VarSpeedServoRA4M1 is a library for Arduino (developed by Kaled Souky in 2024), based on the Servo library (developed by Michael Margolis in 2009) and VarSpeedServo library (developed by Korman in 2010 and updated by Philip van Allen in 2013). Specifically designed for the Renesas RA4M1 microcontroller architecture (Arm Cortex-M4), present on the Arduino UNO R4 Minima and Arduino UNO R4 WiFi boards.
VarSpeedServoRA4M1 is an interrupt-driven library using 16-bit timers, allowing the use of up to 12 servos moving asynchronously or synchronously. In addition to setting the position, you can set the speed of a movement, optionally wait until the servo movement is completed, and create sequences of movements that execute asynchronously or synchronously.
The 32-bit Renesas RA4M1 processor operating at 48 MHz elevates servo control to a new level, providing higher PWM resolution compared to the ATmega328P used in Arduino UNO R3. Thanks to this power, VarSpeedServoRA4M1 fully exploits the microcontroller's capabilities. With its simple and intuitive syntax, this library facilitates precise control over servo position and speed, even for beginners. Creating complex movement sequences is straightforward with just a few commands.
Download the library by clicking on the description below the video
or scan the QR code shown in the video
WARNING:
"External devices with a high current draw (e.g. servo motors) should never be powered via the 5 V pin. It is mainly intended for devices drawing lower current such as sensor modules".
TIP:
How to connect power and control servo motors with your Arduino board. Please check the link of Arduino official site:
Features:
- Supports up to 12 servos.
- Allows synchronous and asynchronous movement of all servos.
- Allows you to configure the "position" and "speed" of each servo individually.
- Includes a "wait" parameter to wait for the servo to complete its movement. Philip van Allen, in his update, incorporated it as a boolean variable within the write() function, and also as the independent
wait()function. This parameter is not included as a variable in Korman'sslowmove()function. - The write() function now includes the "speed" and "wait" parameters, which can optionally be used in conjunction
with the "position" parameter to control servo movement. - The
slowmove()function is retained for compatibility with the Korman version. It only handles the "position" and "speed" parameters. In this case, the waiting time must be configured (using, for example, the functiondelay(),delayMicroseconds(),micros()ormillis()), so that the servo completes the position and maintains it for the desired time. Theslowmove()function does not incorporate the "wait" variable introduced by Philip van Allen in thewrite()function. - Allows the creation of position sequences.
Class methods
A servo is activated by creating an instance of the VarSpeedServoRA4M1 class passing the desired pin to the attach() method. The servos are pulsed in the background using the value most recently written using the write() method
Note that analogWrite of PWM on pins associated with the timer are disabled when the first servo is attached.
Timers are seized as needed in groups of 12 servos - 24 servos use two timers, 48 servos will use four.
The sequence used to seize timers is defined in the content of the "ServoTimers.h" file for Renesas of the Arduino Servo library.
VarSpeedServoRA4M1 - Class for manipulating servo motors connected to Arduino pins. Methods:
VarSpeedServoRA4M1() - Creates a new Servo object and prepares it for controlling a servo motor
attach(pin ) - Attaches a servo motor to an i/o pin
attach(pin, min, max ) - Attaches to a pin setting min and max values in microseconds default min is 544, max is 2400
write(value) - Sets the servo angle in degrees (invalid angle that is valid as pulse in microseconds is treated as microseconds)
write(value, speed) - speed varies the speed of the move to new position 0=full speed, 1-255 slower to faster
write(value, speed, wait) - wait is a boolean that, if true, causes the function call to block until move is complete
writeMicroseconds() - Sets the servo pulse width in microseconds
read() - Gets the last written servo pulse width as an angle between 0 and 180
readMicroseconds() - Gets the last written servo pulse width in microseconds (was read_us() in first release)
attached() - Returns true if there is a servo attached
detach() - Stops an attached servos from pulsing its i/o pin
slowmove(value, speed) - The same as write(value, speed), retained for compatibility with Korman's version
stop() - stops the servo at the current position
sequencePlay(sequence, sequencePositions) - play a looping sequence starting at position 0
sequencePlay(sequence, sequencePositions, loop, startPosition) - play sequence with number of positions, loop if true, start at position
sequenceStop() - stop sequence at current position
wait() - wait for movement to finish
isMoving() - return true if servo is still moving
Examples of use:
Sample code 1: Sweeps a servo motor from 0 to 180 degrees at fast speed and back from 180 to 0 degrees at slow speed, in an infinite loop.
The write() function now includes the "speed" and "wait" parameters, which can optionally be used in conjunction with the "position" parameter to control servo movement.
The "wait" parameter is used to wait for the servo to complete its movement. It is also available as a standalone wait() function.
#include <VarSpeedServoRA4M1.h>
VarSpeedServoRA4M1 myservo; // create servo object to control a servo
// A maximum of twelve servo objects can be created
const int servoPin = 9; // the digital pin used for the servo
myservo.attach(servoPin); // attaches the servo on pin 9 to the servo object
myservo.write(0,127,true); // set the servo to its initial position at fast speed, wait for completion
// write(degrees 0-180, speed 1-255, wait to complete true-false)
/* On the RC servos tested, speed differences above 127
cannot be noticed due to the mechanical limitations of
the servo. However, feel free to experiment with the
speed value that best suits the response of your servo
based on its mechanical and electronic characteristics
myservo.write(180,127,true); // move the servo to 180, fast speed, wait until done
myservo.write(0,30,true); // move the servo to 0, slow speed, wait until done
Sample code 2: Sweeps a servo motor from 0 to 180 degrees at fast speed and back from 180 to 0 degrees at slow speed, in an infinite loop.
The slowmove() function only handles the "position" and "speed" parameters. In this case, the wait time must be set (using, for example, the delay(), millis(), micros(), or delayMicroseconds() functions) to ensure the servo completes the position and maintains it for the desired time. The slowmove() function does not incorporate the "wait" variable.
This example demonstrates the use of the delay() function as a timeout with slowmove(). The exact delay value may require some experimentation (usually in the millisecond range) to ensure that the servo has enough time to reach its target position and hold it for as long as necessary, until receiving the next instruction.
myservo.slowmove(0,127); // set the servo to its initial position at fast speed
delay(1000); // sets the time the servo needs to reach the position and stay there
// slowmove(degrees 0-180, speed 1-255)
myservo.slowmove(180,127); // move the servo to 180, fast speed
myservo.slowmove(0,30); // move the servo to 0, slow speed
delay(3700); // sets the time the servo needs to reach the position and stay there
Additional examples are included in the distribution and are available in the Arduino IDE Examples section.
NOTE:
The VarSpeedServoRA4M1 library is not included in the standard Arduino distribution. You must download and install it separately.
There are two methods to achieve this:
- Import a ZIP library
- Manual installation
These methods are described on the official Arduino site:
