Hello, I'm having an issue with the synchronization of variables in the Iot as they update in one but they don't synchronize. I've tried uploading the code on both boards a couple times, re-synchronyzing the variables, updating libraries, and a couple other things but it still won't update.
I'm also facing the same issue did u find any solution or the problem got resolved?
Not yet I sent an email to support I’ll let you know what they tell me
Hello @hover_ant,
I would suggest you to follow the instructions from Syncing Variables Across Things.
The variables must be set to read and write settings, this way the variables can write the value received from the other synced variables.
If you are still facing the same issues, please provide us the steps you took to set up the two Synced Things.
