variables?
hi! is it possible to declare a variable in the arduinoCode and recieve it through flash? i have tried the FlashConversation.fla, working fine but the code is to complex for me to clean up. could someone offer me the most simple piece of code that can recieve a number from arduino to flash, please!
Hello,
I always use the 'Serial Server' created by Dan O'Sullivan.
Read the instructions, after installing, start the server with: java -jar ss6.jar SerialPort:COM1 Baud:9600 SocketPort:9001 Sub0ForChar:10 SerialDriver:Sun (maybe you have to change your serialport):
You can use the 'debug' checkbox to check if the 'serial server' receives any value. If it works you can start Flash and use this code:
createSocket();
function createSocket() {
      serialServer = new XMLSocket();
      trace("new xmsocket");
      serialServer.connect("127.0.0.1", 9001);
      serialServer.onConnect = function(success) {
            trace("connected " + success);
      // when you close the serial port
      serialServer.onClose = function() {
            trace("closed");
      //receive some data from the arduino
      serialServer.onData = function(data) {
            trace("incoming = " + data);
// send data to the arduino
this.onMouseDown = function() {
      serialServer.send("A");
      trace("Mouse Down");
stop();
does it work with , Serial Proxy? and what code do you fill your arduino with, simpeMessageSysyem?
regards xh|in
You can use this code to send data from Arduino to flash:
  Serial.println("Hello Flash, this is Arduino");
  delay(400);
Hi!
I tried to connect Arduino (0005) and Flash 8. But there are two strange things happening:
  • 1 -
When I read the Serial monitor in Arduino, there are only "0"s (zeros) when I press a pushbutton (connected to I/O Pin 5), but when I release this pushbutton, there are both, "0"s and "1"s (00011100000011111000111 and so on). Actually, there should be only "1"s, right?! Why does this happen?
Here's my Arduino-Code:
int ledPin = 13; // LED connected to digital pin 13 int inPin = 5; // pushbutton connected to digital pin 5 int val = 0; // variable to store the read value
void setup() { pinMode(ledPin, OUTPUT); // sets the digital pin 13 as output pinMode(inPin, INPUT); // sets the digital pin 7 as input Serial.begin(9600); // opens serial port, sets data rate to 9600 bps }
void loop() { val = digitalRead(inPin); // read the input pin digitalWrite(ledPin, val); // sets the LED to the button's value
// Serial.print(val, DEC); // send the buttons's value to serial port
// say what you got: //Serial.print("I received: "); Serial.println(val, DEC);
  • 2 -
Another problem occurs in Flash. I'm using a proxy by D.Mellis, that works fine so far. Flash can hear Arduino and trace the received values. But, when I use an "if"-loop, it seems to be ignored. Here's my Actionscript-Code:
createSocket();
function createSocket() { serialServer = new XMLSocket(); trace("new xmlsocket");
serialServer.connect("127.0.0.1", 5337);
serialServer.onConnect = function(success) { trace("connected " + success); };
// when you close the serial port serialServer.onClose = function() { trace("closed"); };
//receive some data from the arduino serialServer.onData = function(data) { trace("incoming = " + data);
// begin if-loop if (data == "0") { meinRechteck.start(); trace("VERTICAL"); } else { meinRechteck.stop(); trace("HORIZONTAL"); } } };
stop();
And this is, what is traced:
incoming = 0
HORIZONTAL incoming = 1
HORIZONTAL
So, there is always "HORIZONTAL" traced, but i want "VERTICAL" if data == "0" !
Maybe someone can help me?! Any ideas? Thanks a lot!
Daniel
1) Did you use a resistor as you can see in this tutorial?
2) I don't really know, but you could try this to find out and locate the problem:
trace("type = " + typeof(data)); trace("string length = " + data.length);
So the datatype should be a 'string' and the length should be '1' I
Hej ya!
So, I set up the whole thing like in the tutorial and now the serial output is ok! :) Thanks a lot, Eric!
But:
I traced the lenght and type of 'data' in Flash 8:
data is a string (ok) and the length is 2 (not 1)!
Does anyone know how to solve this problem?
Thanx a lot for your support...
Daniel.
I think you only want the first character,
the second is probably a ‘space’.
The actionscript code for this is:
trace(data.substr(0,1));
It will only show the first character.
Eric
