Vary voltage between positive and negative to drive vibration generator
I am doing a Physics project which would involve simulating an earthquake from real data (obtained from http://www.strongmotioncenter.org) instead of having a basic signal generator which produces one tone at a given frequency.
I was hoping to use an Arduino Uno and control a vibration generator to move a wooden board with wheels, mimicking tectonic plate movement. I have the displacement data in a csv file which I would scale (max. ve displacement = max. +/-ve voltage) and would pass via the serial port to calculate the required voltage and then supply to vibration generator to create movement.
The vibration generator can take a maximum current of 1A and I assume that it will take a change in voltage to drive the motion. (http://thumbs.worthpoint.com/zoom/images2/360/0412/09/vibration-generator-unilab-working_360_a952191c7a529459de699d798bf84a25.jpg). I think that voltage supplied would have to be both positive and negative to change direction of motion (magnetic induction and Lenz's law). How could I achieve this?
I know I can vary the voltage using the analogWrite functions for the pins, would I have to then amplify the voltage to allow for small changes in displacement (please see attached csv file)? If so how is this achieved?
Thanks Laurence
The vibration generator can take a maximum current of 1A and I assume that it will take a change in voltage to drive the motion. (http://thumbs.worthpoint.com/zoom/images2/360/0412/09/vibration-generator-unilab-working_360_a952191c7a529459de699d798bf84a25.jpg). I think that voltage supplied would have to be both positive and negative to change direction of motion (magnetic induction and Lenz’s law). How could I achieve this?
I know I can vary the voltage using the analogWrite functions for the pins, would I have to then amplify the voltage to allow for small changes in displacement (please see attached txt version of csv file)? If so how is this achieved? Would a digital to analog convertor be needed?
Thanks
Laurence
20140310_051804_CE_89781_Vo2_StP_Ch2_D.txt (181 KB)
Do you? That is wrong, the voltage out is always a 5V rectangular wave, the value you write controls the duty cycle.
To get the current to go both ways through a load then use a circuit known as a H-bridge.
