Variables not changing in sketch with lots of files
ok im adjusting a sketch and i found some odd stuff. values not changing when they are changed in the origin file. the values seem to have no meaning but the file is included else where in other files. are they just assigned as being real but not changing values in a persistent way between files? i thought this stuff all got compiled into 1 master file
the exact thing im doing is making a custom arduboy but with a bigger screen with more vertical lines of resolution and using a esp32 with the hartmann1301 arduboy2 port from github. its at 128 x 90 with pixels at 2 times on x and y so its a decent ammount of a 320 x 240 screen .
on the arduboy end it works. the screen is now using more pixles. on catacombs of the damned (game i am testing this with) it sort of works . enemies can run up to me which is at the end of the screen at the bottom... the ground and walls are not drawn to that distance... the hand is sort of and the pots and ladder and sign ect is ...but there is a no mans land area in front of me that bugs them out a little. it does it in a circular range in front near where the ground ends. it represents where the player would normally be and thats dont draw sprite because it will obstruct view code
i have found it must be some math related values connected to the horizon but the defines does nothing. its called defines it should appear before draw it would seem or is this normal for instances of the variable to be segregated and not interconnected by default. the hardware should be able to do full screen in theory and im not interested in redistributing games i make . i may post a port on github if this ever gets done.
why bother? why not buy a big 2.42 inch 128 x 64 screen that they sell for $20? its $20 and my screen was $10 and has more vertical lines of resolution to allow for greater detail. i was wandering around weeks ago and found some one had done a full screen port of catacombs with a esp32 but no file download. they just showed something off and i cant find the website ...
What is the question?
Without posting actual code, we're all just guessing.
My guess is you have an issue with scope.
breaking code up into "modules" is a good thing. each module should have a well defined purpose and only implement functions for that purpose.
but to be able invoke those functions, as well as access variables in separate files, a .h file is needed.
for example, the following other.ino/.cpp defines functions and variables
int func (void)  {
    return 1234;
int BeginSignaal = func ();
would have the following other.h file which declares functions/variables specifying the return and arg types in functions and the variable type
extern int BeginSignaal;
extern int func (void);
and any other file using those functions/variables would have the following near the top of the file, as well as other.cpp/.ino which would result in errors if the two files were inconsistent
#include "other.h"
you may have "defined" variables with the same names in separate files
I'm sorry. I can't picture what you mean by that. Or by "the values seem to have no meaning" or by "not changing values in a persistent way between files".
Can you point to the exact project you are adapting, what you changed, and what you expected the change to do that it is not doing?
do variables act like sort of like a class when you #include the origin file in other files in a sketch. meaning do they have self contained instances despite being 1 variable. i am observing the oddest stuff like i change and change values but cant find the true stop drawing walls variable and when i use the most likely candidate the near plane it projects them at a angle that looks like it would reach but refuses to draw the floor or ceiling...
i would upload a file but i would have to upload the augmented hartmann file for arduboy2 because you have to adjust the vertical lines of resolution to end up with the exact problem i have and despite the compiling size the raw files for arduino take up more space than i think they let us use
i can upload the project later as it stands to newgrounds where i have a old account that hasnt been terminated which has a file dump . free web storage space. however i am using odd stuff in my build. a atmega 328p is interpreting a analog (spit out as integer with 17 possible values direction counting not a direction and 4 intensity counting zero) and 4 buttons (currently explicit and exclusive per input works for temp debouncing) and i gutted the input stuff out of arduboy2. also later i plan on trying to get it to handle the music with a ultra trimmed wave player that only does something ever so many mills so it toggles controller and audio processing
its compiling on a sparkfun thing plus so since this is a early version i dont think any one could run into problems compiling. ill be back in a few hours probably
well i hadnt realized every place i could upload it now has odd policies about invalid file types. i have cutmesh for unity on my newgrounds account file dump but cant upload this without official winzip which i wont download. even this place wont acknowledge 7zip... due to policy changes
well if you want to see the problem download hartmann1301 arduboy2 and then download tonym128 arduboy2. tonym128s has catacombs of the damned resource files (sketch form of the game). then go and change the lines in arduboy2 for lines of resolution vertical (the buffer as well) and then go into catacombs of the damned and do the same. when you run it signs and enemies will be able to pass the black fill which is past the priginal end of the screen. your life bar and mana bar will be where they always have been and wont move down and the screen but the hand is ...
i wasnt expecting any one to post a answer to that problem from what i could tell nobody really cared about increasing lines of resolution on diy arduboys but clarification on if variables added through including the origin file are unique instances despite having the same exact name. im probably just going to recode his stuff with extern to allow for global variables. its what i did for the controller end of it since i gutted arduboy2 of that and player and menu files need input. why is there even a defines file idk. i will just put all that stuff in the main and use extern in the other files
i know people would not prefer snippets, but how about posting where the variable is defined, where it is declared, how the .h is is included and how the variable is used in that file with the include along with the filenames of the files the snippets are from
it would be telling if you don't understand what i'm asking
Much depends on where and how variables are declared and defined.
Global variables should be defined once, in one .ino or .cpp file. If they are not defined as 'static' global variables they can be declared 'extern' on other .cpp files to be used as globals there.
Usually, any variables defined in a .cpp file that you want to use in another file should be declared as 'extern' in a matching .h file and that .h file should be included in any .cpp or .ino file where the variable is used.
i will post a tangled mess of stuff on a file from it. be warned i tried 15 variants and the obvious didnt seem to change it
#include <stdint.h>
#include "Draw.h"
#include "Defines.h"
#include "Game.h"
#include "Particle.h"
#include "FixedMath.h"
#include "Map.h"
#include "Projectile.h"
#include "Platform.h"
#include "Enemy.h"
#include "Font.h"
#include "LUT.h"
#include "Generated/SpriteData.inc.h"
#if WITH_VECTOR_TEXTURES
#include "Textures.h"
#endif
#if WITH_SPRITE_OUTLINES
#define DrawScaledInner DrawScaledOutline
#else
#define DrawScaledInner DrawScaledNoOutline
#endif
Camera Renderer::camera;
uint8_t Renderer::wBuffer[DISPLAY_WIDTH];
int8_t Renderer::horizonBuffer[DISPLAY_WIDTH];
uint8_t Renderer::globalRenderFrame = 0;
uint8_t Renderer::numBufferSlicesFilled = 0;
QueuedDrawable Renderer::queuedDrawables[MAX_QUEUED_DRAWABLES];
uint8_t Renderer::numQueuedDrawables = 0;
const uint8_t scaleDrawWriteMasks[] PROGMEM =
	(1),
	(1 << 1),
	(1 << 2),
	(1 << 3),
	(1 << 4),
	(1 << 5),
	(1 << 6),
	(1 << 7)
const uint16_t scaleDrawReadMasks[] PROGMEM =
	(1),
	(1 << 1),
	(1 << 2),
	(1 << 3),
	(1 << 4),
	(1 << 5),
	(1 << 6),
	(1 << 7),
	(1 << 8),
	(1 << 9),
	(1 << 10),
	(1 << 11),
	(1 << 12),
	(1 << 13),
	(1 << 14),
	(1 << 15)
void Renderer::DrawWallLine(int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint8_t clipLeft, uint8_t clipRight, uint8_t col)
	if(x1 > x2)
		return;
	if (y1 < 0)
		if(y2 < 0)
			return;
		if(y2 != y1)
			x1 += (0 - y1) * (x2 - x1) / (y2 - y1);
		y1 = 0;
	if (y2 > 89) //DISPLAY_HEIGHT - 1)
		if(y1 > 89) //DISPLAY_HEIGHT - 1)
			return;
		if(y2 != y1)
			x2 += (((90 - 1) - y2) * (x1 - x2)) / (y1 - y2);//DISPLAY_HEIGHT - 1) - y2) * (x1 - x2)) / (y1 - y2);
		y2 = 89; //DISPLAY_HEIGHT - 1;
	if (x1 < clipLeft)
		if(x2 != x1)
			y1 += ((clipLeft - x1) * (y2 - y1)) / (x2 - x1);
		x1 = clipLeft;
	int16_t dx = x2 - x1;
	int16_t yerror = dx / 2;
	int16_t y = y1;
	int16_t dy;
	int8_t ystep;
	if (y1 < y2)
		dy = y2 - y1;
		ystep = 1;
		dy = y1 - y2;
		ystep = -1;
	for (int x = x1; x <= x2 && x <= clipRight; x++)
		int8_t horizon = horizonBuffer[x] - HORIZON;
		Platform::PutPixel(x, horizon + y, col);
		yerror -= dy;
		while (yerror < 0)
			y += ystep;
			//if(y < 0 || y >= DISPLAY_HEIGHT)
			//	return;
			yerror += dx;
			if (yerror < 0)
			if (x == x2 && y == y2)
#endif
#if WITH_IMAGE_TEXTURES
void Renderer::DrawWallSegment(const uint16_t* texture, int16_t x1, int16_t w1, int16_t x2, int16_t w2, uint8_t u1clip, uint8_t u2clip, bool edgeLeft, bool edgeRight, bool shadeEdge)
#elif WITH_VECTOR_TEXTURES
void Renderer::DrawWallSegment(const uint8_t* texture, int16_t x1, int16_t w1, int16_t x2, int16_t w2, uint8_t u1clip, uint8_t u2clip, bool edgeLeft, bool edgeRight, bool shadeEdge)
#else
void Renderer::DrawWallSegment(int16_t x1, int16_t w1, int16_t x2, int16_t w2, bool edgeLeft, bool edgeRight, bool shadeEdge)
#endif
	if (x1 < 0)
#if WITH_TEXTURES
		u1clip += ((int32_t)(0 - x1) * (int32_t)(u2clip - u1clip)) / (x2 - x1);
#endif
		w1 += ((int32_t)(0 - x1) * (int32_t)(w2 - w1)) / (x2 - x1);
		x1 = 0;
		edgeLeft = false;
	int16_t werror = dx / 2;
	int16_t w = w1;
	int16_t dw;
	int8_t wstep;
	uint8_t du = u2clip - u1clip;
	int16_t uerror = werror;
	uint8_t u = u1clip;
#endif
	if (w1 < w2)
		dw = w2 - w1;
		wstep = 1;
		dw = w1 - w2;
		wstep = -1;
	constexpr uint8_t wallColour = COLOUR_WHITE;
	constexpr uint8_t edgeColour = COLOUR_BLACK;
	uint8_t segmentClipLeft = (uint8_t) x1;
	uint8_t segmentClipRight = x2 < DISPLAY_WIDTH ? (uint8_t) x2 : DISPLAY_WIDTH - 1;
	for (int x = x1; x < DISPLAY_WIDTH; x++)
		bool drawSlice = x >= 0 && wBuffer[x] < w;
		bool shadeSlice = shadeEdge && (x & 1) == 0;
		int8_t horizon = horizonBuffer[x];
		if (drawSlice)
			uint8_t sliceMask = 0xff;
			if ((edgeLeft && x == x1) || (edgeRight && x == x2))
				sliceMask = 0x00;
			else if (shadeSlice)
				sliceMask = 0x55;
				uint8_t y1 = w > horizon ? 0 : horizon - w;
				uint8_t y2 = horizon + w > DISPLAY_HEIGHT ? DISPLAY_HEIGHT : horizon + w;
				DrawVLine(x, y1, y2, sliceMask);
				uint16_t textureData = pgm_read_word(&texture[u % 16]);
				const uint16_t wallSize = w * 2;
				uint16_t wallPos = y1 - (horizon - w);
				for (uint8_t y = y1; y < y2; y++)
					uint8_t v = (16 * wallPos) / wallSize;
					uint16_t mask = pgm_read_word(&scaleDrawReadMasks[v]);
					if ((textureData & mask) == 0)
						Platform::PutPixel(x, y, 0);
					wallPos++;
#else
			int8_t extent = w > 90 ? 90 :w; //64 ? 64 : w;
			Platform::DrawVLine(x, horizon - extent, horizon + extent, sliceMask);
			Platform::PutPixel(x, horizon + extent, edgeColour);
			Platform::PutPixel(x, horizon - extent, edgeColour);
#endif
			if(wBuffer[x] == 0)
				numBufferSlicesFilled++;
			if (w > 255)
				wBuffer[x] = 255;
				wBuffer[x] = (uint8_t)w;
			if(x == segmentClipLeft)
				segmentClipLeft++;
			else if(x < segmentClipRight)
				segmentClipRight = x;
		if (x == x2)
		werror -= dw;
		while (werror < 0)
			w += wstep;
			werror += dx;
			if (drawSlice && werror < 0 && w <= DISPLAY_HEIGHT / 2)
				Platform::PutPixel(x, horizon + w - 1, edgeColour);
				Platform::PutPixel(x, horizon - w, edgeColour);
		uerror -= du;
		while(uerror < 0)
			u++;
			uerror += dx;
		#endif
	if(segmentClipLeft == segmentClipRight)
		return;
	if (w1 < MIN_TEXTURE_DISTANCE || w2 < MIN_TEXTURE_DISTANCE || !texture)
		return;
	if(u1clip == u2clip)
		return;
	const uint8_t* texPtr = texture;
	uint8_t numLines = pgm_read_byte(texPtr++);
	while (numLines)
		numLines--;
		uint8_t u1 = pgm_read_byte(texPtr++);
		uint8_t v1 = pgm_read_byte(texPtr++);
		uint8_t u2 = pgm_read_byte(texPtr++);
		uint8_t v2 = pgm_read_byte(texPtr++);
		//if(u1clip != 0 || u2clip != 128)
		//	continue;
		if (u2 < u1clip || u1 > u2clip)
			continue;
		if (u1 < u1clip)
			if(u2 != u1)
				v1 += (u1clip - u1) * (v2 - v1) / (u2 - u1);
			u1 = u1clip;
		if (u2 > u2clip)
			if (u2 != u1)
				v2 += (u2clip - u2) * (v1 - v2) / (u1 - u2);
			u2 = u2clip;
		u1 = (128 * (u1 - u1clip)) / (u2clip - u1clip);
		u2 = (128 * (u2 - u1clip)) / (u2clip - u1clip);
		int16_t outU1 = (((int32_t)u1 * dx) >> 7) + x1;
		int16_t outU2 = (((int32_t)u2 * dx) >> 7) + x1;
		int16_t interpw1 = ((u1 * (w2 - w1)) >> 7) + w1;
		int16_t interpw2 = ((u2 * (w2 - w1)) >> 7) + w1;
		int16_t outV1 = (interpw1 * v1) >> 6;
		int16_t outV2 = (interpw2 * v2) >> 6;
		//uint8_t horizon = horizonBuffer[x]
		//DrawLine(ScreenSurface, outU1, HORIZON - interpw1 + outV1, outU2, HORIZON - interpw2 + outV2, edgeColour, edgeColour, edgeColour);
		DrawWallLine(outU1, HORIZON - interpw1 + outV1, outU2, HORIZON - interpw2 + outV2, segmentClipLeft, segmentClipRight, edgeColour);
		//DrawWallLine(outU1, -interpw1 + outV1, outU2, -interpw2 + outV2, edgeColour);
#endif
bool Renderer::isFrustrumClipped(int16_t x, int16_t y)
	if ((camera.clipCos * (x - camera.cellX) - camera.clipSin * (y - camera.cellY)) < -512)
		return true;
	if ((camera.clipSin * (x - camera.cellX) + camera.clipCos * (y - camera.cellY)) < -512)
		return true;
	return false;
void Renderer::TransformToViewSpace(int16_t x, int16_t y, int16_t& outX, int16_t& outY)
	int32_t relX = x - camera.x;
	int32_t relY = y - camera.y;
	outY = (int16_t)((camera.rotCos * relX) >> 8) - (int16_t)((camera.rotSin * relY) >> 8);
	outX = (int16_t)((camera.rotSin * relX) >> 8) + (int16_t)((camera.rotCos * relY) >> 8);
void Renderer::TransformToScreenSpace(int16_t viewX, int16_t viewZ, int16_t& outX, int16_t& outW)
	// apply perspective projection
	outX = (int16_t)((int32_t)viewX * NEAR_PLANE * CAMERA_SCALE / viewZ);
	outW = (int16_t)((CELL_SIZE / 2 * NEAR_PLANE * CAMERA_SCALE) / viewZ);
	// transform into screen space
	outX = (int16_t)((DISPLAY_WIDTH / 2) + outX);
void Renderer::DrawWall(const uint16_t* texture, int16_t x1, int16_t y1, int16_t x2, int16_t y2, bool edgeLeft, bool edgeRight, bool shadeEdge)
void Renderer::DrawWall(const uint8_t* texture, int16_t x1, int16_t y1, int16_t x2, int16_t y2, bool edgeLeft, bool edgeRight, bool shadeEdge)
#else
void Renderer::DrawWall(int16_t x1, int16_t y1, int16_t x2, int16_t y2, bool edgeLeft, bool edgeRight, bool shadeEdge)
#endif
	int16_t viewX1, viewZ1, viewX2, viewZ2;
	uint8_t u1 = 0, u2 = 128;
#elif WITH_IMAGE_TEXTURES
	uint8_t u1 = 0, u2 = 16;
#endif
	TransformToViewSpace(x1, y1, viewX1, viewZ1);
	TransformToViewSpace(x2, y2, viewX2, viewZ2);
	// Frustum cull
	if (viewX2 < 0 && -2 * viewZ2 > viewX2)
		return;
	if (viewX1 > 0 && 2 * viewZ1 < viewX1)
		return;
	// clip to the front pane
	if ((viewZ1 < CLIP_PLANE) && (viewZ2 < CLIP_PLANE))
		return;
	if (viewZ1 < CLIP_PLANE)
#if WITH_TEXTURES
		u1 += (CLIP_PLANE - viewZ1) * (u2 - u1) / (viewZ2 - viewZ1);
#endif
		viewX1 += (CLIP_PLANE - viewZ1) * (viewX2 - viewX1) / (viewZ2 - viewZ1);
		viewZ1 = CLIP_PLANE;
		edgeLeft = false;
	else if (viewZ2 < CLIP_PLANE)
#if WITH_TEXTURES
		u2 += (CLIP_PLANE - viewZ2) * (u1 - u2) / (viewZ1 - viewZ2);
#endif
		viewX2 += (CLIP_PLANE - viewZ2) * (viewX1 - viewX2) / (viewZ1 - viewZ2);
		viewZ2 = CLIP_PLANE;
		edgeRight = false;
	int16_t vx1 = (int16_t)((int32_t)viewX1 * NEAR_PLANE * CAMERA_SCALE / viewZ1);
	int16_t vx2 = (int16_t)((int32_t)viewX2 * NEAR_PLANE * CAMERA_SCALE / viewZ2);
	// transform the end points into screen space
	int16_t sx1 = (int16_t)((DISPLAY_WIDTH / 2) + vx1);
	int16_t sx2 = (int16_t)((DISPLAY_WIDTH / 2) + vx2) - 1;
	if (sx1 >= sx2 || sx2 <= 0 || sx1 >= DISPLAY_WIDTH)
		return;
	int16_t w1 = (int16_t)((CELL_SIZE / 2 * NEAR_PLANE * CAMERA_SCALE) / viewZ1);
	int16_t w2 = (int16_t)((CELL_SIZE / 2 * NEAR_PLANE * CAMERA_SCALE) / viewZ2);
#if WITH_TEXTURES
	DrawWallSegment(texture, sx1, w1, sx2, w2, u1, u2, edgeLeft, edgeRight, shadeEdge);
#else
	DrawWallSegment(sx1, w1, sx2, w2, edgeLeft, edgeRight, shadeEdge);
#endif
void swap(int16_t& a, int16_t& b)
	int16_t temp = a;
	a = b;
	b = temp;
void Renderer::DrawFloorLineInner(int16_t x0, int16_t y0, int16_t x1, int16_t y1)
	uint8_t color = COLOUR_BLACK;
	bool steep = ABS(y1 - y0) > ABS(x1 - x0);
	if (steep)
		swap(x0, y0);
		swap(x1, y1);
	if (x0 > x1)
		swap(x0, x1);
		swap(y0, y1);
	int16_t dx, dy;
	dx = x1 - x0;
	dy = ABS(y1 - y0);
	int16_t err = dx / 2;
	int8_t ystep;
	if (y0 < y1)
		ystep = 1;
		ystep = -1;
	for (; x0 <= x1; x0++)
		if(steep)
			if(y0 >= 0 && y0 < DISPLAY_WIDTH && x0 >= 0 && x0 < DISPLAY_HEIGHT && x0 > GetHorizon(y0) + wBuffer[y0] && x0 > GetHorizon(y0) + 8)
				Platform::PutPixel((uint8_t)y0, (uint8_t)x0 + horizonBuffer[y0] - HORIZON, color);
			if(x0 >= 0 && x0 < DISPLAY_WIDTH && y0 >= 0 && y0 < DISPLAY_HEIGHT && y0 > GetHorizon(x0) + wBuffer[x0] && y0 > GetHorizon(x0) + 8)
				Platform::PutPixel((uint8_t)x0, (uint8_t)y0 + horizonBuffer[x0] - HORIZON, color);
		err -= dy;
		if (err < 0)
			y0 += ystep;
			err += dx;
void Renderer::DrawFloorLine(int16_t x1, int16_t y1, int16_t x2, int16_t y2)
	//if(viewX1 > viewX2)
	//	swap(viewX1, viewX2);
	//	swap(viewZ1, viewZ2);
	// Frustum cull
//	if (viewX2 < 0 && -2 * viewZ2 > viewX2)
//		return;
//	if (viewX1 > 0 && 2 * viewZ1 < viewX1)
//		return;
		return;
	//if (sx2 <= 0 || sx1 >= DISPLAY_WIDTH)
	//	return;
	DrawFloorLineInner(sx1, HORIZON + w1, sx2, HORIZON + w2);
void Renderer::DrawFloorLines()
	constexpr int size = 10;
	int16_t baseX = (Game::player.x - CELL_SIZE * size / 2) & 0xff00;
	int16_t baseY = (Game::player.y - CELL_SIZE * size / 2) & 0xff00;
	for(int n = 0; n < 10; n++)
		DrawFloorLine(baseX, baseY + n * CELL_SIZE, baseX + CELL_SIZE * 10 - n * CELL_SIZE, baseY + CELL_SIZE * 10);
		DrawFloorLine(baseX, baseY + n * CELL_SIZE, baseX + n * CELL_SIZE, baseY);
	for(int n = 1; n < 10; n++)
		DrawFloorLine(baseX + n * CELL_SIZE, baseY, baseX + CELL_SIZE * 10, baseY + CELL_SIZE * 10 - n * CELL_SIZE);
		DrawFloorLine(baseX + n * CELL_SIZE, baseY + 10 * CELL_SIZE, baseX + 10 * CELL_SIZE, baseY + n * CELL_SIZE);
void Renderer::DrawCell(uint8_t x, uint8_t y)
	CellType cellType = Map::GetCellSafe(x, y);
	if (isFrustrumClipped(x, y))
		return;
	switch (cellType)
	case CellType::Torch:
		const uint16_t* torchSpriteData = Game::globalTickFrame & 4 ? torchSpriteData1 : torchSpriteData2;
		constexpr uint8_t torchScale = 75;
		if (Map::IsSolid(x - 1, y))
			DrawObject(torchSpriteData, x * CELL_SIZE + CELL_SIZE / 7, y * CELL_SIZE + CELL_SIZE / 2, torchScale, AnchorType::Center);
		else if (Map::IsSolid(x + 1, y))
			DrawObject(torchSpriteData, x * CELL_SIZE + 6 * CELL_SIZE / 7, y * CELL_SIZE + CELL_SIZE / 2, torchScale, AnchorType::Center);
		else if (Map::IsSolid(x, y - 1))
			DrawObject(torchSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 7, torchScale, AnchorType::Center);
		else if (Map::IsSolid(x, y + 1))
			DrawObject(torchSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + 6 * CELL_SIZE / 7, torchScale, AnchorType::Center);
	return;
	case CellType::Entrance:
		DrawObject(entranceSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 96, AnchorType::Ceiling);
		return;
	case CellType::Exit:
		DrawObject(exitSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 96);
		return;
	case CellType::Urn:
		DrawObject(urnSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 80);
		return;
	case CellType::Potion:
		DrawObject(potionSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 64);
		return;
	case CellType::Scroll:
		DrawObject(scrollSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 64);
		return;
	case CellType::Coins:
		DrawObject(coinsSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 64);
		return;
	case CellType::Crown:
		DrawObject(crownSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 64);
		return;
	case CellType::Sign:
		DrawObject(signSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 80);
		return;
	case CellType::Chest:
		DrawObject(chestSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 75);
		return;
	case CellType::ChestOpened:
		DrawObject(chestOpenSpriteData, x * CELL_SIZE + CELL_SIZE / 2, y * CELL_SIZE + CELL_SIZE / 2, 75);
		return;
	default:
	if(numBufferSlicesFilled >= DISPLAY_WIDTH)
		return;
	if (!Map::IsSolid(x, y))
		return;
	int16_t x1 = x * CELL_SIZE;
	int16_t y1 = y * CELL_SIZE;
	int16_t x2 = x1 + CELL_SIZE;
	int16_t y2 = y1 + CELL_SIZE;
	bool blockedLeft = Map::IsSolid(x - 1, y);
	bool blockedRight = Map::IsSolid(x + 1, y);
	bool blockedUp = Map::IsSolid(x, y - 1);
	bool blockedDown = Map::IsSolid(x, y + 1);
	const uint16_t* texture = wallTextureData + (16 * (cellType - 1));
	const uint8_t* texture = vectorTexture0; // (const uint8_t*) pgm_read_ptr(&textures[(uint8_t)cellType - (uint8_t)CellType::FirstSolidCell]);
#endif
	if (!blockedLeft && camera.x < x1)
#if WITH_TEXTURES
		DrawWall(texture, x1, y1, x1, y2, !blockedUp && camera.y > y1, !blockedDown && camera.y < y2, true);
#else
		DrawWall(x1, y1, x1, y2, !blockedUp && camera.y > y1, !blockedDown && camera.y < y2, true);
#endif
	if (!blockedDown && camera.y > y2)
#if WITH_TEXTURES
		DrawWall(texture, x1, y2, x2, y2, !blockedLeft && camera.x > x1, !blockedRight && camera.x < x2, false);
#else
		DrawWall(x1, y2, x2, y2, !blockedLeft && camera.x > x1, !blockedRight && camera.x < x2, false);
#endif
	if (!blockedRight && camera.x > x2)
#if WITH_TEXTURES
		DrawWall(texture, x2, y2, x2, y1, !blockedDown && camera.y < y2, !blockedUp && camera.y > y1, true);
#else
		DrawWall(x2, y2, x2, y1, !blockedDown && camera.y < y2, !blockedUp && camera.y > y1, true);
#endif
	if (!blockedUp && camera.y < y1)
#if WITH_TEXTURES
		DrawWall(texture, x2, y1, x1, y1, !blockedRight && camera.x < x2, !blockedLeft && camera.x > x1, false);
#else
		DrawWall(x2, y1, x1, y1, !blockedRight && camera.x < x2, !blockedLeft && camera.x > x1, false);
#endif
void Renderer::DrawCells()
	constexpr int8_t MAP_BUFFER_WIDTH = 16;
	constexpr int8_t MAP_BUFFER_HEIGHT = 16;
	int16_t cosAngle = FixedCos(camera.angle);
	int16_t sinAngle = FixedSin(camera.angle);
	int8_t bufferX = (int8_t)((camera.x + cosAngle * 7) >> 8) - MAP_BUFFER_WIDTH / 2;
	int8_t bufferY = (int8_t)((camera.y + sinAngle * 7) >> 8) - MAP_BUFFER_WIDTH / 2;;
	if(bufferX < 0)
		bufferX = 0;
	if(bufferY < 0)
		bufferY = 0;
	if(bufferX > Map::width - MAP_BUFFER_WIDTH)
		bufferX = Map::width - MAP_BUFFER_WIDTH;
	if(bufferY > Map::height - MAP_BUFFER_HEIGHT)
		bufferY = Map::height - MAP_BUFFER_HEIGHT;
	// This should make cells draw front to back
	int8_t xd, yd;
	int8_t x1, y1, x2, y2;
	if(camera.rotCos > 0)
		x1 = bufferX;
		x2 = x1 + MAP_BUFFER_WIDTH;
		xd = 1;
		x2 = bufferX - 1;
		x1 = x2 + MAP_BUFFER_WIDTH;
		xd = -1;
	if(camera.rotSin < 0)
		y1 = bufferY;
		y2 = y1 + MAP_BUFFER_HEIGHT;
		yd = 1;
		y2 = bufferY - 1;
		y1 = y2 + MAP_BUFFER_HEIGHT;
		yd = -1;
	if(ABS(camera.rotCos) < ABS(camera.rotSin))
		for(int8_t y = y1; y != y2; y += yd)
			for(int8_t x = x1; x != x2; x+= xd)
				DrawCell(x, y);
				DrawCell(x, y);
void DrawScaledOutline(const uint16_t* data, int8_t x, int8_t y, uint8_t halfSize, uint8_t inverseCameraDistance, uint8_t shiftAmount, bool invert)
	uint8_t size = 2 * halfSize;
	const uint8_t* lut = scaleLUT + (((halfSize - 1) >> shiftAmount) * ((halfSize - 1) >> shiftAmount));
	uint8_t i0 = x < 0 ? -x : 0;
	uint8_t i1 = x + size > DISPLAY_WIDTH ? DISPLAY_WIDTH - x : size;
	uint8_t j0 = y < 0 ? -y : 0;
	uint8_t j1 = y + size > DISPLAY_HEIGHT ? DISPLAY_HEIGHT - y : size;
	int8_t outX = x >= 0 ? x : 0;
	uint16_t invertMask = invert ? 0xffff : 0;
	uint16_t leftTransparencyAndColourColumn = 0;
	uint16_t middleTransparencyColumn = 0;
	uint16_t rightTransparencyColumn = 0;
	uint16_t middleColourColumn = 0;
	uint16_t rightColourColumn = 0;
	bool wasVisible = false;
	for (uint8_t i = i0; i < i1; i++)
		const bool isVisible = Renderer::wBuffer[outX] < inverseCameraDistance;
		if (isVisible)
			uint16_t leftRightOutlineColumn = 0;
			if(i >= i1 - 2)
				if (wasVisible)
					leftTransparencyAndColourColumn = middleColourColumn & middleTransparencyColumn;
					middleColourColumn = rightColourColumn;
					middleTransparencyColumn = rightTransparencyColumn;
					leftRightOutlineColumn = leftTransparencyAndColourColumn;
				const uint8_t u = pgm_read_byte(&lut[i >> shiftAmount]);
				if (wasVisible)
					rightTransparencyColumn = pgm_read_word(&data[u * 2]);
					rightColourColumn = pgm_read_word(&data[u * 2 + 1]) ^ invertMask;
					leftRightOutlineColumn = leftTransparencyAndColourColumn | (rightColourColumn & rightTransparencyColumn);
					leftRightOutlineColumn = (rightColourColumn & rightTransparencyColumn);
			int8_t outY = y >= 0 ? y : 0;
			uint8_t bufferPos = (outY & 7);
			uint8_t* screenBuffer = Platform::GetScreenBuffer() + outX + ((outY & 0x38) << 4);
			uint8_t localBuffer = *screenBuffer;
			uint8_t writeMask = pgm_read_byte(&scaleDrawWriteMasks[bufferPos]);
			bool upIsOpaqueAndWhite = false;
			bool middleIsOpaque = false;
			bool downIsOpaque = false;
			bool middleIsWhite = false;
			bool downIsWhite = false;
			bool leftOrRightIsOutline = false;
			bool downLeftOrRightIsOutline = false;
			for (uint8_t j = j0; j < j1; j++)
				upIsOpaqueAndWhite = middleIsOpaque && middleIsWhite;
				middleIsOpaque = downIsOpaque;
				middleIsWhite = downIsWhite;
				leftOrRightIsOutline = downLeftOrRightIsOutline;
				if(j >= j1 - 2)
					uint8_t v = pgm_read_byte(&lut[j >> shiftAmount]);
					downLeftOrRightIsOutline = (leftRightOutlineColumn & mask) != 0;
					downIsOpaque = (middleTransparencyColumn & mask) != 0;
					downIsWhite = (middleColourColumn & mask) != 0;
				if (middleIsOpaque && j < j1)
					if(middleIsWhite)
						localBuffer |= writeMask;
						localBuffer &= ~writeMask;
				else if(leftOrRightIsOutline || (upIsOpaqueAndWhite) || (downIsOpaque && downIsWhite))
				outY++;
				bufferPos++;
				writeMask <<= 1;
				if(bufferPos == 8)
					bufferPos = 0;
					writeMask = 1;
					*screenBuffer = localBuffer;
					if(outY < DISPLAY_HEIGHT)
						screenBuffer += 128;
		outX++;
		wasVisible = isVisible;
template<int scaleMultiplier>
inline void DrawScaledNoOutline(const uint16_t* data, int8_t x, int8_t y, uint8_t halfSize, uint8_t inverseCameraDistance)
	const uint8_t* lut = scaleLUT + ((halfSize / scaleMultiplier) * (halfSize / scaleMultiplier));
		if (isVisible)
			const uint8_t u = pgm_read_byte(&lut[i / scaleMultiplier]);
			uint16_t transparencyColumn = pgm_read_word(&data[u * 2]);
			uint16_t colourColumn = pgm_read_word(&data[u * 2 + 1]);
			for (uint8_t j = j0; j < j1; j += scaleMultiplier)
				uint8_t v = pgm_read_byte(&lut[j / scaleMultiplier]);
				for (uint8_t k = 0; k < scaleMultiplier; k++)
					bool isOpaque = (transparencyColumn & mask) != 0;
					if (isOpaque)
						bool isWhite = (colourColumn & mask) != 0;
						if (isWhite)
					outY++;
					bufferPos++;
					writeMask <<= 1;
					if (bufferPos == 8)
						bufferPos = 0;
						writeMask = 1;
						if (outY < DISPLAY_HEIGHT)
		outX++;
void Renderer::DrawScaled(const uint16_t* data, int8_t x, int8_t y, uint8_t halfSize, uint8_t inverseCameraDistance, bool invert)
	if (halfSize > MAX_SPRITE_SIZE * 2)
		return;
	else if (halfSize > MAX_SPRITE_SIZE)
		DrawScaledInner(data, x, y, halfSize, inverseCameraDistance, 2, invert);
	else if (halfSize * 2 > MAX_SPRITE_SIZE)
		DrawScaledInner(data, x, y, halfSize, inverseCameraDistance, 1, invert);
	else if(halfSize > 2)
		DrawScaledInner(data, x, y, halfSize, inverseCameraDistance, 0, invert);
	else if (halfSize == 2)
		if (Renderer::wBuffer[x] < inverseCameraDistance)
			Platform::PutPixel(x, y, COLOUR_BLACK);
			Platform::PutPixel(x, y + 1, COLOUR_BLACK);
		if (Renderer::wBuffer[x + 1] < inverseCameraDistance)
			Platform::PutPixel(x + 1, y, COLOUR_BLACK);
			Platform::PutPixel(x + 1, y + 1, COLOUR_BLACK);
QueuedDrawable* Renderer::CreateQueuedDrawable(uint8_t inverseCameraDistance)
	uint8_t insertionPoint = MAX_QUEUED_DRAWABLES;
	for(uint8_t n = 0; n < numQueuedDrawables; n++)
		if(inverseCameraDistance < queuedDrawables[n].inverseCameraDistance)
			if(numQueuedDrawables < MAX_QUEUED_DRAWABLES)
				insertionPoint = n;
				numQueuedDrawables++;
				for (uint8_t i = numQueuedDrawables - 1; i > n; i--)
					queuedDrawables[i] = queuedDrawables[i - 1];
				if(n == 0)
					// List is full and this is smaller than the first element so just cull
					return nullptr;
				// Drop the smallest element to make a space
				for (uint8_t i = 0; i < n - 1; i++)
					queuedDrawables[i] = queuedDrawables[i + 1];
				insertionPoint = n - 1;
	if(insertionPoint == MAX_QUEUED_DRAWABLES)
			insertionPoint = numQueuedDrawables;
		else if (inverseCameraDistance > queuedDrawables[numQueuedDrawables - 1].inverseCameraDistance)
			for (uint8_t i = 0; i < numQueuedDrawables - 1; i++)
			insertionPoint = numQueuedDrawables - 1;
			return nullptr;
	return &queuedDrawables[insertionPoint];
void Renderer::QueueSprite(const uint16_t* data, int8_t x, int8_t y, uint8_t halfSize, uint8_t inverseCameraDistance, bool invert)
	if(x < -halfSize * 2)
		return;
	//if(x >= DISPLAY_WIDTH)
	//	return;
	//if(halfSize <= 2)
	//	return;
	QueuedDrawable* drawable = CreateQueuedDrawable(inverseCameraDistance);
	if(drawable != nullptr)
		drawable->type = DrawableType::Sprite;
		drawable->spriteData = data;
		drawable->x = x;
		drawable->y = y;
		drawable->halfSize = halfSize;
		drawable->inverseCameraDistance = inverseCameraDistance;
		drawable->invert = invert;
void Renderer::RenderQueuedDrawables()
		QueuedDrawable& drawable = queuedDrawables[n];
		if(drawable.type == DrawableType::Sprite)
			DrawScaled(drawable.spriteData, drawable.x, drawable.y, drawable.halfSize, drawable.inverseCameraDistance, drawable.invert);
			drawable.particleSystem->Draw(drawable.x, drawable.inverseCameraDistance);
int8_t Renderer::GetHorizon(int16_t x)
	if (x < 0)
		x = 0;
	if (x >= DISPLAY_WIDTH)
		x = DISPLAY_WIDTH - 1;
	return horizonBuffer[x];
bool Renderer::TransformAndCull(int16_t worldX, int16_t worldY, int16_t& outScreenX, int16_t& outScreenW)
	int16_t relX, relZ;
	TransformToViewSpace(worldX, worldY, relX, relZ);
	// Frustum cull
	if (relZ < CLIP_PLANE)
		return false;
	if (relX < 0 && -2 * relZ > relX)
		return false;
	if (relX > 0 && 2 * relZ < relX)
		return false;
	TransformToScreenSpace(relX, relZ, outScreenX, outScreenW);
	return true;
void Renderer::DrawObject(const uint16_t* spriteData, int16_t x, int16_t y, uint8_t scale, AnchorType anchor, bool invert)
	int16_t screenX, screenW;
	if(TransformAndCull(x, y, screenX, screenW))
		// Bit of a hack: nudge sorting closer to the camera
		uint8_t inverseCameraDistance = (uint8_t)(screenW + 1);
		int16_t spriteSize = (screenW * scale) / 128;
		int8_t outY = GetHorizon(screenX);
		switch (anchor)
		case AnchorType::Floor:
			outY += screenW - 2 * spriteSize;
		case AnchorType::Center:
			outY -= spriteSize;
		case AnchorType::BelowCenter:
		case AnchorType::Ceiling:
			outY -= screenW;
		QueueSprite(spriteData, screenX - spriteSize, outY, (uint8_t)spriteSize, inverseCameraDistance, invert);
void Renderer::DrawWeapon()
	int x = DISPLAY_WIDTH / 2 + 22 + camera.tilt / 4;
	int y = DISPLAY_HEIGHT - 21 - camera.bob;
	uint8_t reloadTime = Game::player.reloadTime;
	if(reloadTime > 0)
		Platform::DrawSprite(x - reloadTime / 3 - 1, y - reloadTime / 3 - 1, handSpriteData2, 0);
		//DrawSprite(x - reloadTime / 3 - 1, y - reloadTime / 3 - 1, handSpriteData2, handSpriteData2_mask, 0, 0);
		Platform::DrawSprite(x + 2, y + 2, handSpriteData1, 0);
		//DrawSprite(x + 2, y + 2, handSpriteData1, handSpriteData1_mask, 0, 0);
void Renderer::DrawBackground()
	uint8_t* ptr = Platform::GetScreenBuffer();
	uint8_t counter = 128;
	while (counter--)
		*ptr++ = 0x55; *ptr++ = 0x00; *ptr++ = 0xaa; *ptr++ = 0x00;
	counter = 128;
	while (counter--)
		*ptr++ = 0x55; *ptr++ = 0xff; *ptr++ = 0xaa; *ptr++ = 0xff;
void Renderer::DrawBar(uint8_t* screenPtr, const uint8_t* iconData, uint8_t amount, uint8_t max)
	constexpr uint8_t iconWidth = 8;
	constexpr uint8_t barWidth = 32;
	constexpr uint8_t unfilledBar = 0xfe;
	constexpr uint8_t filledBar = 0xc6;
	uint8_t fillAmount = (amount * barWidth) / max;
	uint8_t x = 0;
	while (x < iconWidth)
		screenPtr[x] = pgm_read_byte(&iconData[x]);
		x++;
	while (fillAmount--)
		screenPtr[x++] = filledBar;
	while (x < barWidth + iconWidth)
		screenPtr[x++] = unfilledBar;
	screenPtr[x] = 0;
void Renderer::DrawDamageIndicator()
	uint8_t* upper = Platform::GetScreenBuffer();
	uint8_t* lower = upper + DISPLAY_WIDTH * 7;
	for (int x = 1; x < DISPLAY_WIDTH - 1; x++)
		upper[x] &= 0xfe;
		lower[x] &= 0x7f;
	for (int y = 0; y < DISPLAY_HEIGHT / 8; y++)
		*ptr = 0;
		ptr += (DISPLAY_WIDTH - 1);
		*ptr = 0;
		ptr++;
void Renderer::DrawHUD()
	constexpr uint8_t barWidth = 40;
	uint8_t* screenBuffer = Platform::GetScreenBuffer();
	uint8_t* screenPtr = screenBuffer + DISPLAY_WIDTH * 6;
	DrawBar(screenBuffer + DISPLAY_WIDTH * 7, heartSpriteData, Game::player.hp, Game::player.maxHP);
	DrawBar(screenBuffer + DISPLAY_WIDTH * 6, manaSpriteData, Game::player.mana, Game::player.maxMana);
	if(Game::player.damageTime > 0)
		DrawDamageIndicator();
	if (Game::displayMessage)
		Font::PrintString(Game::displayMessage, 0, 0);
void Renderer::Render()
	globalRenderFrame++;
	DrawBackground();
	for (uint8_t n = 0; n < DISPLAY_WIDTH; n++)
		wBuffer[n] = 0;
		horizonBuffer[n] = HORIZON + (((DISPLAY_WIDTH / 2 - n) * camera.tilt) >> 8) + camera.bob;
	camera.cellX = camera.x / CELL_SIZE;
	camera.cellY = camera.y / CELL_SIZE;
	camera.rotCos = FixedCos(-camera.angle);
	camera.rotSin = FixedSin(-camera.angle);
	camera.clipCos = FixedCos(-camera.angle + CLIP_ANGLE);
	camera.clipSin = FixedSin(-camera.angle + CLIP_ANGLE);
	DrawCells();
	//DrawFloorLines();
	EnemyManager::Draw();
	ProjectileManager::Draw();
	ParticleSystemManager::Draw();
	RenderQueuedDrawables();
	DrawWeapon();
	DrawHUD();
	//Map::DrawMinimap();
i have started work on using another raycaster which gives me 100% of screen usage and the extra vertical lines of resolution are working. ram usage grows but when your using a esp32 you can bear with that alittle. teensy and pico should be fine as well as the 8266 and sam stuff. i just couldnt upload the same sketch knowing it wouldnt do the thing anymore. i will port functionality from it to the new host sketch which is a old 250 ish line of code raycaster i found on github
