:
is this correct?
AWOL:
Unfortunately what the compiler says is:
sketch_aug10a:2: error: initializer fails to determine size of 'versionNumber'
sketch_aug10a:2: error: array must be initialized with a brace-enclosed initializer
That implies that the solution is:
 char versionNumber[] = {1.0};
which compiles with a warning (if warnings are turned up):
/Users/john/Documents/Arduino/sketch_aug10a/sketch_aug10a.ino:2:28: warning: narrowing conversion of '1.0e+0' from 'double' to 'char' inside { } [-Wnarrowing]
Still won’t produce the desired results. We can’t always rely on the compiler giving correct instructions for fixing a programming error that causes bad syntax.
Regarding the version "number"
If you aren't doing arithmetic on it, it's text, not a number. It doesn't matter if the individual characters are all numerals.
You're going to have to convert it to a string anyway to display it, so just store it as one to begin with and cut out the useless heavyweight float stuff.
UKHeliBob
UKHeliBob: Learn from getting it to work. Do you understand why it did not work originally but does now ?
Thank you for asking. i do understand most of it but i am still having problems understanding what the [] function is.
Thank You David
dsmith9583: i am still having problems understanding what the [] function is.
It's not a function, it tells the compiler, that you want to create an array. See https://www.arduino.cc/en/Reference/Array
Bearonic: It's not a function, it tells the compiler, that you want to create an array. See https://www.arduino.cc/en/Reference/Array
Thank You
